Forged Built Twin turbo, HTA turbo's! (gone bad) ~g35driver import~
Old Jan 5, 2010 | 06:17 AM
  #101
CRIDDA's Avatar
CRIDDA
Glad to see this baby gets to be back home with daddy. Now go beat on it like a red headed step child
Old Jan 10, 2010 | 04:46 PM
  #102
IslandZavage's Avatar
IslandZavage
Bump for updates/review of the HTA upgrades.....
Old Jan 12, 2010 | 04:06 AM
  #103
Alberto's Avatar
Alberto
Cranky FI Owner
+1 for updates on those snails
Old Jan 12, 2010 | 05:21 AM
  #104
IIQuickSilverII's Avatar
IIQuickSilverII
lol...just when it looked like you were done...eye balling 2010 mods huh
Old Jan 12, 2010 | 09:04 AM
  #105
scout1669's Avatar
scout1669
Well i spoke to sharif yesterday while he was on the dyno. They definitely spool slower then the 18g's i believe he said they hit full boost at 4500. He's got a wastegate (16lb) base tune putting down 540whp and we've decided to pull the meth and go med boost pump then high boost c16. I'd imagine today or tomorrow we'll have some more info.
Old Jan 12, 2010 | 09:17 AM
  #106
IslandZavage
what specific upgrade did u get? from my understandings theres a few HTA options.. some for faster spool, and some for bigger power... im guessing u went the power route?
Old Jan 12, 2010 | 09:35 AM
  #107
scout1669's Avatar
scout1669
well aniel pagan told me i was getting the 82Hta upgrade but on the invoice sharif sent me it said 76hta. SO i'm not really sure, i'm leaning towards sharif being the accurate one. I'm sure he'll chime in here.
Old Jan 12, 2010 | 09:55 AM
  #108
IslandZavage
which one did u ask for? from my understanding the 82 will spool slower but give more hp.. i was looking at 72 or 76.
Old Jan 12, 2010 | 10:17 AM
  #109
str8dum1's Avatar
str8dum1
540 @ 16 psi seems like pretty standard/below average greddy numbers on the DD. maybe they need higher boost to show improvement...
Old Jan 12, 2010 | 12:10 PM
  #110
Jtran Studios's Avatar
Jtran Studios
Vendor - Former Vendor
^^^turbos gotta spool a little bit more to be in its effciency range. we hit 558 whp on our mustang dyno on the 72 or 74 hta upgrade on 17 psi from forced over the weekend @ 6100 to 6200. spool is def. later but its more managable on the street. we are gonna be turning it up to right about 21 to 22psi this friday and see what it will do.
Old Jan 12, 2010 | 12:23 PM
  #111
str8dum1's Avatar
str8dum1
no one seems clear what the upgrade is? just a bigger turbine shoved into the stock housing?
Old Jan 12, 2010 | 12:29 PM
  #112
eltness350's Avatar
eltness350
The Untouchable
for reference on sharifs dyno i did 500rwhp at 13psi with the greddy 18g kit
Old Jan 12, 2010 | 01:20 PM
  #113
rrmedicx's Avatar
rrmedicx
In for results and better details on specifics of upgrades...hopefully.
Old Jan 12, 2010 | 03:25 PM
  #114
tig488's Avatar
tig488
iirc, its got an extra blade, as well as less material, so much lighter.
Old Jan 12, 2010 | 03:46 PM
  #115
IslandZavage
def in for updates.. pls tell me you'll keep us posted.. what are your initial impressions of the upgrade so far?
Old Jan 12, 2010 | 04:33 PM
  #116
D350Z10's Avatar
D350Z10
Your order was for the 76hta, Brian over at forced is the one who built the turbos. Aniel is just a salesperson.
Old Jan 12, 2010 | 05:29 PM
  #117
04G35tt's Avatar
04G35tt
These are the upgradesthey offer for the Greddy Turbos:
Upgrade TD06 to 68mm Compressor HTA
Upgrade TD06 to 76mm Compressor HTA, 67mm Turbine
Upgrade TD06 to 82mm Compressor HTA, 67mm Turbine
Mine are being upgraded to the 76mm as we speak. The email I got said upgrade TD06 not TD05, so I don't know if they upgrade the cover or if the upgrade is the same for the TD05s and the TD06 compressor housing and they just list them together. I couldn't get inducer and exducer sizes from Aniel, but based on the standard comp/turbine wheels the 18g comes with I guessed that the numbers are for the exducer on the comp and inducer for the turbine. I went off of Sharif's thoughts on the upgrade based on Scout's Z and went with the 76 HTA.
Old Jan 12, 2010 | 05:33 PM
  #118
IslandZavage
What did he say?
Old Jan 12, 2010 | 05:40 PM
  #119
str8dum1's Avatar
str8dum1
so the 76HTA some sort of bastard GT3076 compressor with a GT35r turbine
The 82HTA is just a GT3582.
be interesting to see the housings. big wheels, small housings = ????
here's a typical 3076 setup.
https://my350z.com/forum/shop-builds...p-563rwtq.html
Looks right on par with that 550 at 16psi Scout is making with a DJ>DD conversion
Old Jan 12, 2010 | 05:57 PM
  #120
04G35tt's Avatar
04G35tt
IslandZavage-
I can't remember exactly what was said, so I will let Sharif give his opinions on the turbos, but they were positive.
str8dum1-
Aniel said that the housing had to be machined and to make sure the threads/studs on the turbine housing were in good shape and not stripped so they can bolt it done to machine it correctly.
I beleive I read somewhere that the A/Rs for the greddy turbos are as follows:
8 cm- .57 A/R
10 cm- .73 A/R
12 cm- .89 A/R
14 cm- 1.05 A/R
so it should sppol a little quicker than a GT3076 with the .64 A/R, as long as they keep the TD05 comp housing and just machine it for the bigger wheel.
