Longevity of full builds, the good the bad
Old Jan 11, 2014 | 12:16 PM
  #401
adrift_foolish1's Avatar
adrift_foolish1
I have 10k on mine so far. All I've had to do is oil, plugs, and a couple coils.
https://my350z.com/forum/forced-indu...20g-15psi.html
Old Jan 11, 2014 | 01:33 PM
  #402
suprasam's Avatar
suprasam
Steve you must be so bored! You have been all over the forums this week.
Old Jan 16, 2014 | 06:37 PM
  #403
RED RIDER's Avatar
RED RIDER
Default :)
I haven't been in here in forever...My 550hp+ twin turbo has been with ME since '07..I have put roughly 25,000 miles on it..I have raced the www.bborr.com 7 times and had several track days...I rebuilt the turbos and flow matched the injectors about 9 months ago...pulled the motor, did the pathfinder mod and a bunch of wiring clean up and wrap...
just replaced the wideband o2..it went bad and was giving erroneous readings...I am registered to run the Big Bend race in April..car runs like a scalded *** ape!
Old Jan 18, 2014 | 02:44 PM
  #404
Recklezzz's Avatar
Recklezzz
I have been running the same Built motor since 2004. Charles At CJM built the motor. Over 40K miles on it now(Not sure on exact numbers). Power has been anywhere between 550-650+whp. Last tune was By Hal 636 Dynojet last year.
This year i am planning on pushing the motor pretty hard. Using Twin GTX3076 turbos. Using a set of custom CJM turbo manifolds. Upgraded intake and ID1300's. Shooting For 800whp maybe a little more if everything is going smooth.
I think most VQ failures are from improper tuning. These cars are also not the easiest to work on and a lot of simple mistake can be easily made. These motors make so much torque for there size and spool pretty quick which makes them so hard to tune.
I personally think the VQ's are VERY underestimated. Not many stock block motors can make it over 900whp. No one really even know's where the blocks limitations are. Watching all these VR's make over 1500whp on the stock sleeves makes me think.
Old Jan 18, 2014 | 03:40 PM
  #405
midz350's Avatar
midz350
Stock block 900whp VQ and over 1500whp stock sleeves? Are you high?
Old Jan 18, 2014 | 05:09 PM
  #406
Cux350z's Avatar
Cux350z
hatersgonnahate
I think he meant sleeves for both.
unless he is from relentless auto
Old Jan 18, 2014 | 07:11 PM
  #407
Resmarted's Avatar
Resmarted
He means VR stock sleeves
IE Vr38dett.
But they aren't at all comparable, if anything the vq should be much weaker; open deck vs semi closed/closed.
I've heard reputable shops claim that vq's push water at like 700hp, I've heard that certain parts wont hold four digit power, I've heard that vq's can't be reliable, I've heard that you need to replace your hG all the time.
Don't go by everything that you read. Do your own research on how things work and go by that.
Old Jan 18, 2014 | 10:34 PM
  #408
racer59's Avatar
racer59
IE Vr38dett.
I have been running a vq in a track car, the engine is making around 760hp the engine never uses water, running stock sleeves.
Used to have issues with head gaskets, changed to power enterprise gaskets that are made in Japan had no more issues since.
Old Jan 18, 2014 | 10:51 PM
  #409
midz350's Avatar
midz350
IE Vr38dett.
Even the VR engine won't make 900whp on stock block.
Old Jan 19, 2014 | 12:03 AM
  #410
Recklezzz's Avatar
Recklezzz
A shop that sponsor's this forum just made well over 1000whp on a stock sleeved Vq. Not going to say who or when they did it because i am sure they will be making a new thread about it when its time.
There are Several Vr's making over 1200whp on stock sleeves. I know of at least one VR that makes just over 1500whp on stock sleeves. I am sure there are more out there. I have a couple friends that work at AMS (I am not a fan but they tune alot of GTR's). They have yet to break a stock sleeved motor that i was told about. They have had a couple sleeved motors fail.
Old Jan 19, 2014 | 02:27 AM
  #411
Cux350z's Avatar
Cux350z
hatersgonnahate
Sounds like he is saying stock block as in specifically the block/sleeves. not the typical use of stock block which is causing some confusion.
they are several threads and post about the sleeve strength and no need to do drop ins for under 1000whp. it's nothing new.
Old Jan 19, 2014 | 06:15 AM
  #412
midz350's Avatar
midz350
Yeah, I just got that.
Old Jan 19, 2014 | 12:34 PM
  #413
Recklezzz's Avatar
Recklezzz
Ya.. Sorry for the confusion. I was referring too the block its self.
350Z_Al
Oct 29, 2020 07:44 PM
Tochigi_236
Sep 27, 2015 03:40 PM
