my 2011 and Beyond! build thread.
Old Sep 18, 2011 | 11:12 PM
  #461
Flo-ridaZ33's Avatar
Flo-ridaZ33
Old Sep 19, 2011 | 06:43 AM
  #462
str8dum1's Avatar
str8dum1
So, you still have your new motor getting built anyhow right?
Originally Posted by dikspiel
Even though I am building the motor and possibly have a ticking time bomb on my hand, I am going to be going back to the haltech tuner to get the car tuned properly so I can at least enjoy the car for a few hundred miles before the motor is pulled.
Old Sep 19, 2011 | 07:08 AM
  #463
Cass007's Avatar
Cass007
Originally Posted by 350z006
Welcome to the SoCal Blown Motor club...I've blown 2, may you not blow anymore...
Exclusive membership, More exclusive than SBC!
Sorry to hear this!!! Hope the block can still be used as a donor at least.
Welcome to the VED Club as well
Old Sep 19, 2011 | 07:12 AM
  #464
dikspiel's Avatar
dikspiel
Chestons Toilet
I am going to use my block for the build..hopefully.
Old Sep 19, 2011 | 07:29 AM
  #465
midz350's Avatar
midz350
You can buy a bare DE block for dirt cheap and have it build now to minimize the downtime.
Old Sep 19, 2011 | 07:36 AM
  #466
dikspiel's Avatar
dikspiel
Chestons Toilet
Well my **** is already not working so i dont think it will make a difference in downtime
Old Sep 19, 2011 | 08:03 AM
  #467
dikspiel's Avatar
dikspiel
Chestons Toilet
What is everyone using for Rod bolts?
Old Sep 19, 2011 | 09:16 AM
  #468
str8dum1's Avatar
str8dum1
the bolts that come with the rods.... are you asking if people swap the rod bolts that come with the rods for something else? if so, only ones worth swapping to are Carr bolts.
did you drop your oil pan yet?
Old Sep 19, 2011 | 09:23 AM
  #469
dikspiel's Avatar
dikspiel
Chestons Toilet
Not yet..towing it to the shop in a little bit.
My Carrillo H-Beam rods didn't come with any rod bolts...is it supposed to come with them?
Old Sep 19, 2011 | 09:32 AM
  #470
midz350's Avatar
midz350
Mine came with bolts.
Old Sep 19, 2011 | 11:27 AM
  #471
str8dum1's Avatar
str8dum1
ya they are supposed to come with ARP hardware. see about getting the Carr bolts though. I wish I had got those.
Old Sep 19, 2011 | 12:27 PM
  #472
dikspiel's Avatar
dikspiel
Chestons Toilet
ill call summit racing later
Old Sep 19, 2011 | 12:35 PM
  #473
Ruthless18x's Avatar
Ruthless18x
Bummer.
Old Sep 19, 2011 | 03:51 PM
  #474
dikspiel's Avatar
dikspiel
Chestons Toilet
CP wants me to send them their rods back since it didn't come with the correct rod bolts. :/ God damnit.
Old Sep 19, 2011 | 04:05 PM
  #475
ace32x's Avatar
ace32x
hopefully turn around is fast
Old Sep 21, 2011 | 04:00 AM
  #476
dikspiel's Avatar
dikspiel
Chestons Toilet
Motor:
Cosworth 8:8.1 Pistons 95.75mm **
Nissan OEM Piston Rings 95.75mm
Carrillo H-Beam Rods (NI-Q35>-65676H-0) **
ARP Main Studs **
ARP L19 Head Studs **
Cosworth Head Gasket **
ACL Main Bearing Set
ACL Thrust bearing
New RevUp Oil Pump **
Block inspected and cleaned
Block redecked
Block Bored and Honed using a Torque Plate
Rotating assembly balanced
Crank magnafluxed and the journals micro-polished
Fuel:
Cosworth Fuel Rail Kit **
CJMotorsports RFS Stage 0 (modified to work with the Cosworth Kit) **
Aeromotive 340lph stealth fuel pump **
DW 850cc injectors **
** means already purchased.
Old Sep 21, 2011 | 04:01 AM
  #477
dikspiel's Avatar
dikspiel
Chestons Toilet
Anyone know how I can order 95.75mm piston rings from nissan?
Old Sep 21, 2011 | 07:31 AM
  #478
ace32x's Avatar
ace32x
your pistons dont come with piston rings?
Old Sep 21, 2011 | 07:36 AM
  #479
dikspiel's Avatar
dikspiel
Chestons Toilet
negative and cosworth no longer offers the size. the cosworth piston rings are just nissan anyways.
Old Sep 21, 2011 | 07:43 AM
  #480
ace32x's Avatar
ace32x
did not know that! hopefully the reason they dont carry them anylonger isnt because nissan doesnt offer it
