Z33Art V2.0 Custom Single Turbo
Old Jul 13, 2009 | 11:11 AM
str8dum1's Avatar
str8dum1
they are pulling 921/641 at 48 psi with that turbo on a 2L EVO. 700 on a 3.5 will be a joke.
Old Jul 13, 2009 | 11:37 AM
plumpzz's Avatar
plumpzz
Do you have equal length exhaust manifolds? Beautiful setup by the way.
Old Jul 13, 2009 | 11:40 AM
Quamen's Avatar
Quamen
No. I made a compromise between log style and equal length. I have individual primaries that run into a very nice Cone Engineering Merge Collector. I also have bullet dividers to help counteract the unequal length problems by improving the laminar flow and merging of the exhaust gases entering the collector.
Old Jul 13, 2009 | 11:48 AM
QuadCam's Avatar
QuadCam
I love it! Huge props on not going the "kit" route.
I have been thinking/planning a similar build to what you have done. my first step is too sell my Greddy kit and buy the Tig welder I really want.....but that is a topic for another day.
You have done a really nice job on this setup. This makes alot more sense than the blower setup you had. That was nice, but not really necessary for the power you were lookign for. This setup, on the other hand, will allow you to take you car to new HUGE levels!!! Again, congrats on some great work!!!
Old Jul 13, 2009 | 11:51 AM
GreenGoblin's Avatar
GreenGoblin
I love the setup looks killer...
Old Jul 13, 2009 | 12:33 PM
IslandZavage's Avatar
IslandZavage
props... looks good
Old Jul 13, 2009 | 01:22 PM
Quamen's Avatar
Quamen
Thank you for the compliments. I have been working day and night to get this thing done right. The only thing left is to powder coat the last couple parts like the coolant catch can and the passenger side coolant pipe.
Then I have to clean the car and get some high quality pictures of it to post along with some numbers!
Old Jul 13, 2009 | 01:35 PM
BoostedProbe's Avatar
BoostedProbe
That is an awesome build, very creative. It was probably more work moving all the crap out of the way than the actual turbo related build.
It is nice to see things like this. Most of the threads here titled "My build..." start with a parts list and end with: "I will be picking the car up from ........shop in a month".
Did you have any in progress pictures? I would love to see some more detailed pics.
Great work.
Old Jul 13, 2009 | 01:51 PM
Quamen's Avatar
Quamen
Great work.
The link in my signature has more pictures which I didn't post.
It really wasn't too bad for me to move everything because if you look at the progression of the three builds, I remove a couple things each time. You get to a point where it doesn't really matter what has to move, you'll do it. I just like working on my car, hence why I have 8668 miles on the odometer
Old Jul 15, 2009 | 07:23 PM
Quamen's Avatar
Quamen
I was able to get out today with the car a bit and drive it. Still getting the air bubbles out of the cooling system which is always a pain. I managed to get a couple decent pulls in at only 25% throttle and it felt really good. You can really hear the turbo spool through this exhaust! Hoping to get some decent miles in on the motor this weekend and get some more tuning done. Still have some rough idle problems.
I have not been able to successfully do the idle air volume learning on my car for some reason. I can not seem to get the MIL to blink since it is always on when the key is in the ON position. Does anyone have some tips or insight as to what I may be doing wrong?
Old Jul 15, 2009 | 07:56 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
Did you set the clock next to you? It's good to watch clock during process. Btw, how i missed this thread...Awsome man
Old Jul 15, 2009 | 08:30 PM
boostedmaxima's Avatar
boostedmaxima
Very nice, looking forward to dyno results and videos!!!
Old Jul 16, 2009 | 06:11 AM
str8dum1's Avatar
str8dum1
that reset is the same steps as the generic ECM reset. Just unplug the battery. should do same thing.
other wise you know the step
key on
wait 5s
pump gas 5 times quickly
wait 10s
hold gas pedal down til the CEL light starts to blink (i find that is often more than 10s)
are you reflashed? The UTEC will have a hard time getting that minimum pulse right for a smooth idle. Well thats assuming you have at least 800cc injectors.
Old Jul 16, 2009 | 04:24 PM
Quamen's Avatar
Quamen
key on
wait 5s
wait 10s
I have 650cc injectors. No reflash on top of the UTEC. I freaking hate the UTEC.
Old Jul 16, 2009 | 06:14 PM
str8dum1's Avatar
str8dum1
ahh, then it shouldnt have a problem with idling. Whats your base fuel pressure?
I figured with such a big turbo you'd have a correspondingly big fuel system.
Old Jul 16, 2009 | 06:21 PM
Quamen's Avatar
Quamen
I wouldn't be using the UTEC then now would I
That is this winter that I will be upgrading the entire fuel system and ECU for much more than the 500whp that it is capable of now.
Base fuel pressure is at 52psi right now.
Old Jul 16, 2009 | 06:42 PM
IIQuickSilverII's Avatar
IIQuickSilverII
sweet...then time to turn up the boost!!
i always keep up with your project(s)
Old Jul 16, 2009 | 08:14 PM
  #38
Chef-J's Avatar
Chef-J
Booooosstt!!
damm man, could you post up some video when you get a chance?...i really want to hear sounds.
Old Jul 16, 2009 | 09:12 PM
  #39
Vas@Extended's Avatar
Vas@Extended
Vendor - Former Vendor
Damn ryan, I didnt even know about this thread... that thing looks intense!!! cant wait for high boost!
Old Jul 17, 2009 | 03:56 AM
  #40
Quamen's Avatar
Quamen
I will have videos soon. I have to check some stuff. I'm am going to look at the plugs and see how they are. I am also considering that the crank angle, MAF or the throttle body could have been damaged since all my research has shown these three area to be problematic.
Hopefully this weekend I can get it running good and take some video. I only hit 2psi so far and it seems like it is going to be fast. As soon as I get into the 10% column though it is falling on its face in speed density mode. Not sure why. I think I may be running to rich but my wideband doesn't seem to show anything. I am going to data log it this weekend since I think the wideband gauge may not be displaying it before it stumbles.
