07 built GTM stage 2 Turnkey: "Service engine soon"-light is on. What to do now?
Old Jan 1, 2010 | 07:41 AM
Germanguy's Avatar
Germanguy
Originally Posted by Sam@GTM
Alex
The turbo kit came with the programing cable, this cable gives you the ability to pull codes in case the check engine light come on.
There is not even one justifiable reason for the light to be on , if the light is on then something is wrong which means the system is working
pull the codes, e mail them to us and we will get you squared away .
Sam
Thank you very much, Sam. So I just need my z, the cable out of the turnkey box and a laptop? No software, which I would have to download from a site in the www ?!
Alex.
Old Jan 1, 2010 | 07:44 AM
Germanguy's Avatar
Germanguy
Originally Posted by GreenGoblin
lol same here, removed evap system, o2 cels, tire pressure, winshield wiper resivor gone... its christmas all year on my dash lol
how to remove tire pressure? : ) Its the other light which burns after I put my 265/295 Volks Sf-Challenge on.
Old Jan 2, 2010 | 05:16 PM
mikedbz's Avatar
mikedbz
If you got tpms sensors in your new wheels, any Nissan/Infiniti dealer can calibrate the sensors to your car so the functionality is restored. I think its a nice feature to have.
Old Jan 2, 2010 | 07:33 PM
QuadCam's Avatar
QuadCam
Originally Posted by djamps
Depending on what code you're throwing it might or might not be a big deal. Catalyst code you could probably ignore it... random misfire not a good idea to ignore.
They make non foulers for your test pipes BTW (I'm sure you know that, but just for others who are curious) that will stop catalyst codes.
Random misfire is fixed with proper plugs, gapping, and tune.
Everyone gets the random cylinder misfires.....they are no big deal. That's code P0300. the problem is if you have an individual cylinder misfire code.
Old Jan 3, 2010 | 08:25 AM
djamps's Avatar
djamps
Not everyone gets those, and neither do I, not once. My observation is that if your car is misfiring enough to trigger 0300 (and it takes on-going regular misfiring, not just an occasional glitch) you need to go get your tune fixed.
Old Jan 3, 2010 | 09:06 AM
Jay'Z's Avatar
Jay'Z
Alex.
To use your Osiris/Cipher Software you have to go to www.uprev.com and download the Osiris Tuner Installer. Once you have done that you can plug in the Osiris Cable to the car then your laptop and pull the code. You can email or call Sam@GTM all of your problems.
Old Jan 3, 2010 | 09:27 AM
G Coupe's Avatar
G Coupe
+1 I get the random missfire code every now and then as well...my car is perfect everything checks out normal.
Old Jan 3, 2010 | 09:33 AM
Jay'Z's Avatar
Jay'Z
p0300 is a good code to get btw.. It means your FI..
Old Jan 3, 2010 | 09:38 AM
cdoxp800's Avatar
cdoxp800
Alex.
Here you go Alex
Download Cipher:
Cipher V1_03 Installer.exe (203.4 MB)
Use the cable thats was provided by GTM in your Kit. It's real easy to use. There are instruction included in the downloaded file.
Also see UpRev FAQ:
http://www.uprev.com/faq.php
This should help you out.
C
Old Jan 3, 2010 | 09:42 AM
Jay'Z's Avatar
Jay'Z
^I posted that above..
Old Jan 3, 2010 | 09:56 AM
UMW350Z's Avatar
UMW350Z
Originally Posted by jeffie7
Not running cats can cause a check engine light on both stock and utec ecus
My check engine lights been off for awhile but it never surprises me if it comes on.
I had that cat welded in an I just get a/f sensor codes most likely from the car idling rich. I beat the cat code and should beat the sensor code when i get a touch-up this spring
Old Jan 3, 2010 | 10:08 AM
Germanguy's Avatar
Germanguy
Woooow, thank you. Dont have the Z around here. Im very interested what my Z will say with the cable the the cipher software .
Do I have to pay attention to something, if I plug my laptop with cipher in the Z? Dont want to kill my tune .
Thanks,
Alex.
Old Jan 3, 2010 | 10:21 AM
cdoxp800's Avatar
cdoxp800
Thanks,
Alex.
No.. The first thing cipher will do is pull the codes once you click connect. You can not mess anything up.
Old Jan 3, 2010 | 10:44 AM
jeffie7's Avatar
jeffie7
I'm not saying you can't do anything to cause it to not throw a code, but for most people who just put test pipes in or turbo their car with the basic parts given to them they throw codes, and that's A LOT of people.
Is there a way to do it right? yes. Saying that no codes should be thrown is not correct for a lot of people who if they dont know any better would read this thread then get worried that their car is going to blowup.
Old Jan 3, 2010 | 10:56 AM
Germanguy's Avatar
Germanguy
Fine. Got the Software. Sadly the Z is a bit away from me . I will tell you guys what code my baby got. Software and manual seems to me not as difficult as I thought
Thank you.
Alex.
Old Jan 3, 2010 | 01:47 PM
djamps's Avatar
djamps
On the other hand, if they get complacent about the light they won't know if a more serious code pops up -- you could have 1 code or 100 codes... same light. If you can't tune out a constant code, have the codes deleted so if you actually do start having a constant SES you know to get checked out.
I agree that an occasional light is probably nothing to worry about though. But having it on 24/7 is negligent if you're not scanning it regularly.
Old Jan 3, 2010 | 02:03 PM
Jay'Z's Avatar
Jay'Z
You should always clear the codes at least weekly for piece of mind IMO.
Old Jan 6, 2010 | 01:27 PM
  #38
jeffie7's Avatar
jeffie7
Maybe I'm the only one but the only lights/gauges I care about on my dash are.
Low Oil light
Oil pressure
Water temp
A/F
Boost
Check engine light has never meant anything to me.
any random sensor really doesn't bother me, if one goes bad chances are the car will go into limp mode, for the most part it's a dummy light, is there any sensors that could go bad that the stock ECU reads that could cause a major engine failure? I don't think there is.
Correct me if I'm wrong and yes there's a good chance that I am wrong lol. Please just don't say because they're there for a reason......
Old Jan 6, 2010 | 04:35 PM
  #39
rcdash's Avatar
rcdash
Well I suppose if you are misfiring or if a wire has been burned through that might be good to know and the CELs can be helpful in tracing the source of the problem when you do experience issues that affect the car's driveability. I'm pretty sure the GTM reflash disables those CELs that are irrelevant to that particular build (e.g. for a cat-delete, the cat efficiency codes are disabled). Thus if the CEL light does come on, then it should be relevant.
Old Jan 6, 2010 | 06:41 PM
  #40
ashtrojan2008's Avatar
ashtrojan2008
the only time i had a random misfire code was when my stock engine was blown (no compression in cyl 2) i was blowing oil EvErYwHeRe
14 (ish)psi + 500(ish)whp + No Codes = (just switched to haltech so not sure on #'s)
Except that damn air bag light won't go away....
EnjukuRacing
Sep 30, 2015 06:55 AM
