Glex25 Winter Build
Old Dec 15, 2009 | 04:50 PM
  #41
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Originally Posted by Glex25
I was putting mine together today and I cut the pipe as it was noted in this thread thanks
I spent the whole day trying to find a proper plug for the bypass even a barbed fitting I didn't care I found none. The 1/4 NPT or COMP plugs would not fit. The only plug that would fit was some elbows and T's that had 1/4 MPT. I finally went to NAPA and they had a NPT plug which seems to have a little play but it feels tight once it screwed all the way down.
Can anyone shed any light on this conundrum.
I still have to pickup the pressure collars for the tube that goes from the T-Housing to the Plate and weld the small pipe closed.
Here are some pics so people can get a idea
For the guys that went from a FI'd stock compression motor tuned with a Haltech to a FI'd lower compression motor.
Did you guys have to retune for the lower compression motor?
did you wait until after the break in(No Boost, 4000RPM Limiter enabled)?
Will the Haltech automatically compensate for a tune that was made with 600cc if you change them out for a 800CC and you change the injector size in the proper tables?
Might get the call tomorrow to pick up the block/heads from M2race
I have since changed to a UTEC, but when I installed my new motor (9:1 compression) I left my unichip + 440cc injectors in for about a month to break in the new motor on a proven tune. The lower compression won't affect your tune any appreciable amount.
Old Mar 27, 2010 | 08:20 PM
  #42
Glex25's Avatar
Glex25
Time to update
Was forced to do headwork since the valves were pitted because the previous owner had let the motor sit in his backyard.
Supertech Inconel Valves (Flat)
Ferrea Valve seals
HR Valve Springs
Serdi Valve Job
No porting
Changed up some other parts:
DW 800cc Injectors
Southbend DXD Clutch Stage 5 FE
Now I have run into a snag
I was assembling the block today and found out that JWT never included
the dowel pins on their cams.
I sold my Rev-up cams long ago and now I'm stuck.
I tried looking up the part number for the Dowel pins and it seems that it only offered with the cams no seperate part number.
The Revup cams use 4 dowels pins 2 big ones and 2 small ones.
Anyone have any input on this?
Part number perhaps?
The only reference that the dowel is offered separately is in this thread
https://my350z.com/forum/engine-and-...my-engine.html
Old Mar 28, 2010 | 07:02 AM
  #43
binder's Avatar
binder
I would be giving JWT and earfull. They should have either sent them or informed you that you needed them for the install.
About the injectors: I'm not a guru by any means but going from 600's to 800's shouldn't cause a horrible problem with the tune. If anything it will cause you to be on the safe side of fuel (rich) which is the best side to be if you have to be. The only thing i can think it would affect is the starting. I'm just starting to tune my 800's in osiris and it starts like crap.
Old Mar 28, 2010 | 07:08 AM
  #44
rrmedicx's Avatar
rrmedicx
Hey Glenn, can you contact any of the reputable motor builder shops, like Forged, SP, Injected, or so forth and see if they have any of the dowel pins, leftover, from perhaps a blown motor. Turbo-toys in Florida also has tons of used Z parts. Why not give them a shot 813-695-6665 ask for Jim.
Old Mar 28, 2010 | 08:41 AM
  #45
Glex25's Avatar
Glex25
Got lucky the guy i sold it to is next state over and he hasn't installed them yet so I'm heading out there see if i can remove them easily.
I will post pics of the block later on
Old Mar 28, 2010 | 12:50 PM
  #46
Glex25's Avatar
Glex25
So I panicked a little when I was looking at the service manual and it said the dowel pins were on the cams and so did the parts catalog. My mistake was not looking at the cam gears and looking behind so for future reference on the rev-up motors the cam sprockets are the ones that hold the dowel pins.
Here are some pics.
Here are some other pics
Old Mar 28, 2010 | 01:27 PM
  #47
rrmedicx's Avatar
rrmedicx
PM'd you regarding assembly lube, or absence thereof.
Old Mar 28, 2010 | 03:15 PM
  #48
Glex25's Avatar
Glex25
I used some Fogging oil on the heads but I will add Assembly lube
Old Mar 28, 2010 | 03:38 PM
  #49
Vas_Z33's Avatar
Vas_Z33
very nice build!
Old Apr 14, 2010 | 10:27 AM
  #50
rrmedicx's Avatar
rrmedicx
Whats up G? Updates?
Old Apr 14, 2010 | 10:53 AM
  #51
Glex25's Avatar
Glex25
Got the Nissan RTV on Sunday and 1cockyz and I did some work. I was also missing the 4 small O-Ring Seals that go behind the rear timing cover pick those up Monday and installed the rear timing cover. My kids baseball season has started so every day is either drop them off at a practice or taking them to a game which is cutting into my time.I have also been selling some stuff off so boxing up and shipping has also taken my time by the end of the week i hope to have everything together.
Here are some of the progress pics
I should have the car back in my possession in 3-4 weeks according to the shop so we shall see. Some pics from last week
Old Apr 14, 2010 | 11:25 AM
  #52
binder's Avatar
binder
now that's some crazy fender! awsome
Old Apr 14, 2010 | 12:26 PM
  #53
Forged_G's Avatar
Forged_G
Cant wait to see the finished car. 600 HP sounds awesome!
Old Apr 14, 2010 | 01:05 PM
  #54
350Z400rwhp's Avatar
350Z400rwhp
That's one way to resolve any fender rubbing issues! Good luck with your build!
Old Apr 14, 2010 | 01:17 PM
  #55
BrianLG35C's Avatar
BrianLG35C
New color too?
Old Apr 14, 2010 | 01:55 PM
  #56
Glex25's Avatar
Glex25
Originally Posted by BrianLG35C
New color too?
Keeping it Grey
Since I don't want to go through the headaches of changing color on the title
The new color is Grigio Silverstone
Old Apr 14, 2010 | 04:01 PM
  #57
BrianLG35C's Avatar
BrianLG35C
Keeping it Grey
Nice Ferrari color.
Old Apr 14, 2010 | 07:03 PM
  #58
Glex25's Avatar
Glex25
Wanted to get a second opinion to make sure I got all the timing marks correct.
I tried following the manual to a T including the marks on the chains.
If it's wrong let me know before I seal it up
The motor has been sprayed down with some WD40 and put away for the night
Old Apr 14, 2010 | 07:10 PM
  #59
ashtrojan2008's Avatar
ashtrojan2008
Looks familiar! Except a few parts that I wish I had....
The timing looks fine. All marks are in the right place, and the cam lobes on cylinder 1 sit as they should. Good luck on the rest of the build!
ross
Old Apr 15, 2010 | 03:58 AM
  #60
rrmedicx's Avatar
rrmedicx
Timing marks look fine.
Hope the heads are down nice and tight. Do you remember how much you torqued them down? Should be around 92-95 ft/lbs for the L19's. You certainly don't want to worry about heads lifting with 600rwhp under the hood.
