Fuel is literally being dumped from engine bay area.
Old Sep 17, 2009 | 08:53 PM
ezpotato's Avatar
ezpotato
Default Fuel is literally being dumped from engine bay area.
I was driving, and all of the sudden I smelled gas really bad. And i looked at my fuel pressure gauge and it had dropped from about 4.8 bars to about 3.9 on regular driving, it's never been below 4.5ish (when i'm accelerating even) so i knew something was up with my car. I made it home (only 1 miled from home) and noticed that the fuel was literally just dripping out of my engine bay area. This is 11 pm, so it's dark so i cant get a good look. all on my drivway, there is a line of fuel.
SO i put a towel under it, to soak up the rest of the fuel and will deal with it tomorrow after work. is there anything that would cause the leak?
Vortech with 440cc injectors, walbro fuel pump, etc, but why would the fuel be leaking in the engine bay? I'm bad at fuel stuff, so help me out guys with some ideas. hopefully i'll have better luck looking at it tomorrow, but i dont get home till it's almost dark.
Old Sep 17, 2009 | 09:16 PM
Barzten1's Avatar
Barzten1
More than likely one of your fuel lines is too close to a header. Is it more on the passenger side? Even if you've had the setup for some time over time the rubber hose could malfuntion slowly. Fuel leaking in a hot engine bay could spell disaster. Dont take any chances
Old Sep 17, 2009 | 09:54 PM
ezpotato's Avatar
ezpotato
yeah its on the passenger side.. i'm thinking it's a fuel line, so i'll check it during the day. i'm not even turning on the car till i get it fixed
Old Sep 17, 2009 | 10:00 PM
350Z400rwhp's Avatar
350Z400rwhp
Maybe it's where you tapped in for your fuel pressure gauge?
Old Sep 17, 2009 | 10:02 PM
ezpotato's Avatar
ezpotato
yeah guys, i just panicked and made this thread, i guess i'll just check and update. thanks for the help, when i get pics, you guys can help me further.
btw, barzten1, the nums your car is putting out are ****ing ridiculous!!! that's amazing.
you guys make my 340 whp look soooo small!
Old Sep 17, 2009 | 10:23 PM
Barzten1's Avatar
Barzten1
My Z got totalled in may. I need to put the new car in my sig but honestly I cant let go. My Z was rediculous when it came to performance and is now more realized now thats its gone.
Old Sep 19, 2009 | 03:51 AM
shiftdrift06's Avatar
shiftdrift06
Make sure you use fuel injection clamps and also the right size!
+1--Hoses can go bad over time, swell, and then come loose.
Old Sep 19, 2009 | 07:24 AM
Blackbird CPV35's Avatar
Blackbird CPV35
Try checking the injector o rings, I had a similar problem when mine tore
Old Sep 19, 2009 | 08:04 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
OEM fuel rail where the dampner is. Held on by 2 10mm bolts. That little o-ring in there is prone to failure. Should be easy to find this leak, if you are smelling and seeing raw fuel. Good luck.
Old Sep 21, 2009 | 09:55 AM
Driver06's Avatar
Driver06
Like everyone else said, fuel and a hot engine bay spell disaster.
I hope all you guys have fire extinguishers in your cars. If you dont, all it takes is a stupid little fire, then your that guy watching his car burn to the ground on the side of the road. For those of you that commute a lot, we've all seen it happen..
Old Sep 22, 2009 | 07:50 AM
ezpotato's Avatar
ezpotato
after this incident, i'm buying a small one. going FI changes your safety habits quite a bit. i till havent had time to look at the car, and of course it's raining today. ugh.
Old Sep 23, 2009 | 01:02 PM
ezpotato's Avatar
ezpotato
I need this hose/line. keep in mind, this a g35, i dunno if it's anyu different. this is the passengers side of the engine bay towards the bottom
HELP! anyone know where to get this part without me having to take the car to the dealership (towing is NOT cheap)
Old Sep 23, 2009 | 01:17 PM
- bigc -'s Avatar
- bigc -
if its an ordinary fuel line you can hit up auto zone or pepboys. otherwise, find a junkyard or try courtesyparts.com
Old Sep 23, 2009 | 01:24 PM
ezpotato's Avatar
ezpotato
damn i gotta find out if that is oem. anyone know?
3vilbunny
Jul 18, 2017 05:10 PM
