my 2011 and Beyond! build thread.
Old Feb 25, 2013 | 01:58 PM
  #941
str8dum1's Avatar
str8dum1
why is 96.7 too big? isnt your motor bored 20 thousandths over. thats 96.5mm
The HKS gasket is 97mm for the DE and everyone uses that
Old Feb 25, 2013 | 02:46 PM
  #942
Resmarted's Avatar
Resmarted
Mine's 20 thou and its 96mm.
Old Feb 25, 2013 | 02:57 PM
  #943
dikspiel's Avatar
dikspiel
Chestons Toilet
mine is 10 over
Old Feb 25, 2013 | 07:25 PM
  #944
binder's Avatar
binder
It's not too big. I ran a 98 on a 96 bore. won't hurt a thing. HKS 97mm has been used on stock bore with no issues as well.
That being said, just run the HR gasket unless you are planning on 700+
Old Feb 25, 2013 | 09:55 PM
  #945
jerryd87's Avatar
jerryd87
20 thous is actually 96mm, stock bore is 95.5mm, 96.7mm is 47 thous overbore.
but the point is yah 96.7 isnt too big at all pretty sure the dynosty HG i use are 97mm too but i cant remember 100%
a little bigger probably be a good idea anyway to account for the different piston to wall clearances of the different pistons since a 96 mm piston the bore is likely to be a little bigger then 96mm anyway, dont wanna contact the hg with the piston and then it not seal lol.
Old Feb 26, 2013 | 04:42 AM
  #946
Ruthless18x's Avatar
Ruthless18x
Why isn't GH doing the tear down?
Old Feb 27, 2013 | 10:30 AM
  #947
str8dum1's Avatar
str8dum1
ahh thought stock bore was 96 for some reason, but knew mine was bored to 96.5 with a 97mm HKS gasket
Old Mar 8, 2013 | 01:18 PM
  #948
dikspiel's Avatar
dikspiel
Chestons Toilet
was able to find a Cosworth 96mm HR head gasket
Old Mar 26, 2013 | 10:46 AM
  #949
dikspiel's Avatar
dikspiel
Chestons Toilet
Motor is now back in the car, tune is way off. Have to install the new injectors and schedule for tuning.
Old Mar 26, 2013 | 12:59 PM
  #950
350z006's Avatar
350z006
Don't you still need to break it in?
Lemme know when you go, I may want to check it out if I have the time...
Old Mar 26, 2013 | 01:23 PM
  #951
dikspiel's Avatar
dikspiel
Chestons Toilet
I'm going to try to schedule it for a Saturday. I'll let you know.
Old Mar 26, 2013 | 01:39 PM
  #952
ace32x's Avatar
ace32x
new injectors again?
Old Mar 26, 2013 | 01:43 PM
  #953
dikspiel's Avatar
dikspiel
Chestons Toilet
not yet but the fuel is way off, strange no? I am bringing over 1000cc injectors today.
Old Mar 27, 2013 | 05:03 PM
  #954
dikspiel's Avatar
dikspiel
Chestons Toilet
the fuel wasn't way off, mechanic didn't realize I have a haltech ecu and was going by the odb2 readings. doesn't matter anyways because it has 1000cc injectors now and needs to be retuned.
Old Mar 27, 2013 | 07:58 PM
  #955
jomamahama's Avatar
jomamahama
this thread is depressing
Old Mar 27, 2013 | 09:15 PM
  #956
ace32x's Avatar
ace32x
welcome to built vq's
Old Mar 28, 2013 | 07:37 AM
  #957
dikspiel's Avatar
dikspiel
Chestons Toilet
ya welcome to the jungle baby
Old Apr 15, 2013 | 08:43 PM
  #958
dikspiel's Avatar
dikspiel
Chestons Toilet
Just got tuned 500@9 psi. 560@14 psi. Could do 650 on e85 he says but will probably run out of injector. Very conservative tune.
Old Apr 15, 2013 | 09:50 PM
  #959
ace32x's Avatar
ace32x
some good numbers! congrats
Old Apr 16, 2013 | 07:35 AM
  #960
dikspiel's Avatar
dikspiel
Chestons Toilet
Not really considering the dyno used.
