Finally: GTM Stage 5 + E-85 + G35 = Awesome
Old Oct 3, 2009 | 07:39 AM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
Originally Posted by Blackbird CPV35
i actually have that, give me about 5 min to post it
waiting
Old Oct 3, 2009 | 07:49 AM
thom000001's Avatar
thom000001
yea e85 is like 105.......but I like that its about 1/5 the cost...granted you have to run more.
i'll be doin a e85 tune next season fo sho...
Nice numbers
tom
Old Oct 3, 2009 | 08:30 AM
str8dum1's Avatar
str8dum1
I didnt think I was that far off base. No VTC would make a big difference in the powerband. But run those puppies up to 23-24 psi on some E85 when you get your injectors sorted. Sam's DJ #s are close to what you made. But, theres a ton left in those turbos!!
the 3082s are renamed GT3040's and guys running just ONE! of those are making almost 500 hp.
Originally Posted by Sam@GTM
+ 1
We have made 682 RWHP 563 RWTQ @ 19 psi using 109 gas with the GT3076 and those turbos were still a sleep
Here is the link
https://my350z.com/forum/shop-builds...p-563rwtq.html
Sam
Old Oct 3, 2009 | 08:43 AM
Blackbird CPV35's Avatar
Blackbird CPV35
You have to remember that this isn't a full 3082, it still has a t25 exhaust housing and cast log manifolds. The backpressure between the turbo and manifold is probably killing the hp numbers
I hope hal will chime in with his opinion
Old Oct 3, 2009 | 08:44 AM
ttg35fort's Avatar
ttg35fort
Professional
I would love to have an E85 tune. Big HP, safe and cheap.
Unfortunately, there are no stations anywhere near me. Closest station is about 50 miles away.
Old Oct 3, 2009 | 08:49 AM
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
+1
I Would really sort out the variable valve timing issue first
Sam
Old Oct 3, 2009 | 09:04 AM
Blackbird CPV35
The whether the vtc was on or off it made the same peak hp. The vtc was on 9 out of 10 times so I know that isnt affectin power
Old Oct 3, 2009 | 11:45 AM
ttg35fort's Avatar
ttg35fort
Professional
Well, on my build one time we accidentally connected a wire to the cam phasing control wire (on the ECU harness) for the passenger side, which screwed up the cam phasing on that side. I lost at least 40-50 hp (confirmed on the dyno). Once we found and moved the wire to its appropriate location, the hp came right back.
Old Oct 3, 2009 | 12:53 PM
rcdash's Avatar
rcdash
The intake cam solenoids are powered off the same 12V supply line that feeds the coils. Your misfire and this VTC issue are likely related. Before you go to the trouble of replacing the wiring, I would replace the intake cam solenoids on both banks and see if it solves your issues.
Old Oct 3, 2009 | 02:24 PM
str8dum1's Avatar
str8dum1
Sucks then. bc that is not much power for such big turbos. The additional lag wouldnt be worth the price of admission.
Hopefully, Hal can resolve it and give ya the 200 more HP that kit is well capable of producing.
Old Oct 3, 2009 | 02:56 PM
binder's Avatar
binder
awsome, i'm pumped to see this car.
are you planning on taking it to the tuesday night ORP open nights before the season is over? if not then i'll have to wait until spring to see this car.
Old Oct 3, 2009 | 07:20 PM
Cass007's Avatar
Cass007
Welcome to the 600whp club
In looking at the comparison dyno, I am suprised that you didn't get more out of the APS Extreme kit. Did you make other significant changes in the build when you swapped kits?
Old Oct 4, 2009 | 01:26 AM
Blackbird CPV35
I was only on a single walbro and pump gas
For this build I added a cosworth manifold and twin walbros
Old Oct 4, 2009 | 06:34 AM
SmallTuner's Avatar
SmallTuner
how much boost ???
19 psi ?
Old Oct 4, 2009 | 06:38 AM
SmallTuner's Avatar
SmallTuner
yep, some times it gets stuck.
Old Oct 4, 2009 | 07:13 AM
ttg35fort's Avatar
ttg35fort
Professional
Originally Posted by SmallTuner
hmmmmmmm looks like the T25 really killing HP.
I put all that work into the T25 analysis, and you guys didn't follow that thread, did you?
Just kidding.
It's not the T25 flange itself. You can cut off the T25 flange and throw a T3 or T4 flange onto a log style manifold and its performance will not change. The bottlenecks are the log style manifold itself and the turbine inlet, not the flange.
I have not found the GT3082 turbine housing dimensions on the Garrett website, but I'm assuming that it has a turbine inlet that is smaller than the GT3582 turbine inlet. The GT3582 (0.76 A/R) turbine inlet is 1117 sq. mm. The T25 flange is 1735 sq. mm. So, the T25 flange is already 60% larger than the turbine inlet. You can double the size of the flange and it will not matter.
Think of it like a garden hose with a spray nozzle on the end. The size of the hose doesn't much matter when you have the spray nozzle partially closed. Now, in the middle of the hose you can cut out a 5 ft section and replace that section with a fire hose, but it will not change the flow comming through the nozzle, nor change the back pressure...
Guys running T25 flanges and smaller have laid down alot of power. Heck, XKR got over 800 whp with his last setup. This time, he should even higher. Hopefully his HP numbers are posted in the next couple of days or so.
Old Oct 4, 2009 | 07:57 AM
Blackbird CPV35
That's was 800whp on a dynojet and with race gas though right?
Old Oct 4, 2009 | 08:09 AM
  #38
ttg35fort's Avatar
ttg35fort
Professional
Dyno Dynamics I beleive. I'm not sure whether he had race gas or meth injection. Hopefully he will see this thread and let us know.
But E85 is 105 octane. Not quite C16, but it is about 1/2 way there, and should be better than 100 octane gas.
EDIT: Also re-read post #19. Running race gas is not going to make your turbos perform better. Running race gas inhibits the onset of detonation and pre-ignition, thus allowing you to run more boost and/or more advanced timing before the engine goes boom. The turbos that are capable of providing a particular level of boost on race gas also can provide that same level of boost on pump gas, it's just that you won't be able to use the boost. More simply, people on pump gas run lower boost because they don't want detonation, not because the turbos won't provide the boost. When the use race gas, the onset of detonation is delayed, so the boost can be cranked up.
Old Oct 4, 2009 | 08:28 AM
  #39
ttg35fort's Avatar
ttg35fort
Professional
As others have said, once you get the electrical issues solved, everything should fall into place (assuming no other problems pop up). The electrical problems that you are having are probably having more of an adverse impact than you think...
Old Oct 4, 2009 | 09:46 AM
  #40
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
Maybe i missed it, How much boost pressure are you running ?
Sam
