Greddy oil pan or AAM spacer
Old Sep 14, 2009 | 05:39 AM
eZg's Avatar
eZg
Default Greddy oil pan or AAM spacer
I salvaged most of a Greddy 18g kit off a totaled 350Z. I guess you could say it's the ultimate tuner kit. I did not get the Greddy oil pan that comes with the kit although I have just found one for sale.
Is there an advantage to running something like the AAM oil pan spacer instead? Would an oil pan with such a spacer have lower ground cleanance?
Also.... any periodicals that you guys recommend as I try to prepare for my first voyage into aftermarket FI? Been lurking here for a year or so and YES I searched.
Thanks,
George
Old Sep 14, 2009 | 06:47 AM
Skrilla's Avatar
Skrilla
the bigger oil pan allows more oil and most aftermarket pans also have holes predrilled for your turbo's needs. Go for the entire pan. The spacer is good but installation requires the same amount of work but again holds less oil
Old Sep 14, 2009 | 06:48 AM
doug's Avatar
doug
where did you see the pan for sale? i need a new one.. and they were $300+
Old Sep 14, 2009 | 07:35 AM
eZg's Avatar
eZg
Default Hey
Stay off my tip jk
looks like you found it.....
Old Sep 14, 2009 | 07:41 AM
doug's Avatar
doug
lol.. yeah.. i've giving you till tommorow to grab it.. my current greddy oil pan threads are stripped and i have a universal plug on it now.. so either i'm going to retap the oil pan for 14mm or buy this used pan..
either way i'm putting on a quick oil drain valve: http://www.quickoildrainvalve.com/Pr...ductCode=F103N
ReTapping is annoying so this will come in handy.. but i will do it if i have to i guess.. good luck if you pick it up
Old Sep 14, 2009 | 07:43 AM
doug's Avatar
doug
hmm.. maybe if i buy this pan.. i re-tapp and put a quick plug on my old pan anyway and sell it.. but i'm more inclined to tap and plug a pan i don't need to put back in the car to drive to work the next day
Old Sep 14, 2009 | 07:47 AM
eZg's Avatar
eZg
Default Wow!!!
Thank you... Very considerate of you. While I am going to get it....... My stupid employer of 15 years is circling the drain. I might be parting out soon and I will def. rem your kindness!
Old Sep 17, 2009 | 05:46 AM
Skrilla's Avatar
Skrilla
WOW, good find on the oil drain, I'm gonna check that out for sure
Old Sep 18, 2009 | 07:01 AM
UMW350Z's Avatar
UMW350Z
I'm interested to see if it leaks over time. That is a cool item if it does not go bad 2 years in
Old Sep 18, 2009 | 02:02 PM
psychoballistic's Avatar
psychoballistic
Could be another wonderful thing for those of us who have stripped our threads and had to retap the hole. Great find Doug.
Old Sep 18, 2009 | 03:21 PM
doug's Avatar
doug
i can't take credit.. it was brought up in another thread .. you stripped your threads too? i wonder how many people have stripped threads on greddy oil pans
Old Sep 21, 2009 | 09:13 PM
ZRuggernDC's Avatar
ZRuggernDC
APS Oil Pan...
Most places advertise for 300ish.. Got it for 129.00
Old Sep 22, 2009 | 05:08 AM
eZg's Avatar
eZg
Thanks....I went ahead and bought the Greddy oil pan.......just hoping it gets here in one piece!
Old Sep 25, 2009 | 02:41 PM
QuadCam's Avatar
QuadCam
when did greddy start making an oil pan with added side wings?
Old Sep 25, 2009 | 07:01 PM
citymunky's Avatar
citymunky
+1
I'm using the Greddy, but I had the oil return ports re-tapped to a 10 AN unions.
Old Dec 20, 2009 | 05:41 PM
binder's Avatar
binder
Originally Posted by citymunky
+1
what were they originally? I think they are 3/8" npt so would that be a -6an?
Old Dec 20, 2009 | 07:59 PM
djamps's Avatar
djamps
I went with the spacer because of all the stripping problems I read about with APS and other pans. Last thing I need to deal with is a stripped drain plug.
Old Dec 29, 2009 | 05:06 AM
McLovin350Z's Avatar
McLovin350Z
has anybody used the quick drain valve yet?
Old Dec 29, 2009 | 05:23 AM
GreenGoblin's Avatar
GreenGoblin
I use a quick drain with my greddy pan works good, just drains much slower.
Old Dec 29, 2009 | 06:04 AM
McLovin350Z
that sounds like a "pain" I can deal with
"me likely drain valve"
