Oil pressure sending unit
Old Sep 2, 2009 | 10:51 AM
fklentz's Avatar
fklentz
Default Oil pressure sending unit
My oil pressure sending unit failed again, this is the second time since turbos were installed, anyone else having failures?
The OEM replacement is $90, is there one for a different model that works and is cheaper?
Old Sep 2, 2009 | 12:18 PM
spdtckts's Avatar
spdtckts
honestly you cant afford a 90$ part? with all your mods you think you wouldnt complain about a simple part.
Old Sep 2, 2009 | 12:45 PM
fklentz's Avatar
fklentz
Thank's for the feedback, anybody else?
Old Sep 2, 2009 | 01:29 PM
Chris@FsP's Avatar
Chris@FsP
Vendor - Former Vendor
Found one for $62.00 here. Maybe you could try one from a maxima or something; they're cheaper.
edit: guess it would have helped if I had posted the link (doh!). Let me see if I can find it again...sorry.
Old Sep 2, 2009 | 05:09 PM
fklentz's Avatar
fklentz
I bought one for an 04 Maxima, totally different and would not work. Maybe a Pathfinder unit. (EDIT) I found one for $76 shipped. Online I found a unit for a Pathfinder priced at $14 and another 67, I'm thinking that the cheap one is a switch for a light the other for pressure.
Old Sep 2, 2009 | 06:53 PM
rcdash's Avatar
rcdash
Some senders are resistance based, some voltage - with different wiring. I don't see how you can mix and match that way...
Old Sep 3, 2009 | 05:53 AM
djamps's Avatar
djamps
I wonder if you're overheating your oil? Strange that you go through senders like that.
Old Jun 27, 2011 | 02:48 PM
blackfairladyz's Avatar
blackfairladyz
my car is reading low psi at idle and while driving. I checked the oil, drained it and refilled it. and it still is doing the same thing, what did your guage do when it failed, i need to know if its my pump or my oil psi sending unit. Thanks
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
