piston to cylinder clearance
Old Aug 7, 2009 | 09:38 AM
  #41
SmallTuner's Avatar
SmallTuner
Originally Posted by rcdash
i don't think his builtZmotor was ever any good. not his fault though...
yeah
its realy ****.
that time every body told me to go to builtzmotors.
Old Aug 7, 2009 | 10:44 AM
  #42
go-fast's Avatar
go-fast
Originally Posted by Z1 Performance
What can snap the cam? As mentioned - a cam that wasn't made correctly (very unlikely if it's from a reputable source), improper torquing sequence on the caps as westpak said, drastic change in oil pressure (in which case, I'd replace ALL the cams, not just the one that broke, or at the very least, have them magnafluxed to check for stress cracks)
you forgot valve to piston interference.
rumble in the desert.......i want vids when you guy's race (or fight).
  #43
350z-Dude's Avatar
350z-Dude
Originally Posted by str8dum1
only 470 hp on a built motor Greddy kit? thats not very good to begin with..
But sounds like the new build is underway! Those huge turbos you have should easily pop off 900 hp at some high boost!
good luck
Nope, it wasn't a built motor my friend, it was pistons and con. rods only, i think it had CJM fuel system, but i can't remember, the built engine came later and put 570rwhp before he felt some problems happening and he had to take out his engine and check it, as for the cam it was cracked but not broken, he broke it after taking it out from the heads.
I saw his con. rods and pistons and the whole block, it's pretty damn clean and i thought everything is new, but as he said, there is no problem with the engine, just took it out and found a surprise inside, thank god he did it, otherwise he would've end up with blown up engine.
Can't wait for next week for the piston rings, i'll help you there, i need my dremel .
Old Aug 7, 2009 | 10:48 AM
  #44
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
true - didn't even think to mention the most obvious, especially given the first post
Old Aug 7, 2009 | 11:09 AM
  #45
ttg35fort's Avatar
ttg35fort
Professional
Originally Posted by Clint@Altered
We've done Darton sleeves on Nissans, Hondas, domestics - even scions - all without issue. All comes down to equipment and proper installation/machining.
I know a lot of people are wary of darton sleeves, but they work great if done correctly. For street or race applications.
Small tuner - If you plan on resleeving, I suggest getting a new shortblock to sleeve.
I have heard about overheating issues when using Darton sleeved VQ motors for road racing. What do you do to eliminate that issue?
Old Aug 7, 2009 | 11:17 AM
  #46
Z1 Performance
Former Sponsor
install the sleeves properly, install the headgaskets/studs/bolts properly, and reinforce the cooling system with the proper supporting mods (fans that flow more cfm than stock in a well thought out shroud), radiator with more capacity vs stock, coating the exhaust manifolds/turbo's to keep heat inside, periodically inspecting the water pump and coolant system for signs of leaks, corrossion, etc
some also take it a step further and run distilled water, evans coolant, etc. I've never had the need to use that stuff in our track cars here (BMW, not Z's) - but certainly can't hurt. It should not need that sort of stuff to work efficiently, but it certainly can help the overall cause
Old Aug 7, 2009 | 11:18 AM
  #47
Z1 Performance
Former Sponsor
a built motor consists or, primarly, aftermarket pistons and rods.
Old Aug 7, 2009 | 05:22 PM
  #48
SmallTuner's Avatar
SmallTuner
guys that was back in 2004 when i had my greddy setup
here is my pistons and rods after i took it out.
just a proof for that cool_z33 gay that i dont have a blow motor
ya 7mar
Cool_z33
Attached Thumbnails piston to cylinder clearance-dsc00580.jpg   piston to cylinder clearance-dsc00583.jpg   piston to cylinder clearance-dsc00574.jpg   piston to cylinder clearance-dsc00581.jpg
Old Aug 7, 2009 | 05:27 PM
  #49
SmallTuner's Avatar
SmallTuner
so now lets stop this and u guys wish me good luck on the dyno
Old Aug 7, 2009 | 05:37 PM
  #50
SmallTuner's Avatar
SmallTuner
i a sure u that this guy has a JWT popcharge mod only, or mabye he still thinking about how to pay shiping cost to get it
Old Aug 8, 2009 | 02:18 AM
  #51
350z-Dude's Avatar
350z-Dude
When someone say built motor i think of block, crank, pistons and rods all balanced together, never thought of pistons and rods as built motor .
