Water problem need help
Old Jan 2, 2010 | 04:17 PM
TWINTURBOZ350's Avatar
TWINTURBOZ350
Default Water problem need help
I have a 04 350z twin turbo and every time i wash my car i get a puddle of water in the driver and passenger floor then i have trouble starting up the car and white smoke comes out of the exhaust
Old Jan 2, 2010 | 05:29 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
pull your wipers off and all the black plastic parts under them there are 2 big plug covers there One is for the ECU the other is part of the body harness. they are probly just no set in correctly.
Old Jan 2, 2010 | 05:34 PM
diablox1's Avatar
diablox1
https://my350z.com/forum/forced-indu...eedn-help.html
Old Jan 4, 2010 | 12:07 PM
TWINTURBOZ350
thx ill try it out
Old Jan 4, 2010 | 05:21 PM
Sylvan Lake V35's Avatar
Sylvan Lake V35
+1 i had the same problem but just the passanger side. i was using the foam brush at the car wash and looked where the foam leaked in and traced it back to the grommets that the ECU wires come through the fire wall at.
Old Jan 7, 2010 | 11:04 AM
widerisbetter's Avatar
widerisbetter
I also had this problem. instead of taking the time to route the wires to the ECU through the original gromet hole, they just cut the gromet(more like a boot) in half and ran the wire that way. What I did was reseat the "boot" and put a large hose clap around the the boot where it seats into the flange. Then used ALOT of gasket sealer to seal the boot up. To test for leaks I left a hose running on various angles all over the windshield area and it was sealed with no problem!! Theres a large harness under the passenger side dash on the side wall infront of the door. Chances are water is getting in the wiring and causing resistive values to change, thus the ECU compensates with fuel, air, timing changes etc...
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
