Return Fuel System
Old Oct 6, 2009 | 07:56 AM
james12345pt's Avatar
james12345pt
Default Return Fuel System
Is a return fuel system needed to achieve 525whp with a walboro fuel pump, 800cc injectors and Haltech E-mgmt? If so, are there other advantages to having an return system?
Old Oct 6, 2009 | 08:15 AM
thom000001's Avatar
thom000001
Sure you can make it. Really need to watch fuel pressure and see whats going on based on your setup.
Generally on non-return setups, the fuel pressure will be less stable. And the harder you push the system, the worse that gets.
tom
Old Oct 6, 2009 | 08:16 AM
str8dum1's Avatar
str8dum1
you dont need it, but its a nice option. You car will tune out just fine without it, if thats what you are asking.
the main advantage is the 1:1 fuel pressure regulator so you can increase fuel pressure to compensate for the the boost pressure.
On paper, if you had enough boost pressure you could completely counteract your fuel pressure.
Old Oct 6, 2009 | 08:26 AM
Chris@FsP's Avatar
Chris@FsP
Vendor - Former Vendor
Achieving the power isn't the concern. Getting it to idle civilly, is the only issue with large injectors and no return.
Old Oct 6, 2009 | 10:59 AM
eltness350's Avatar
eltness350
The Untouchable
altered atmosphere/cj motorsports make return systems fairly cheap and its a nice safeguard when pushing that setup
Old Oct 6, 2009 | 12:08 PM
Blck350z's Avatar
Blck350z
Well considering the money you've probably/are going to spend to try to achieve 525whp .... another $500 for the AAM Stg 1 RFS wouldn't made much of a difference??? just a thought....
Old Oct 6, 2009 | 12:10 PM
Nexx's Avatar
Nexx
generally speaking, skimping on any part of the fuel system is asking for trouble.
Old Oct 6, 2009 | 02:24 PM
ttg35fort's Avatar
ttg35fort
Professional
+1000
Old Oct 6, 2009 | 06:14 PM
Cass007's Avatar
Cass007
As everyone hassaid, its probably a good idea. Unless Scott Bush is your tuner and your motor is being built in a dirt floor shack in the middle of nowhere
Old Oct 6, 2009 | 06:23 PM
Nexx's Avatar
Nexx
if i remember correctly there was one florida tuner who swore by a return less system with big injectors to make up for it. we all know how his cars have turned out....
Old Oct 18, 2009 | 03:27 PM
zerosec's Avatar
zerosec
what turbo kit are you going for ? if im not mistaken the APS TT is equipped with a semi RFS... (correct me if im wrong)
Old Oct 18, 2009 | 03:31 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
I 100% agree with Nexx. If you don't have enough money to go, atleast go with stage 0. Check out CJM or GTM.
Old Oct 18, 2009 | 03:36 PM
stormcrow's Avatar
stormcrow
whats a fuel return do?
Old Oct 18, 2009 | 03:58 PM
str8dum1's Avatar
str8dum1
instead of having fuel dead end at the fuel rails, like stock, the fuel flows thru the rails and back to the gas tank.
That way you can control the fuel pressure and increase fuel pressure as you increase boost on a FI car
zerosec's Avatar
zerosec
its a direct bolt-on kit that converts the current factory “return less” fuel system to a full return fuel system. The “return less” system in the 350Z & G35 offers minimal adjustment to the amount of fuel the engine can receive. This type of system is cheaper for the factory to manufacture and works okay in a factory naturally aspirated setup, but has several draw backs when you go to forced induction.
Chef-J's Avatar
Chef-J
Booooosstt!!
"Return style fuel systems will send the fuel that goes to the fuel rail back to the fuel tank. This will allow you to run more fuel to the motor without flooding it. Return style fuel setups are a must for big HP!"
Dammm i love to read slideFox's forced induction for nooooob!
Old Oct 18, 2009 | 05:39 PM
djamps's Avatar
djamps
Like others said, if you can afford it, get it. The tune will be way less exact nor consistent without it.
Old Oct 18, 2009 | 05:57 PM
xzotklr's Avatar
xzotklr
From AA's website:
AAM Competition STG I Fuel Return System
Item #: AAM35FS-FRSBFR
Quantity in Basket: None
Shipping Weight: 10.00 pounds
Our Price: $999.99 -
Old Oct 18, 2009 | 06:05 PM
stormcrow's Avatar
stormcrow
guess i failed at teh lulz. i got real answers...
if you are lost reading this...make note of the tags in the infamous RA thread... my favorite - "whats a fuel return do?"
Old Oct 18, 2009 | 06:24 PM
Chris@FsP's Avatar
Chris@FsP
son, i am dissappoint :/
