anyone with stri boost gauge or with knowledge. please help.
Old Oct 29, 2009 | 04:28 PM
needforspeed1's Avatar
needforspeed1
Default anyone with stri boost gauge or with knowledge. please help.
i just installed my stri boost gauge this afternoon. looks like everyting fired up normal with arm moving up and down soon as i crank up the car. i have set my max boost to 9lb, but my gauge reads -20to-30 at start and while i'm driving it moves to -10. i am using vaccum block to feed it to the boost sensor. do i need to split before the vacuum block or going thru block is ok? please any feedback will be greatly appreciated. thanks in advance.
Old Oct 29, 2009 | 05:01 PM
psychoballistic's Avatar
psychoballistic
It will show vacumn as long as you are out of boost. Once you go into boost, then it will read above 0 into lbs for you. Running the sensor out of a vacumn block is fine for what you described, many people use vacumn blocks to keep everything nice and clean as well as having a central location for the main connection point.
AbrasiveRaysive
Sep 20, 2021 02:29 PM
bcoffee20
Nov 19, 2015 06:39 PM
codek
Sep 28, 2015 03:03 AM
