Needed or not
Old Dec 15, 2009 | 06:14 PM
De La Money's Avatar
De La Money
Default Needed or not
YES, IVE searched and very little info was usable minus the fact that the threads related were 3-5yrs old lol. But my question is the following???
1. At 450whp DO I NEED A FUEL RETURN SYSTEM??? if not when do i need a FRS??
2. Lastly, has anyone USED the "SEMI" APS TT return system (NOT THE EXTREME KIT) for 500whp and under builds???
thanks in advance. flame suit on even tho im sure i wont need it.
NOTE- for those who dont know heres an explanation of how the semi aps tt frs works.
It does not include a "traditional" fuel return system (i.e. pressure regulater at the end of the rails with a fuel line going back to the tank). It places the FPR in the tank and maintains a target pressure by running a LONG vacum signal to the gas tank... Thus, instead of routing excess fuel to the rails and then returning it back to the tank, the presure regulation is in the tank so there is no need to return it.
Old Dec 15, 2009 | 07:45 PM
Glex25's Avatar
Glex25
I used the APS FRS on my car for 2yrs and didnt have any issue pushing 427WHP.
Old Dec 15, 2009 | 08:12 PM
thom000001's Avatar
thom000001
you are right in that grey area for RFS at 450rwhp on a TT setup.....
Is it required? No.
Would it make the tune (and fuel pressure) more stable? Absolutely
So there is no right answer. That being said, RFS would be "safer" and a little more controlable to tune......
BTW, by tune I am not necessarily saying your peak power tune, I mean the drivability tune (especially part throttle, but in the higher rpm area)
just my $.02
tom
Old Dec 15, 2009 | 10:32 PM
350Z400rwhp's Avatar
350Z400rwhp
I'd say a fuel return would be a good idea. I think I am in the gray area at 414. You are really pushing it at 450. A basic fuel return is not that expensive. I'm not sure about the APS regulator you are speaking about but a fuel return is more mainstream and if you run into tuning issues it would be easier to rule out fuel related problems because if it being more common.
Old Dec 16, 2009 | 07:57 AM
Cass007's Avatar
Cass007
Since, like the others have said, you are in the grey area, I would advise to err on the side of caution and get the FRS. Either that or leave it to your tuner's discretion.
Old Dec 16, 2009 | 08:22 AM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
My answer depends on the rest of the setup. At 450whp, boost will likely be low so the factory static fuel pressure won't present a problem.
If you are using a good ems such as Haltech, I would suggest throwing in a Walbro and a set of DW800 drop in injectors. This can be tuned without trouble to drive perfect. This also gives you room to grow if you decide to turn it up more in the future and add a RFS.
If you are using a piggyback/utec, then the car will drive better if you use a fuel return system and smaller injectors.
Old Dec 16, 2009 | 11:23 AM
De La Money
im using a utec, walbro 255 and the aps 500cc injectors. will that work or will i have to get some dw600cc to do the job??? thanks
Old Dec 16, 2009 | 11:31 AM
Dynosty's Avatar
Dynosty
Depends on a number of factors, but I can say that those will not support 450whp on our dyno dynamics. DW600s likely will, but be careful as they will be near max duty. Also, a return fuel system can help with 600s on the UTEC as it lowers base fuel pressure when in vacuum.
Old Dec 16, 2009 | 11:37 AM
str8dum1's Avatar
str8dum1
+1, my DW600s were 98-99% IDC with dual pumps and CJM stage 2 RFS at 460whp,11.5 AFR on a dyno dynamics. Granted this was with a less efficient supercharger, but still too small to anything close to that power.
Old Dec 16, 2009 | 12:01 PM
De La Money
okay, how come on aps website they claim those injectors are good for 600 flywheel hp. thats clearly over at least over 475whp
als just incase u need to know my build is as follow...
greddy tt kit
aps 500 injector
hks boost gauge
aem uego wideband
strup 2.5 testpipes
utec
utec map sensor
stage 3 clutch
txs boost controller
walbro 255 lph fuel pump
8.8:1 wiseco pistons
eagle h-beam rods
apr head studs
greddy oil catch can
ACL rod bearings
ACL main bearings
ACL thrust washer
cometic headgasket
jic single 3in exhuast
1 step colder spark plugs
Old Dec 16, 2009 | 12:21 PM
str8dum1's Avatar
str8dum1
well try it and find out. every car is different.
Hal has tuned alot of cars and I know what I had on my own setup...
Old Dec 16, 2009 | 01:25 PM
Dynosty's Avatar
Dynosty
Same reason they sell a "1000hp fuel system" with 880cc injectors at 4bar... and that you can find other manufacturers selling "1000hp" turbo kits that will never make 1000hp. People can say whatever they want, and as long as the majority is never going to actually try and do what they claim - then they are ok.
You can give it a shot and I wish you the best - I am just trying to save you two trips in for tuning (the first, aborted for lack of fuel).
Also fyi, a 600hp vehicle will not make 475whp on our Dyno Dynamics. What dyno you tune on will make a difference in the perceived "whp" output - but obviously no difference in crank hp.
Old Dec 17, 2009 | 07:20 AM
De La Money
naw thats much appreciated, i wasnt trying to be a smart *** to u or strdrum btw. do u know the max whp those 500cc aps injectors will make on ur dyno using a return fuel system????
Old Dec 17, 2009 | 07:49 AM
De La Money
x2 post sorry
Old Dec 18, 2009 | 06:04 PM
weslutes's Avatar
weslutes
Most stock APS kits made decent power.
I added a FRS and it actually lowered my whp potential but I still ended with a conservative 400whp.
Maybe compression is a factor in the equation?
sherm
Apr 11, 2020 05:21 PM
