Jay'Z Built Engine Health Diagnosis needed!! Engine Builders Opinions Pls!!
Old Sep 4, 2009 | 07:46 AM
Jay'Z's Avatar
Jay'Z
Default Jay'Z Built Engine Health Diagnosis needed!! Engine Builders Opinions Pls!!
I am noticing this noise become more prominent and not sure if its coming from the cam area.. Is this noise normal on a built engine? I would like Engine Builders opinions and Built engine owners opinions.. Id like to be reassured its healthy.. Its been about 30k miles, the car is running normal at 35-40psi oil pressure at idle, 170-190 water temp even on hot days, and 15psi high boost.
Vid of noise..
<embed width="448" height="361" type="application/x-shockwave-flash" wmode="transparent" src="http://s40.photobucket.com/player.swf?file=http://vid40.photobucket.com/albums/e218/jonb7777/Enginenoise002.flv"></embed>
Old Sep 4, 2009 | 07:51 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Hmm...sounds like a normal built motor. I do hear some piston slap or valvetrain type noises, but nothing really alarming.
This was an SGP motor, if I remember correctly, and so far it seems to be holding up well, making good power, good oil pressure, and low oil consumption. I wouldnt worry.
Old Sep 4, 2009 | 08:11 AM
thom000001's Avatar
thom000001
got noisy injectors like me too lol
tom
Old Sep 4, 2009 | 08:16 AM
Jtran Studios's Avatar
Jtran Studios
Vendor - Former Vendor
This was an G and G motor, if I remember correctly, and so far it seems to be holding up well, making good power, good oil pressure, and low oil consumption. I wouldnt worry.
fixed for ya sharif
Old Sep 4, 2009 | 08:23 AM
Jay'Z's Avatar
Jay'Z
Ok, thanks.. They didnt build the engine it was done at some shop in Houston, SGP just put it together, and I saw the heads etc were wrapped in plastic/ built from what I saw..
tom
They are RC 750cc.. Never could compare with anyone elses built engine so Im all alone in Missouri here with the FI/Built Z.. lol
Originally Posted by Overdrive/Jtran
fixed for ya sharif
I dont get it? What is G and G? If its a joke let me know so I can laugh.. I think the Built block itself was from a Nissan Pathfinder, thats what Sharif said if I remember correctly..
Old Sep 4, 2009 | 08:27 AM
Jtran Studios
g and g did all of there motors. assembly, balance, blueprint, setting cold lash, porting of heads, everything. all sgp did was bolt the head to the block and set the timing chains up. anyone that needs a good vq machine shop, go to them. joe is the owner, tell him jtran sent yall!
Old Sep 4, 2009 | 08:28 AM
thom000001's Avatar
thom000001
I have their 1000's......but still batch firing of them with the pro-efi 48 so with 3 firing at a time its noisy lol
tom
Old Sep 4, 2009 | 08:31 AM
Jay'Z's Avatar
Jay'Z
Thats exactly what I saw/thought...... I kinda knew SGP only put the new heads on, re installed engine etc.. I knew they didnt actually build it.. But they never told me that.. I just figured it out..
Old Sep 4, 2009 | 08:50 AM
Chris@FsP's Avatar
Chris@FsP
Hmm, yeah SGP led me to believe that they did all assembly themselves. Well, it's best that they didn't considering the cleanliness of their shop
Old Sep 4, 2009 | 12:16 PM
djamps's Avatar
djamps
Sounds great to me.
My stock heads make more noise up top than that, but I think it's mostly the injectors.
If you close the hood and walk back about 10 feet and can barely hear it or not at all, then you should be OK.
Old Sep 4, 2009 | 12:21 PM
doug's Avatar
doug
turn the radio up brotha.. thats what i do anytime i hear something i don't feel like worrying about
Old Sep 4, 2009 | 12:36 PM
Jay'Z's Avatar
Jay'Z
Originally Posted by djamps
Sounds great to me.
I wanted some opinions from Builders/Built Owners, as I have never heard any other built engines on idle close up.. Thanks though!
I do, I just dont want to ignore if its bad and end up with a blown engine.. Now is not a good time for me as I am relocating to TX..
Old Sep 4, 2009 | 12:40 PM
Cass007's Avatar
Cass007
Jay, my vid is on page 32 of my thread. I thought they sounded similar, but after listening to yours again I would say that mine was MUCH louder, it sounded like a tractor motor .
Old Sep 4, 2009 | 12:44 PM
djamps's Avatar
djamps
Well if a stock block (mine) sounds like a tractor compared to yours, which it does up close, I'd hope that eased your fears a bit. Anyhow, good luck anyways!
Old Sep 4, 2009 | 12:54 PM
Jay'Z's Avatar
Jay'Z
Thanks you have, do you have upgraded cams? I forgot how a stock block sounds too.. lol
Old Sep 6, 2009 | 02:25 PM
ToastZ's Avatar
ToastZ
Sounds like a built motor with aftermarket cams and injectors.
I have BC-Stage2 cams and HKS injectors (1000cc) and at idle you can definitely hear some valvetrain noise with the hood open and hovering around the top of the engine like in your video.
If you have healthy oil pressure and good power under boost, not burning oil or any smoking or missing coolant,... then I vote no worries and enjoy the car
Old Sep 6, 2009 | 02:34 PM
Jay'Z's Avatar
Jay'Z
Thanks ToastZ!!
Old Sep 6, 2009 | 04:34 PM
SmallTuner's Avatar
SmallTuner
normal on built VQs, dont worry
Old Sep 6, 2009 | 07:44 PM
Blackbird CPV35's Avatar
Blackbird CPV35
That isnt **** compared to mine, which sounds like someone is hitting the manifold with a hammer.
And no its not rod knock or anything, Ive been driving with the noise for ~10k miles
Old Sep 6, 2009 | 07:51 PM
Jay'Z's Avatar
Jay'Z
Ok, anyone care to post vids of their engine on idle? Just for true reassurance....
PLAYDIRTY
Oct 12, 2015 07:45 AM
codek
Sep 27, 2015 03:21 PM
