S/C Z
Old Aug 29, 2009 | 05:41 PM
RA11325's Avatar
RA11325
Originally Posted by sajazzman007
So let me get this right the bigger the crank pulley then what? I've heard of this from a guy who builds crank pulleys in Texas. I know it is suppose to help with belt wrap. What size is the ATI pulley?
The ATI pulley is supposed to help dampen torsional vibration. The slightly larger diameter would give you ever so slightly more belt traction as well as overdrive all of your accesories, including your supercharger so boost would increase slightly.
Old Aug 29, 2009 | 06:51 PM
DAWK254's Avatar
DAWK254
Originally Posted by Chef-J
Can I ask you to share your mods, power and boost? And plan?
Thanks
I have a stillen S/C with headers, test pipes, stillen 3" true duals, Injen CAI, AEM water/meth, custom 2.4" boost pulley, Haltech, ACT stage 2. Im at about 10lbs of boost.
Old Aug 29, 2009 | 06:58 PM
DAWK254's Avatar
DAWK254
ATI has three sizes for the Z, 6.325", 6.75" and 7.074"
Old Aug 29, 2009 | 10:33 PM
ReV2Red's Avatar
ReV2Red
I haz da turbos
Originally Posted by jonnylaw
+1. ATI is slightly OD and is what I use on my S/C setup.
So your running the ATI crank pulley and the GTM pulley? What sort of boost are you running?
Old Aug 30, 2009 | 09:11 AM
jonnylaw's Avatar
jonnylaw
yes ATI crank pulley and GTM sc pulley, 12-13 psi.
Old Aug 31, 2009 | 03:35 AM
halfass872's Avatar
halfass872
Hmmmmm......
According to Stillen (And Eaton), anything over 8PSI is just pumping super heated air at that point, and asking for issues because that size blower isn't ment to be spun much faster then the stage 4 pully spins it at. (Don't remember the exact RPMs off hand, but i remember stage 4 is dangerously close to maxing that little blower out).
Also i'm surprised to hear you are seeing 10PSI with headers and test pipes. The Roots style Stillen blower needs/uses the stock exhaust back pressure. Stillen will tell you all day long that adding headers and/or test pipes will significantly reduce power output.
So basically whatever you may be gaining by spinning the blower hard enough to get to "10 PSI", you are surely loosing with that exhaust setup and the gobs of super heated air coming out of the over worked blower. You're probably significantly running worse then a stage 4 setup on stock exhaust.
I know it sounds like i'm trying to call BS, and maybe to some small amout i am. But something just doesn't add up with why you'd dump all those extras onto a small blower that won't safely yield anything significantly extra for you over 8PSI! Go to Eaton's site, do the math, the numbers don't lie. They've been making blowers for a while now!
I'm curious what your track times are.
I love my Stillen, but i know it's limits too!
Old Aug 31, 2009 | 03:41 AM
ReV2Red's Avatar
ReV2Red
I haz da turbos
Holy ****! That would probably explain why your idler pulley snapped.
Old Aug 31, 2009 | 07:28 AM
DAWK254's Avatar
DAWK254
Originally Posted by halfass872
Hmmmmm......
I am not using the stillen piggy pack to run my setup, Im using the Haltech. Boost pressure is not everything as long as you have a good tune. I get mine tune for ever upgrade an seen increase in power every time. With a good tune you will get increase in power with your mods. There are ways to get way more power out of it than what stillen says!!
Old Aug 31, 2009 | 09:21 AM
jonnylaw's Avatar
jonnylaw
yea, it sees 12-13 psi on the dyno, but on the streets, I've only pushed her to 8-9 psi. This is with Cosworth plenum, nismo headers. PE HFC's, Tanabe y pipe, and Amuse R1 exhaust btw.
Old Aug 31, 2009 | 10:34 AM
halfass872's Avatar
halfass872
I can only imagine what your output air temps are at 10PSI! That's like strapping a space heater to your intake! lol
Old Aug 31, 2009 | 12:47 PM
DAWK254's Avatar
DAWK254
My temps are normal, water/meth injection makes a diffrence!
Old Aug 31, 2009 | 12:58 PM
DAWK254's Avatar
DAWK254
I know you think you know everything about this charger but Im sorry that you dont. I have had this thing since 06, and I have research and found out what works with the stillen S/C. I have no reason to LIE... This S/C does suck if you dont do any upgrades and keep it the way you bought it from stillen. I am still adding upgrades, I have three more mods that I can do and if they work I will be glad to let you know and If they dont I will be glade to let you know also. So far every up grade that I did adds power and with NO problems. Like I said I have no reason to put out bad INFO... PM me if you want to know how I did it.
Old Aug 31, 2009 | 01:07 PM
halfass872's Avatar
halfass872
Sweet! Dont' be a D'bag.
Old Sep 1, 2009 | 11:54 AM
str8dum1's Avatar
str8dum1
LOL ^^ look who is calling who a d'bag. your condescending posts stink royally of douchebaggery
Old Sep 3, 2009 | 05:51 PM
frankie945's Avatar
frankie945
Bump...Keep us updated on this. I know you have put a lot of hard work into that charger. I would like to see the final outcome. And come down to the valley and watch you run.
Old Sep 4, 2009 | 10:35 AM
DAWK254's Avatar
DAWK254
I will, I have an appointment with IP next week to get the pulley installed and tuned. I will let you know the out come..
Old Sep 17, 2009 | 09:08 AM
sajazzman007's Avatar
sajazzman007
DIY'er Unite
Whats the verdict? I spoke with someone at ATI about a dampner and he did not know what I was talking about. It would seem that you would need a overdrive pulley to make it work.
Old Sep 17, 2009 | 09:49 AM
  #38
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
We carry and stock the oversize ATI crank pulley, and installed one recently on DAWK's stillen supercharged 350Z. It did raise the boost and made more low end power, but the top end suffered - likely from spinning the supercharger out of it's efficiency range.
Old Sep 17, 2009 | 11:36 AM
  #39
str8dum1's Avatar
str8dum1
do u need a longer serp belt with that ATI pulley? or is there enough slack in the stock for the idler to pick up?
Old Sep 18, 2009 | 05:14 AM
  #40
Dynosty's Avatar
Dynosty
Longer belt is required.
