Haltech Output Wire
Old Jan 13, 2010 | 04:53 AM
str8dum1's Avatar
str8dum1
why do u have generic output as one of your criteria to turn on the generic output??
Old Jan 13, 2010 | 06:53 AM
rcdash's Avatar
rcdash
Well crap, I better go test this now with v1.06. Mr Rizk, did you inform Hal already?
Old Jan 13, 2010 | 01:53 PM
MR RIZK's Avatar
MR RIZK
It is so that it allows the fans to come on at 90 and then stay on until it drops to 82 Otherwise the fans would
come on at 90
turn off at 89
come on at 90
turn off at 89
Which would kill your fans pretty quick.
It is something called hysteresis I *think*. (I learnt this new word from the guys at haltech)
I posted a thread on the haltech forums to see if there is a response.
Old Jan 13, 2010 | 03:07 PM
str8dum1's Avatar
str8dum1
neat.
is there somewhere you read how to manipulate commands like that?
cant wait for an input/output box cuz then you could have all sorts of nice warning lights using that function
Old Jan 13, 2010 | 08:11 PM
deanfootlong's Avatar
deanfootlong
Originally Posted by MR RIZK
Deanfootlong,
I had the first gen red box ECU with v1.0 of the firmware and had it setup to turn on my thermo fans via the IPDM which requires a ground trigger like that is outputed via the Haltech. This worked perfectly and was setup like the image attached allowing the fans to come on 90 and then stay on until temp dropped to 82.
I received a new silver unit with 1.06. Configured the same and had the same issue as you. The ground output was always grounded and hence my fans would come on straight away.
Not the answer you are after but hopefully puts your mind at ease as your not the only one having this issue.
interesting. so you are still having this problem? or you resolved it somehow?
Old Jan 13, 2010 | 10:38 PM
MR RIZK's Avatar
MR RIZK
I disconnected it in the hope a firmware revision would fix it since it was not critical.
Old Jan 14, 2010 | 08:43 AM
deanfootlong
interesting. im interested to know the difference between how firmware 1.0 and firmware 1.06 controls the output wire.
Old Jan 14, 2010 | 10:39 AM
str8dum1's Avatar
str8dum1
the previous firmware was 1.04. Have you tried even upgrading to that from 1.0?
Old Jan 14, 2010 | 02:46 PM
MR RIZK's Avatar
MR RIZK
I don't want to upgrade the old unit as I do not have the orginal firmware incase I wanted to downgrade it.
I will down grade the 1.06 box I have to 1.04 and test still wont be conclusive but if it works it would be a bonus.
At the end of the day we are assuming it is the firmware but it also could be the harness.
Old Jan 14, 2010 | 04:08 PM
str8dum1's Avatar
str8dum1
i really meant that for the OP, but be intersting if it works for you as well
u used a new harness with the silver box as well?
Old Jan 15, 2010 | 08:22 AM
deanfootlong
i am currently using 1.04. still havent even upgraded to 1.06 yet.
Old Jan 15, 2010 | 10:13 AM
str8dum1's Avatar
str8dum1
so at least in your case its not a firmware issue...
are you just goin to send it in to Hal for repair?
Old Jan 18, 2010 | 12:01 AM
MR RIZK's Avatar
MR RIZK
Results from my testing
New harness on new ECU - Constant ground
Old harness on new ECU - Constant ground
Old harness on old ECU - Works fine
New ECU = Silver box with 1.06
Old ECU = Red box with 1.00
New Harness = With O2 break out
Old Harness = Without O2 break out
So from the above the issue would lie in the firmware or the box.
Old Jan 18, 2010 | 05:39 AM
str8dum1's Avatar
str8dum1
surprised Hal hasnt had much to say on here.
Old Jan 18, 2010 | 08:28 AM
deanfootlong
im emailing him the link right now.
Old Jan 18, 2010 | 08:57 AM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
Deanfootlong:
I just pulled one of the emails we exchanged, where I loaded your map into an ecu I had on the bench. The map you supplied that was giving you trouble was 1.04, same as the firmware you were running.
If there is something going on with 1.06 I am happy to test and work on that, but first, you have a problem with your wiring configuration being that it would not work with a tested-good 1.04 map/firmware.
"I just setup the test bench with your map loaded into an ecu running 1.04 firmware. When I powered up the ECU, the output was not active - shown both in the software and verified with a continuity tester on the output to ground.
To verify the continuity test and the function of the output, I modified your map to turn the output on when RPM under 3300. After restarting the ecu to make the changes take effect - the output was active (grounded) verified both in the software and with the multimeter setup.
I have attached the modified map I used for testing.
It sounds to me as though you have something wrong with your relay/wiring setup. "
Old Jan 18, 2010 | 09:15 AM
deanfootlong
any suggestions for rewiring it a different way? i have it wired how you instructed. i'll try 1.06 and report back soon.
Old Jan 18, 2010 | 09:23 AM
  #38
Dynosty's Avatar
Dynosty
^ If it doesn't work with 1.04 (which we know works), there is no sense in changing to 1.06.
If you feel confident that your wiring is correct, feel free to send the unit in for inspection. Contact Ryan here at Injected Performance (859-224-0461) for shipping/inspection details.
Old Jan 18, 2010 | 09:39 AM
  #39
deanfootlong
i plan on sending it to you when I swap my motor. for now it'll have to wait as its my semi-daily driver. how about the other guys problem in this thread? and suggestions for him?
Old Jan 18, 2010 | 09:54 AM
  #40
Dynosty's Avatar
Dynosty
^ MR RIZK deals directly with Haltech Australia. While he may be on current firmware now, he is often on beta items which we do not offer support for, in that circumstance. His ECU was never distributed through us or Haltech USA, and as such, may not have comparable experiences or solutions.
