my 2011 and Beyond! build thread.
thats what it would look like if they used a lift and dropped tranny/ngine from underneath. (smart way) No way you are doing it like that with a cherry picker (the way I have to do it in my 1 car garage )
Sorry I meant the radiator support shroud not the strut bar. I saw the pic where they were using a cherry picker and pulled the motor from the top. So they just dropped the tranny first and then pulled the motor?
The reason I ask is because I'm trying to pull mine but I was going to remove the rad support and pull it all at once.
it is not, i've been on the internet longer.
Also guys, eta for motor to be back in the car is 1-2weeks. The builder who is doing the work on my engine formely worked at HKS and now works at Cosworth. One of the perks of dealing with GearHeinz. =)
good turn around time im envious! took my machinist 7 weeks >.>
I didn't follow this thread, so can you give a quickie on why the felt they needed to pressure test the head? Is this a motor you popped in the past or something?
Yea popped few weeks ago. Stock motor only had about 11,000 miles on it. if the motor had high miles i would of considered some valvetrain upgrades but since my goals are very modest and the heads are fine i decided against it.
