Have a water/meth kit? Come in here...
Old Sep 4, 2009 | 08:42 PM
  #81
rcdash's Avatar
rcdash
Hey Terry, thanks so much for digging that out. I've read this one before (probably the last time you posted it!!! lol!) and I just did a quick re-review. I think you need to separate the concepts of knock vs. knock-limited performance. I'll read it again in the morning in depth, but I still think that for preventing knock, water cannot be beat because the higher latent heat of vaporization is so much higher. Of course if you switch to measuring maximal (knock-limited) performance, then methanol has the advantage since it's a power adder (because it burns whereas water does not). So you can obtain optimum power with a mix of W/M versus water alone. Take another one of my extreme examples for argument's sake: dump tons of water (short of hydrolock of course) into a motor. How difficult do you think it would be to get temps up hot enough to cause knock? Pretty tough regardless of boost. Now your performance would be terrible, but the threshold for knock would be outrageously high. Do the same thing with pure methanol? Methanol burns, generates heat, and although it has higher octane than pump gas, it will eventually reach it's knock threshold (and make a lot of power doing so!). I'm not really presenting an argument, only a clarification. Knock-limited performance is admittedly the more relevant parameter.
This is a nice article though. If only 30/70 W/M wasn't so flammable...
Old Sep 4, 2009 | 09:42 PM
  #82
ttg35fort's Avatar
ttg35fort
Professional
Hi Raj,
A couple quick comments in response to the above post.
I'm not quite sure what you mean here. There is only one concept discussed, and that is knock-limited performance. My interpretation is that "knock-limited performance" is a level of performance achieved in which the knock was limited to a particular level. Perhaps an acceptable level?
If you have any other interpretation, please share it.
... but I still think that for preventing knock, water cannot be beat because the higher latent heat of vaporization is so much higher.
The latent heat of vaporization for water is approximately 2257 kJ/liter. For methanol it is 874 kJ/liter. (Although the value for methanol is higher than water on a kJ/mol basis, water has nearly triple the number of molecules per unit of volume).
Based on the latent heat of vaporization values, one would expect straight water to perform significantly better than a meth-water mix. Indeed, had I never read this report, I would probably also beleive that pure water would be the best liquid to inject.
However, I have the benefit of having reviewed the report, and my opinion is based on the data contained therein. As the data in the report clearly indicates, there is more at work here than just the absorption of energy during the state change from liquid to gas.
Here is item #1 from the summary of the results:
"1. In all cases the use of methyl alcohol - water, monomethylamine-water, and dimethylamine-water mixtures as internal coolants raised the knock-limited performance of AN-F-28 fuel more than did water alone." They could not have stated this any more clearly.
Once you get a chance to review the full report, you'll get a better feel for the data.
One side note. At one point Japtrix did some dyno testing on a car where they injected water, meth-water and straight meth. I was told that the car acheived the highest level of hp using straight meth. I have heard others in the forum indicate the same thing. This seems to correlate with an extrapolation of the data in the NACA report.
As you said, methanol is flamable, but so is gasoline. I would just treat it with respect and not get careless with it. Also, make sure you have a good tank or fuel cell to keep it from spilling into your trunk.
I think it would be great if someone made a methanol tank that fits in the spare tire compartment!!! If anybody knows of one, please post the information here.
Old Sep 5, 2009 | 04:54 AM
  #83
Cass007's Avatar
Cass007
Terry - how can you think that clearly at quarter till 2 in the morning
I'm going for more coffee right now so I can try and follow along.
Old Sep 5, 2009 | 08:01 AM
  #84
ttg35fort's Avatar
ttg35fort
Professional
I'm a night owl. I really start to get going after about 6:00 P.M.
Old Sep 5, 2009 | 09:29 AM
  #85
rcdash's Avatar
rcdash
Originally Posted by ttg35fort
Hi Raj,
Well, it's an academic point and as I stated earlier, I agree both you and the article are addressing the more relevant parameter. However if you want to consider another perspective, think about a study of boost vs. knock. That is the highest boost you could run at a fixed concentration of water, w/m or meth injection before knock occurs. Which do you think would allow the highest level of boost? I understand that this is a significant departure from how the study was conducted in that article but it more specifically targets the ability to prevent knock vs maximizing power. The reason methanol makes the most power is because it burns.
There really is no best, just different properties that for different setups may be more or less beneficial. That's why I was starting to consider how different setups may benefit from different concentrations of W/M (e.g. different manifolds, turbines, compression ratio, EGT, AIT, etc).
Agreed. Just a cavaet that they are dealing with a very different setup and knock limited performance has many more variables to it than just the injected fuel/liquid. Our platforms are considerably different. It doesn't invalidate the data but it should preclude one from making an assumption that just because 30/70 was the optimum ratio for that study means that its the optimum for any individual VQ build.
Sharif has confirmed this in discussion as well. 100% methanol makes the most power. Of course, it's a fuel, so not unexpected that the more (higher octane) fuel you put in, the more power the car will be able to make.