Cool_z33 didn't reply yet, i wonder if he's dead of jealousy or maybe he's thinking of what to say but can't find the words, i'm dying to see his reply, and btw he's not who you think he is, i'll give you a call l8tr bude.
Old Aug 8, 2009 | 03:06 AM
  #52
*Boose*'s Avatar
*Boose*
I know some people in the z32 world do it. Fix the weak link but overall only pick up a few hp.
Anyway wheres that dyno sheet with superb af tuning? Also if my reading is accurate GTM built and sent you the last motor?
Old Aug 8, 2009 | 03:49 AM
  #53
Z1 Performance
Former Sponsor
If you don't consider aftermarket pistons and rods to be a built motor, then I guess we don't have much else to discuss. Those are the primary components that make up a built motor, as 99.9% of people are using the stock block (there might be someone out there using something custom) and 99% using the stock crank. Any person building a motor surely is balancing the crank, pistons and rods before they install them. If they aren't, they should step away from the toolbox.
OP - good luck, hopefully you have better luck and are back on the road soon
Old Aug 8, 2009 | 12:05 PM
  #54
350z-Dude's Avatar
350z-Dude
I understand and i know that.
Old Aug 8, 2009 | 12:56 PM
  #55
cool z33's Avatar
cool z33
Default wating ur replay
first off all KUWAIT is so small so i donot see u in street since 2004 loool
u tune for gays in qatar ???? uae ??? ksa ??? do u really think thay need u to tune for them ??? do u think thay leave thim shops and tuners and teel u in kuwait to tune for them ?????
1 u donot have shop u tune since 4 days looool
2 ur car with pistons-cams-ds-big tt kit ........many things u just 480whp !!!!
3 u make OMRAN car and it broken 2 times ( i know that )
4 do u think ur not adonky cose u bay les than 272 cams for huge hp ????
at last i hope u tune my a$$ i want to fly
tell ur boyfriend to kiss my a$$ if u tune it will
Old Aug 8, 2009 | 01:24 PM
  #56
SmallTuner's Avatar
SmallTuner
ur Grammer sucks
ok i have nothing Bravo
keep it up
ur so jealous eheheh
Old Aug 8, 2009 | 01:44 PM
  #57
350z-Dude's Avatar
350z-Dude
Originally Posted by SmallTuner
ur Grammer sucks
keep it up
LOL +1.
Why whenever someone install pistons/rods people go and say he broke his engine??
I'm not Omran btw, and his car is putting pretty good number, i hope SmallTuner upload his dyno runs sheet, also why would you attack him for no reason, your just jealous, so beat it.
And as a proof that you know nothing about cars, he doesn't need 272 cams for that horse power, people are doing it with 262 or 264 cams all the time, but your a noob that thinks bigger is better, sheesh you do not understand the difference between turbo and supercharger.
And btw, if he tuned your @$$ you'll be shitting all over the place .
Old Aug 8, 2009 | 01:55 PM
  #58
cool z33's Avatar
cool z33
LOL +1.
yah shitting in ur face so ur his boyfriend
i think u will say that couse u cannot replay me so u make joke
couse u and ur boyfriend are joke
Old Aug 8, 2009 | 02:02 PM
  #59
SmallTuner's Avatar
SmallTuner
LOL +1.
he dont understand the Difference between **** and shampo
Old Aug 8, 2009 | 02:09 PM
  #60
350z-Dude's Avatar
350z-Dude
Lol, i'm too old to reply to you, please go learn english and come back here.
You'll get banned for attacking forum members, go read the rules, you are a funny person indeed .
