GTM turbo kit feedback thread
Old Mar 25, 2011 | 01:04 PM
  #181
ace32x's Avatar
ace32x
had some fitment issues with the intercooler on my HR kit and a few missing fittings and no uprev cable, but good other than that
Old Jun 22, 2011 | 10:20 PM
  #182
Jtran Studios's Avatar
Jtran Studios
Vendor - Former Vendor
We just installed a gtm stage 3 kit on a customers revup 350z. Its common sense to drop the motor to install the kit or it will be a pain to install. Rrgardless of the negative feedback in this thread, the knstall went flawless. No issues here. we will be pushin gtms parts til sam gives us a reason not to. Regardless the kit made 379 whp on a break in tune on 9psi on our low reading mustang dyno, built bottom end with gtm stage 2 cams and a bunch of other goodies. a 750 whp vette did 650 on our dyno. A stage 2turbo kit on a 370 made 389 whp on our dyno also. Sam, hit me up tomorrow and lmk when the exhaust is leaving.
Johnny Tran
Jtran Studios
Old Nov 3, 2011 | 11:02 PM
  #183
Yohann's Avatar
Yohann
Default GTM
Hi, I have just managed to read through this entire thread in one sitting....
While have read quite a bit on missing parts, fitting issues and delays getting the tune back, I am still very seriously considering the stage 2 kit.
I do believe that any tech challenge that comes up will be sorted by GTM. MIke has been super helpful so far.
I am after actual driving impressions, reviews of any kind from anyone who has fitted and run stage 1 or 2 kits.
Can anyone please help?
It's a lot of dough for me and I want to make sure I am making the right choice.
Thanks very much guys
Yohann
Old Nov 4, 2011 | 04:10 AM
  #184
Cass007's Avatar
Cass007
As with any TT kit you choose, the car will feel VERY much faster and more fun. All kits are limited by the strength of the stock rods, so they all make similar whp and will have somewhat similar dyno curves. Bigger turbos come on later vs smaller turbos that max out earlier and so on...
Old Jan 17, 2012 | 07:53 AM
  #185
Yohann's Avatar
Yohann
Thanks very much! Sincerely appreciate the advise and help. I ordered the stage 1 kit + clutch. Any one who has this on a DE care to share any wisdom /advise ?
Is there really an issue where these turbos run out of breath ? Seems hard to believe,
Thanks again for all the support received from members. You know who you are.
Old Jan 17, 2012 | 12:29 PM
  #186
kelly350Z's Avatar
kelly350Z
^ good question. I know the stage 1 kit is rated to make up to 500whp, but i would also like to see what people are making with this kit on a built engine.
Old Jan 17, 2012 | 06:50 PM
  #187
midz350's Avatar
midz350
The only bad thing that I noticed about GTM kits is the exhaust manifolds. They tend to break easily.
Old Jan 18, 2012 | 03:55 AM
  #188
Yohann's Avatar
Yohann
Exactly ! I am planning on building my engine after using the kit for about a year. Would love to know what we can expect from the stage 1 kit and built engine.
Does anyone know the boost at which these turbos are the most efficient? (GTM ST1)
Also does anyone have a 0-60 or 1/4 time on this kit with stock boost?
Thanks again for taking the time to read and respond. The main reason I am actually going ahead with this project is due to the confidence given by members.
Yohann
Old Feb 11, 2012 | 02:03 AM
  #189
Yohann's Avatar
Yohann
anyone?
Old Feb 11, 2012 | 09:34 AM
  #190
dikspiel's Avatar
dikspiel
Chestons Toilet
If you planning on building the motor go with stage 2
Old Feb 14, 2012 | 06:33 AM
  #191
Vq35hr350z's Avatar
Vq35hr350z
i plan on buying the stage 3 turbo kit, but do not plan on building the motor, would it be bad to run stage 3 on a stock motor?
Old Feb 14, 2012 | 07:03 AM
  #192
midz350's Avatar
midz350
Yes.
Old Feb 14, 2012 | 07:10 AM
  #193
Vq35hr350z's Avatar
Vq35hr350z
okay thank you, i just wanted big turbos so it could sound and spool louder, i was only planning on trying to get 475whp on a stage 3
Old Feb 14, 2012 | 07:43 AM
  #194
ace32x's Avatar
ace32x
Old Feb 14, 2012 | 07:52 AM
  #195
dikspiel's Avatar
dikspiel
Chestons Toilet
Definitely go for stage 4 and don't run an exhaust past the headers
Old Feb 14, 2012 | 08:50 AM
  #196
str8dum1's Avatar
str8dum1
no reason not to get stage6. you will make 475whp at a much lower boost with alot more sound from the wastegates and turbines
Old Feb 14, 2012 | 09:08 AM
  #197
Sylvan Lake V35's Avatar
Sylvan Lake V35
Just run dumps right off the down pipes you can hear the turbos whistle and it sounds like chaos when your on the throttle.
http://s677.photobucket.com/albums/v...t=MVI_1510.mp4
Old Feb 18, 2012 | 01:20 AM
  #198
fla350tt's Avatar
fla350tt
I have a stage 2 with open waste gates and puts down 500 whp at 12 psi. the kit is capable of running up to 16 psi with the springs that come in the wastegates.12 psi is max recommened by Sam for stock block. go ahead and get the boost controller with it, I only run 8 psi in 1st & 2nd(due to tire spin) and up it too 12 for 3rd-6th.
Old Feb 18, 2012 | 07:54 AM
  #199
f150intally's Avatar
f150intally
How do you vary the boost by gear? Do you have a stand alone?
Old Feb 18, 2012 | 09:23 AM
  #200
MDK's Avatar
MDK
Why I was choosing a block I called GTM and after discussing my build with Sam we decided on the stage 0 shortblock for my car. With the gt28rs turbos my car put down 537hp on 93 octane. Plenty of power and I'm real happy with it.
Keep in mind if you're going much over 600whp you're going to need to sleeve the block which adds substantial cost to the build, and that wasn't worth it to me with my goal of having fun daily driver that sees occasional track use.