Old Sep 5, 2009 | 09:55 AM
  #86
ttg35fort's Avatar
ttg35fort
Professional
I think we have hammered this one enough.
I am anxious to see your data when you play around with it.
Once I have my car back together (Sam, how's my short block coming?), I'll get data both with straight 93 octane and then with 93 octane and meth injection.
Old Sep 5, 2009 | 10:45 AM
  #87
Cass007's Avatar
Cass007
I can add something here. Since the ViPEC can switch maps instantly and is wired to recognise when the meth is activated Dave was able to tune by keeping all other settings the same just meth on/off. When the meth is on I saw an instant ~50whp DD gain at appx 18lbs of boost with 93oct.
Old Sep 5, 2009 | 07:35 PM
  #88
Sylvan Lake V35's Avatar
Sylvan Lake V35
So 50whp with no boost or timing increase. Thats impressive.
Old Sep 5, 2009 | 10:23 PM
  #89
350Z400rwhp's Avatar
350Z400rwhp
100% or 50/50 Meth? I gained 20whp but I'm at a lower boost level and supercharged. I used a 50/50 mix
Old Sep 6, 2009 | 03:37 AM
  #90
ttg35fort's Avatar
ttg35fort
Professional
Very nice!
Old Sep 6, 2009 | 07:44 AM
  #91
frankie945's Avatar
frankie945
Here is my old procharger setup 93 octane @7-8psi.
You can see the gains. Was using a 50/50 mix and had the timing advanced with the meth. I don't see how anyone is getting more hp without advancing the timing a little.
[IMG][/IMG]
Old Sep 6, 2009 | 08:23 AM
  #92
ttg35fort's Avatar
ttg35fort
Professional
It also allows you to run more boost for a particular timing.
Old Sep 6, 2009 | 09:14 AM
  #93
rcdash's Avatar
rcdash
Definitely will post up findings however it turns out. Hope you get your block back soon!
Old Sep 6, 2009 | 09:18 AM
  #94
ttg35fort's Avatar
ttg35fort
Professional
Me too!
Old Sep 6, 2009 | 09:25 AM
  #95
ttg35fort's Avatar
ttg35fort
Professional
FYI, the boost pressures obtained using the various liquids is shown at the top of Figure 5(d).
In that test, water allowed about 20% more boost in the AFR range applicable to us. A 70/30 meth-water mixture allowed about 50% more boost.
Those gains are pretty significant.
Old Oct 9, 2009 | 10:25 PM
  #96
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Thumbs up
Originally Posted by tony_t
anyone use the AEM kit? or comments on it? I have one sitting in my closet I have been meaning to install
I'm gonna be using the AEM kit. It's a progressive system that was highly recommended to me by Larry at Sound Performance due to it's recirculation style pump.
Here is a vid showing how the AEM recirculation style pump differs from the switch style pump that many of the other kits use. The head tech at Intense showed me this vid today. I was impressed.
<EMBED height=344 type=application/x-shockwave-flash width=425 src=http://www.youtube.com/v/XNIjps6bwqs&color1=0xb1b1b1&color2=0xcfcfcf&hl=en&feature=pl ayer_embedded&fs=1 allowScriptAccess="always" allowfullscreen="true">
Old Oct 10, 2009 | 02:18 AM
  #97
ttg35fort's Avatar
ttg35fort
Professional
Good information.
Coolingmist also has changed their pumps to the re-circuation type. In fact, I bought the new pump a few months back, and hence have the old pump available for sale if anybody is interested.
Old Oct 10, 2009 | 06:22 AM
  #98
Cass007's Avatar
Cass007
Great info Rude. Any idea on the cost of the AEM pump? I assume the meth line fittings are standard.
Old Oct 10, 2009 | 08:44 AM
  #99
rcdash's Avatar
rcdash
I have an aquamist pump which appears to be a shurflo 160 psi "bypass" pump. I wonder if that's the same thing? There is a separate electronically controlled flow control valve with the aquamist setup and the pump wiring seems to consist simply of a relay connection to the battery (always on I presume). My set up is not ready to turn it on yet to test... Sam, George, can you put this in perspective for your aquamist customers?
If you currently have a system that pulse width modulates your existing pump, I don't think you can just pop this in, can you? How do you regulate flow otherwise?
EDIT: Never mind - apparently Aquamist has been using these types of pumps for some time now. This is directly from an Aquamist rep post on another forum:
The water pump is normally at idle. It turns fully when the triggering point is reached.
Inside the pump head, there are three by-pass valves. As soon as the preset pressure is reached, the valve opens and allows the water to recirculate internally. This process maintains the water pressure steadily at around 125psi.
Water injection flow is controller by an inline PWM valve. The whole set up is almost identical to the fuel injection system.
Old Oct 10, 2009 | 12:01 PM
  #100
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Not necessarily. My AlkyControl fittings are much larger than the fittings I've seen on some other kits.
