Preferred MAF Sensor Location w/Turbo - Before or After Turbo?
Old Aug 6, 2009 | 06:23 PM
mx594's Avatar
mx594
Default Preferred MAF Sensor Location w/Turbo - Before or After Turbo?
I am doing a custom turbo system for my 03 G. I am using an HKS turbo setup kit and the majority of a JWT intercooler system. The one thing I dont have is intake piping, which I am going to fabricate. I noticed that JWT puts the MAF sensor on the intake side of the turbo, while the GReddy kit places it after the turbos. Personally, I like the GReddy style, since it will account for temperature variations caused by the turbos/ intercoolers. Plus, the GReddy style will allow me to use dual air filters.
Can anyone shine some light on this subject?
Oh yeah and I am using a UTEC and DW 600s.
Old Aug 6, 2009 | 06:30 PM
failsafe306's Avatar
failsafe306
Most kits I've seen for the VQ place the MAF sensor after the turbo(s).
Old Aug 6, 2009 | 08:02 PM
rcdash's Avatar
rcdash
I think you can do either. I had the pull through MAF on my JWT kit and I changed it to blow through (so I could get dual CAIs). There are benefits to pull through (like you won't ever be blowing oil onto the MAF sensor, which you can do if turbo seals start leak, and all leak a little).
Old Aug 6, 2009 | 11:21 PM
ACI318's Avatar
ACI318
Preferred location would be in the trash can. Buy a Haltech or Fcon and dont use it at all. I know it cost more, but it is worth it.
Old Aug 7, 2009 | 12:44 AM
zads's Avatar
zads
I like blow through because if you develop a major or minor leak in your system before your MAF you can still drive it around (albeit at loss of power),
but if you develop a leak after the MAF then it will barely run (if at all), or run very poorly.
With blow through there's much less leak potential after the MAF.
With suck/pull through, there's tons of leakage points.
You can run also run an atmosphere vented/open BOV easily (although I don't like them), without making weird ECU corrections for the 'lost air'.
Old Aug 7, 2009 | 04:33 AM
mx594's Avatar
mx594
I don't want to hear the "get an Fcon or Haltech" rant. Save it for another thread. It's not an option for me. You can't even tune an Fcon yourself can you?
Sounds like I will be going with a blow through MAF. It would sure make things easier. RC - do you have any pictures of your dual CAI setup with the JWT?
Old Aug 7, 2009 | 05:28 AM
failsafe306
Old Aug 7, 2009 | 05:53 AM
rcdash's Avatar
rcdash
Pics are in my build thread - link in sig. I run a Haltech and keep the MAF anyway because:
(a) I have to as the automatic trans (TCM) REQUIRES it as it needs the calculated load parameter that the stock ECU sends to it and the stock ECU derives that from the MAF.
(b) it prevents the CELs related to the MAF.
Alberto's Avatar
Alberto
Cranky FI Owner
LOL-I was gonna say the same thing. MAP sensor would be appropriate...
Old Aug 7, 2009 | 07:44 AM
mx594's Avatar
mx594
I will have the UTEC MAP sensor hooked up of course...don't get me wrong, I am not going to try to use the MAF sensor for boost!
Old Aug 7, 2009 | 09:41 AM
ttg35fort's Avatar
ttg35fort
Professional
On my setup we elimiated the MAF sensor. We used the F-Con to feed a dummy voltage back into the ECU to keep the check engine light from illuminating. I'm not sure if you can do this with the UTEC, though.
If you do eliminate the MAF sensor, don't throw it away. They are expensive and you may be able to sell it.
Old Aug 7, 2009 | 12:43 PM
phunk's Avatar
phunk
CJ Motorsports
MAF is more accurate and consistent and I would prefer to run it when its an option, which depends on power level etc. I also prefer to run it before turbo... and having the car run weird if you get an intake leak is an advantage rather than a disadvantage IMHO... i would rather myself or a customer know there is a leak so that it can be fixed immediately.
Old Aug 7, 2009 | 01:41 PM
ttg35fort's Avatar
ttg35fort
Professional
MAF definitely is more accurate and consistent. Will version 3.3 of the F-CON work exclusively with a MAF sensor in lieu of a MAP sensor?
If you put the MAF sensor before the turbo, the sensor readings would not be accurate during shifts (assuming you use a BOV). I wonder if this would create any issues.
Old Aug 7, 2009 | 05:00 PM
phunk's Avatar
phunk
CJ Motorsports
the fcon has preset calibrations for factory airflow meters.. i never looked to see if you could set it up for a custom one... but since the sensor output will be a 0-5v im sure it wouldnt really matter. the fcon can also support dual MAF inputs since it has a PnP application for the RB26 GTR. I actually picked up another Z33 MAF sensor a couple years ago with intentions on running twin stock MAFs... never got around to it
Old Aug 7, 2009 | 09:18 PM
ttg35fort's Avatar
ttg35fort
Professional
I found this:
http://www.350zmod.com/ProductDetail...HPX+VQ35DEMMAF
The description says that it is capable of supporting over 1000WHP. So, I'm wondering if I can use this in my new build and have my F-CON V Pro tuned around mass air flow rather than MAP/RPM.
Has anybody played with tuning the F-CON using MAF instead of MAP/RPM on a high hp build (GTM 4.0L stroker with a GTM stage 3 TT setup)? If so, please post your experiences.
Old Aug 8, 2009 | 08:12 AM
tig488's Avatar
tig488
on other cars, ive had much more success using a blow thru maf setup. pull thru had idle and off throttle issues.
Old Aug 8, 2009 | 11:35 AM
phunk's Avatar
phunk
CJ Motorsports
that is true... i was actually under the misconception for a very long time that MAF readings were not entirely correct when blow-thru... which turns out I was wrong according to sources i have spoken with more recently... and I guess I am still just used to thinking that way.
Old Aug 8, 2009 | 10:56 PM
mx594's Avatar
mx594
Well I will be doing it blow through then.
ttg35fort - I have never seen that MAF sensor before. It sounds like that might be the key to using the Orsiris for boost. I guess I need to do more research, the Orsiris is starting to look more attractive now. Is there any way to use that MAF with the UTEC, so that I dont have to use a MAP sensor at all?
Old Aug 9, 2009 | 09:14 AM
ttg35fort's Avatar
ttg35fort
Professional
I'm not sure. I have never played with the UTEC. But if the UTEC will accept air flow as an air input monitoring parameter, I don't see why not.
Yesterday I spoke with Roger (Japtrix) about using that MAF sensor with the F-Con. He thinks it might work, but is recommending against it at this time. As he puts it, let the manufacturer do some R & D builds to prove that it works well. Why risk my new motor ($$$$$) on a product that is yet unproven for the HP I will be running. Considering how much money I have at stake, I completely agree.
Now, if the manufacturer of the HPX MAF sensor wants to discuss sponsoring some R & D on a high HP build, I am open to discussions.
Old Aug 9, 2009 | 02:37 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
Originally Posted by ttg35fort
I found this:
5xx whp was highest number that i heard from jared( with that MAF sensor/osiris tuned) I'm sure SAM@GTM has better idea, since you have GTM stroker plus they have an experience tuned with that sensor/osiris also with Fcon.
