My VQ35HR Build
Old Feb 3, 2010 | 10:17 PM
  #61
350z006's Avatar
350z006
Curious what break-in method you're using....the typical safe way or the drive-it-like-you-stole-it-to-break-in-rings-better method....
Originally Posted by Jasonvs2146
Been driving the car for the past several days. Break in miles woohoo. Thing runs so smooth cant wait to tune and dyno it ... Btw Operating temp has not been affected at all car runs as if nothing had changed.
Old Feb 4, 2010 | 11:33 PM
  #62
Jasonvs2146's Avatar
Jasonvs2146
Playing it safe.
Old Feb 4, 2010 | 11:40 PM
  #63
Jasonvs2146
I'm also working with a buddy we are going to run earls fittings on everything and the hoses will b custom made. Will be pretty nice no worries bout hose issues after
Old Feb 5, 2010 | 01:45 PM
  #64
UnitedBreaks's Avatar
UnitedBreaks
I wanna come see the ride man, sounds wicked. I'm in s. st.pete near the skyway.
Old Feb 5, 2010 | 01:47 PM
  #65
Jasonvs2146
LoL you do know im in the 350zcluboffl right? Im the webmaster there
Old Feb 5, 2010 | 01:54 PM
  #66
UnitedBreaks
yeah, I know
Old Feb 5, 2010 | 06:00 PM
  #67
Ahsmo's Avatar
Ahsmo
Imakecopies
So what about the block and the filler material expanding at different rates? How about the unrelieved stresses from the welding?
Old Mar 9, 2010 | 09:31 AM
  #68
rcdash's Avatar
rcdash
Any updates?
Originally Posted by ttg35fort
From a structural sense, the block guards make alot of sense. From the little research I have done so far, it appears that they are not as strong as sleeving, but reduce cylinder movement in high HP builds. Some people are claiming that they do reduce cooling in the upper part of the cylinder, which would not be good. Nonetheless, both the SuperTech and KMS block guards have numerous small cooling passages and, of course, they will need to be drilled out with much larger cooling passages to match those in the head gasket.
Another solution could be to only use portions of the block guard at structurally significant locations. For example, instead of completely surrounding the cylinders and then drilling holes, perhaps weld in a 2" section on the two opposing portions of each cylinder that are aligned with the rotation of the crank.
I would think that the small iron-aluminum-aluminum boundary layer would help to conduct heat away from the top of the cylinders vs the iron-coolant-aluminum interface.
Old Apr 2, 2010 | 07:07 AM
  #69
Andrei's Avatar
Andrei
Quick question. If closing an older block with over 100k miles wouldn't oil sweat out of the block during welding and compromise the weld?
Old Apr 2, 2010 | 07:43 PM
  #70
GAMERMODZoCOM's Avatar
GAMERMODZoCOM
If I remember correctly, the coolant contamination made it difficult to do this and took the welder quite a bit of time.
Old May 12, 2010 | 11:20 PM
  #71
sradenton's Avatar
sradenton
BUMP for updates
Old May 29, 2010 | 07:59 PM
  #72
Andrei's Avatar
Andrei
Updates?
Old Jun 12, 2010 | 03:26 PM
  #73
midz350's Avatar
midz350
Dyno #'s?
Old Jun 12, 2010 | 07:55 PM
  #74
johnwigs's Avatar
johnwigs
why did you use rev-up cooling system that passes coolant to the heads at the rear cylinders instead of the HR that passes coolant to the exhaust valves??? are you planning blowing the headgaskets out the rear of the engine??? just an observation... and the VR38 deck does have holes to alow coolant to the heads through the gaskts... oil cools the combustion chambers coolant is around the cylinders for quick warmup for emissions... I think that is all of my 2 cents...
Old Jun 14, 2010 | 11:46 AM
  #75
350z-900whp's Avatar
350z-900whp
has anyone looked into this or have more info about it GTM close deck block. i would like to hear from SAM him self about this block and what kind of temp it gives
http://www.gtmotorsports.com/product...cat=473&page=1
Old Jun 14, 2010 | 12:00 PM
  #76
str8dum1's Avatar
str8dum1
thats the block they made for TTG35forT. Its sittin at Japtrix right now awaiting install, so Sam has no idea about the temps as it was his 1st motor out of the shop.
Old Jun 14, 2010 | 01:02 PM
  #77
ttg35fort's Avatar
ttg35fort
Professional
This thread was the inspiration for me to get my short block flat-decked. Thank you Jasonvs2146!!! Prior to this thread, I didn't even know it could be done to the VQ35DE block.
I spoke with Japtrix today, we are scheduled to get started on Sunday.
Old Sep 20, 2010 | 03:21 PM
  #78
Jasonvs2146
John at Japtrix is a Awesome guy!
350Z_Al
Oct 29, 2020 07:44 PM
Tochigi_236
Sep 27, 2015 03:40 PM
