Glex25 Winter Build
Old Apr 15, 2010 | 04:08 AM
  #61
Glex25's Avatar
Glex25
Originally Posted by rrmedicx
Timing marks look fine.
Hope the heads are down nice and tight. Do you remember how much you torqued them down? Should be around 92-95 ft/lbs for the L19's. You certainly don't want to worry about heads lifting with 600rwhp under the hood.
Torqued them down to 95ft lbs
Thanks for that info Randy cause I got that info from one
of your old threads where you were asking the same question and Shariff had answered it
Old Apr 15, 2010 | 04:17 AM
  #62
Jay'Z's Avatar
Jay'Z
Wow, I think i need a cossy..
Old Apr 15, 2010 | 07:29 AM
  #63
GreenGoblin's Avatar
GreenGoblin
^ doet you carbon *****
Old Apr 15, 2010 | 01:27 PM
  #64
ttg35fort's Avatar
ttg35fort
Professional
Glen,
What size wheels/tires are you running?
Old Apr 15, 2010 | 01:40 PM
  #65
Glex25's Avatar
Glex25
Originally Posted by ttg35fort
Glen,
360 Forged Mesh 10's
20x13 +12 offset
20x10 0 offset
345/25/20 Nitto Invo
275/30/20 Nitto Invo
Track setup
Rota Grids 18x10 +15
Toyo R888 305
Toyo RA1 275
Old Apr 15, 2010 | 01:43 PM
  #66
ttg35fort's Avatar
ttg35fort
Professional
Nice!!!
Old Apr 18, 2010 | 03:04 PM
  #67
Glex25's Avatar
Glex25
Finally got some time to myself and was able to finish up the motor.
I will not use any sensors that came off this motor and will take them off my
known good running motor that is on my car now. The motor ain't pretty from the
side since the previous owner had let it sit in his backyard.
Here are some pictures of the finished product
Clean bead of Nissan RTV every where
Now as always a question
The little bolt that is all the way to the left is that suppose to be anywhere on the motor?
The one between the 2 stamp marks I just put it there for now until I compare it to my other motor
Old Apr 18, 2010 | 03:38 PM
  #68
GreenGoblin
Awesome bro looking good
Old Apr 18, 2010 | 06:19 PM
  #69
Glex25's Avatar
Glex25
Thanks Danny
I got the motor sling yesterday
The small plug I was pointing to is the front drain plug
I should have looked closer at the Service manual but I thought
it would be as obvious as the other drain plugs
Old Apr 19, 2010 | 04:36 PM
  #70
Glex25's Avatar
Glex25
Thinking of doing a leakdown test tomorrow or Thursday.
Any Advice?
What kind of numbers should I be looking at with a cold motor?
Drop of oil on each cylinder before performing the test on a particular cylinder?
Old Apr 19, 2010 | 05:21 PM
  #71
binder's Avatar
binder
Any Advice?
well on a fresh motor what exactly are you looking for?
i wouldn't worry too much what the numbers are as much as how consistant each cylinder is.
It will probably have a high leakdown since the rings aren't seated to the cylinder walls yet.
Old Apr 19, 2010 | 06:19 PM
  #72
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Any Advice?
I would wait to do a leakdown until you have 500-600 miles on the motor. If it runs smoothly and doesn't burn any oil, I would wait before any leakdown or compression testing.
Build looks good!
Old Apr 24, 2010 | 12:30 PM
  #73
rrmedicx's Avatar
rrmedicx
Bump. Whats the status of the physical car? Body shop or is that transformation all done?
summer time is here and we gotta roll down to Z-Day my friend.
Old Apr 24, 2010 | 01:19 PM
  #74
Glex25's Avatar
Glex25
^ It's going
Just shot a sample of the color today and I'm liking it
Old Apr 24, 2010 | 02:20 PM
  #75
ttg35fort's Avatar
ttg35fort
Professional
Are using a fiberglass front bumper?
If it is urethane, it seems that it would be hard to get the bumper to fit to the flared front fenders.
Old Apr 24, 2010 | 02:33 PM
  #76
Glex25's Avatar
Glex25
These are the pieces I'm using
No Urethane here or I wouldn't be able to do what I have to do
Old Apr 24, 2010 | 06:29 PM
  #77
GreenGoblin
looking very good homie.
Old Apr 25, 2010 | 06:30 AM
  #78
BrianLG35C's Avatar
BrianLG35C
It's gonna look great, I'd only change the mesh to black.
Old Jul 6, 2010 | 08:15 PM
  #79
Glex25's Avatar
Glex25
Started on pulling out the motor on Tuesday and cleaned the engine bay so it can get sprayed.
Wednesday did some suspension work and also did the solid differential bushing (Which I think took me longer than pulling the motor).
On Saturday I started moving things over from one motor to the other and continued doing the same on Monday. I found some disturbing things such as the driver side manifold missing the lower to 2 nuts and a sizable exhaust leak. You can see the exhaust leak in the second picture.
I have moved almost everything over but have to remove the passenger side wastegate because the power steering bracket bolts will not go on. I still have to move over the lower oil pan and spacer for the oil pick up and flywheel, install the Southbend clutch/pilot bearing/throwout bearing then reinstall back into the car.
Those with the Pathfinder mod how in the hell did you get the connectors for the water temp sensor and cam sensor connected since they are practically touching each other?
Also for those that were able to remove the bottle neck for the Greddy Evo TT what did you have to do? did you cut the bottleneck and weld a 2.75" Flange or did you expand the small bottleneck then weld on a 2.75" flange?
I'm even thinking of sending the pipe to Forged Performance just so they can remove the bottleneck
I would also like to thank my local shop MC Tires for letting me use their lift for 2 days and space for me to do this work
Old Jul 7, 2010 | 06:13 AM
  #80
Forged_G's Avatar
Forged_G
Car is coming along nicely Gio!! Cant wait to see the finished product.
