Built motor @ 17psi misfire
Old Sep 22, 2009 | 09:31 PM
streetzlegend's Avatar
streetzlegend
Default Built motor @ 17psi misfire
Well I have a little issue, iv got a built motor, 8.8:1 compression. I am running 2 step colder ngk copper plugs gapped at .026, single turbo (hx35).
I am getting a misfire (feels like ign cut, but its not) in 2nd gear at around 6k rpm. The boost at that given rpm in 2nd is at around 17psi. If i shift into 3rd, and boost goes to its max at 19-20 psi, I dont get misfires during 3rd. My a/f is at low 11's(11.1-11.3), I am running 50/50 water/meth injection with a 7GPH nozzle. My timing at this boost is 17degree's
Can my misfire be due to the plugs being too cold in range(Maybe 1step colder is enough)? Is it possible that based on the info above, my tune is too conservative and actually hurting me by causing such misfire?
Any info will be greatly appreciated.
Here's one of the plugs thats currently in the car.
Old Sep 23, 2009 | 04:45 AM
GreenGoblin's Avatar
GreenGoblin
What engine management are you using?
Old Sep 23, 2009 | 06:12 AM
SH Luciano's Avatar
SH Luciano
what's your turbo kit?
Old Sep 23, 2009 | 06:19 AM
mforrest100's Avatar
mforrest100
I am pretty sure this is a VQ35 swapped maxima he is talking about. Probably running eManage or Turbo XS EMS with a custom turbo kit.
Old Sep 23, 2009 | 06:50 AM
frankie945's Avatar
frankie945
You should have used 1 step cold ngks. When I was running the Utec. I got missfire codes once a week. After I switched over to a haltech. I have not seen that code yet. But my Z is all stock now. stilll running 1 step ngk's. On stock ecu no codes. What it boils down to is the UTEC sucks.
Old Sep 23, 2009 | 07:25 AM
rcdash's Avatar
rcdash
I also think its UTEC related though you might want to try a less aggressive tune (lower psi that is) and make sure it's not knock. Does backing off timing 2 degress solve the issue? If it's a UTEC ignition driver issue, you should consistently have issues at high rpm. An HKS DLI-II or Ken Bell Boost-a-Spark have helped others running UTECs. I think the fact that it is gear related does not necessarily let the UTEC off the hook as the rate of change of rpm may also be affecting the ability to produce strong spark as quickly as needed. Also might want to be triple certain that the UTEC is well grounded.
Old Sep 23, 2009 | 07:30 AM
Jay'Z's Avatar
Jay'Z
Old Sep 23, 2009 | 07:39 AM
streetzlegend
Thnx for the replies, well I have an Emanage Ultimate, with a custom turbo setup. The issue is at the higher boost, when I lower it, it does not happen. I really doubt its knocking however, because the plugs dont show sign of it, and my knock sensor log does not show knock activity.
Old Sep 23, 2009 | 07:43 AM
frankie945's Avatar
frankie945
Get a better ems. At those boost levels. IMO.
Old Sep 23, 2009 | 08:26 AM
streetzlegend
Well its not an EMS issue, also my options are very limited considering I have a VQ30 ecu.
IMO usually problems with the EU is due to user error and lack of experience with it, I dont see how it would be a problem using it. (not saying its better than a Utec or any other EMS, just saying its not no Apexi SAFC either). I use my EU in relation to my OBD scanner/logger, so for example with timing, I know exactly how much timing I need to take away to output my desired degree's, since I know exactly how the stock ECU's curve/table is.
Old Sep 23, 2009 | 08:48 AM
GreenGoblin
If that is the case I would star buy buying some one step colder plugs and starting there.
Old Sep 23, 2009 | 08:49 AM
streetzlegend
Good idea., thats the first thing I am going to try out.
Old Sep 23, 2009 | 09:21 AM
Chris@FsP's Avatar
Chris@FsP
Vendor - Former Vendor
I would definitely try moving up a heat range, to one-step colder plugs and see if that fixes it.
Old Sep 23, 2009 | 09:39 AM
athenG's Avatar
athenG
LOL at the people jumping on "UTEC Suck!" right away... At the PSI UTEC does suck though. lol
You may want pull more timing at 17psi. You said before that you were running 21deg @ 15psi and I recommended to pull more timing. I believe you set it to 17deg @15psi, you added 2 more psi and still running 17deg then should be pulling more timing. I think 17deg at 17 psi is just high.
Old Sep 23, 2009 | 09:49 AM
streetzlegend
So you think I should pull about 2 degree's more?
Old Sep 23, 2009 | 09:59 AM
wasuber's Avatar
wasuber
The guys telling you to try the colder plugs may be on to something.
Old Sep 23, 2009 | 10:03 AM
streetzlegend
Yea, im def going to try that. I know the most commonly used is 1 step colder. I went with 2step since thats what i used to run on a previous VQ (but was nitrous). So i'll get the hotter plug before i try anything else.
Old Sep 23, 2009 | 10:12 AM
athenG's Avatar
athenG
Unless that timing was set on a dyno then I will always play it extra safe. Did you get a misfire error code? You could be detonating and the ECU is pulling timing.
Edit.
Unless you injector, coilpack, plugs are failing then I dont see why your tune will cause the misfire.
Old Sep 23, 2009 | 10:21 AM
athenG's Avatar
athenG
You have a rear-mount right? You are hitting 17psi on 2nd gear? I want what you have!!!
Old Sep 23, 2009 | 11:03 AM
streetzlegend
In my logs I didnt see timing being retarded. What im going to do first, is put 1 step colder plugs, and see if it still does it. For now, I lowerd my shiftpoint to slightly below 6k (stock is 6200RPM), so I dont get in the misfiring range. Either way I wont be doing many WOT runs if any, till I get this solved.
Haha, yea I do have a RMT setup. Its taken me a couple of years to have it running how I do now. That thing back there spools up with the least amount of effort, If i brake boost in 1st gear, id be able to get 20psi in 2nd. Actually by taking out the muffler alone I get the same boost in 2d as i get in 3rd (19--20). (dynomax superturbo muffler is pretty damn restrictive)
