Fron mount Turbo set up?
Old Dec 5, 2009 | 10:28 AM
  #41
binder's Avatar
binder
Originally Posted by 04.350z
We will see after we look into it deeper
putting the turbo in that area is actually a great design. I like the way hal's is set up.
The radiator brace looks like a pretty simple build but i'm not sure what he did for the radiator. I think he built his own which I wouldn't even know where to start.
Old Dec 5, 2009 | 11:07 AM
  #42
04.350z's Avatar
04.350z
I'll post pics of the drawings of the design hen I get them
Old Dec 5, 2009 | 12:03 PM
  #43
str8dum1's Avatar
str8dum1
ahh I was thinking of the race car. Hal street setup is just the same as any other PL setup, but has a huge turbo and huge down pipe that had to fit, so it had to be moved more forward
no reason you couldnt do that as well.
Old Dec 5, 2009 | 12:24 PM
  #44
04.350z's Avatar
04.350z
Putting the car on the lift now we don't think we are gonna have to cut the radiator support
Old Dec 5, 2009 | 12:37 PM
  #45
04.350z's Avatar
04.350z
Old Dec 5, 2009 | 12:43 PM
  #46
Quamen's Avatar
Quamen
The way to go for a custom radiator is Howe Racing for sure. They will build you a custom radiator which half of what the radiators for our car cost and the quality is top knotch. That is what happens when you look in other crowds, i.e. circle track, where people are not willing to pay the ridiculous prices we do.
Old Dec 5, 2009 | 12:49 PM
  #47
04.350z's Avatar
04.350z
Thanks for the info I'll keep them in mind
Old Dec 5, 2009 | 03:00 PM
  #48
Quamen's Avatar
Quamen
Ive had three radiators made for my z (dye to design changes) and they all came in at under $300. We also use one on our Pikes peak Porsche 928 and have had no problems.
Old Dec 5, 2009 | 03:03 PM
  #49
Chef-J's Avatar
Chef-J
Booooosstt!!
coo, could you tell/show us exact place you are going to put turbo at?
Edit: +1 thanks for good info quamen.
Old Dec 5, 2009 | 03:37 PM
  #50
04.350z's Avatar
04.350z
Drivers side just right of the intercooler the way we are looking at it the down pipe will sit just above the steering column gonna need alot of heat wrap and possiby a heat shield
Old Dec 5, 2009 | 04:23 PM
  #51
str8dum1's Avatar
str8dum1
ya the common kits are high up so you dont have to mess with an oil return pump.
There's a pic of someones kit just like how you are thinking. I couldnt find it though
Old Dec 5, 2009 | 04:57 PM
  #52
04.350z's Avatar
04.350z
We are putting my car up on stands tomarro and gonna see what size piping etc. will fit and blah blah then we should be able to draw up a legit and detailed design.
Old Dec 5, 2009 | 05:23 PM
  #53
binder's Avatar
binder
are you doing forward facing manifolds? you should have a lot more room if you do that verses the cross over pipe that has to squeeze back through.
Old Dec 5, 2009 | 10:45 PM
  #54
04.350z's Avatar
04.350z
We havent decided weather to do forward facing or not yet. we need to get the car in the air so we can see what our best bet is so we can make the most power. and be the most sensible. Cause we are trying to keep power steering and A/C
Old Dec 6, 2009 | 12:24 AM
  #55
350z-900whp's Avatar
350z-900whp
here what y looking for
link
http://www.youtube.com/watch?v=lS9dY...eature=related
Old Dec 6, 2009 | 04:05 AM
  #56
str8dum1's Avatar
str8dum1
heres a gt42 fit where the PL goes
https://my350z.com/forum/forced-indu...4294r-g35.html
Old Dec 6, 2009 | 05:10 AM
  #57
Quamen's Avatar
Quamen
Getting the manifolds to point forward is extremely hard to do. You have an A/C, thermostat and thermostat bypass tube to the heater core on the river side that get in the way and the power steering and alternator on the other side. I had to move my alternator to the driver side, lower my power steering down to the cross member, modify my driver side coolant tube and thermostat and eliminate the heater core tube in order to come up with a no compromise design. Of course mine is a bit over the top compared to what is possible.
Old Dec 6, 2009 | 05:39 AM
  #58
binder's Avatar
binder
that's why i run a supercharger
Old Dec 6, 2009 | 07:21 AM
  #59
Quamen's Avatar
Quamen
That's why my car is a bigger money pit than yours and only has 9000 miles on it over five years
Old Dec 6, 2009 | 07:49 AM
  #60
04.350z's Avatar
04.350z
We think we have a pretty good idea how we are gonna fothis now forward facing mounts doesn't make sense it's just not practical.
It looks like the easiest way will be mount the turbo on the drivers side (gt42r) in front of the wheel well.
The charge pipe will run about 6-10inch from intercooler into the turbo.
Down pipe will run from the turbo straight back to my single exit exhaust.
It will run from the turbo make a slight left to male it back into the engine bay over the steering rack and then back to the Greddy tic.
We will then fab up a y pipe to connect the headers into one pipe haven't decided weather to go over the transmission or under
if we go over the design will be:
up from the drivers side over the transmission connect to drivers side header down and forward over the steering rack and across the front of the motor back into the exhuast side of the turbo
