Haltech Output Wire
Old Nov 6, 2011 | 09:13 PM
  #61
mx594's Avatar
mx594
Originally Posted by Hal@Dynosty
^For what it's worth.. I am using the top clutch switch, which works great for slipping the clutch on a launch while using the twostep. As soon as the clutch is fully released the twostep disengages - perfect!
I am also curious as to how you got this to work without causing issues on every gear shift? Are you using the generic output to make the 2 step conditional like I am trying to do?
Old Nov 6, 2011 | 09:41 PM
  #62
MR RIZK's Avatar
MR RIZK
Originally Posted by mx594
When the generic output is active, it reads continuity to ground but it shows ~75 ohms. When the generic output is NOT active, it is exactly the same. So as far as I can tell the generic output does nothing. When I turn the key off and the Haltech shuts down a few seconds later, the resistance to ground through the output wire drops to ~0.3 ohms.
You are not the only one. There are at least another few threads that report this and mine also does the same. I just gave up.
IMHO just buy the CAN module and use that. Save your time and sending the unit for repair takes a long time from experiences of other Z owners. Last thing you want is for it to come back and say "all ok" but have the same issue.
Old Nov 7, 2011 | 05:30 AM
  #63
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
^ I use it as no-lift-shift as well, so no problem between gears. I could see how you would need conditional control if it was set low and/or shifting very slowly - but for performance use, no. I have upgraded my personal car to 1.10 as well, but have not been to the track since then to test.
Old Nov 7, 2011 | 05:55 AM
  #64
str8dum1's Avatar
str8dum1
What is different about the CAN system in the G35??? I remember the original firmware did not see the G35 wheel sensors either. Haltech had to release a new firmware. But its always working on the 350z.
Hal do you know what was originally adjusted in the updated G35 firmware to get the wheel speed sensors to read?
I tried 1.10.1 firmware yesterday. Not only does the output still not work properly, but with 1.10.1 my CAN wheel speed sensors stopped working altogether. So I am back on 1.06.2 which is what Hal sent me months ago and is the only firmware I have ever tried which actually had working wheel speed sensors.
Old Nov 7, 2011 | 06:09 AM
  #65
Dynosty's Avatar
Dynosty
^ They are on different CAN channels. Haltech has them both incorporated.
Old Nov 7, 2011 | 02:51 PM
  #66
mx594's Avatar
mx594
I see. Thanks for the info - as usual you have all the answers to my questions!
Two problems with the CAN module:
  1. Its over $400
  2. It requires the use of firmware 1.10 or higher, which will disable my wheel speed sensors so I would be worse off than I am now.
And it just pisses me off - even if firmware 1.10 worked I wouldn't shell out another $400 to make the ecu do something that it is supposed to do already.
Old Nov 7, 2011 | 02:56 PM
  #67
mx594's Avatar
mx594
I guess in the mean time what I will do is exactly what Hal is doing, and wire it also to a toggle switch so I can deactivate it completely for "normal" driving. Either way, the G is away for winter so I have a few months to think about it.
Old Nov 7, 2011 | 04:06 PM
  #68
MR RIZK's Avatar
MR RIZK
If indeed the wheel sensors are not working for all G owners with 1.10 then I would assume Hal and Haltech will get this sorted out pretty quick with a point release.
The question here is if this is true after such a long time for release you would have hoped the QA would have picked this up.
Old Nov 14, 2011 | 08:55 AM
  #69
str8dum1's Avatar
str8dum1
any update? wheel sensor or lineout?
Old Nov 14, 2011 | 12:22 PM
  #70
rcdash's Avatar
rcdash
My CAN data is working fine with 1.10. Wheel speed, vehicle speed, etc...
Old Nov 14, 2011 | 04:27 PM
  #71
Dynosty's Avatar
Dynosty
Thanks for posting - I thought this was the case.
350Z_Al
Oct 29, 2020 07:44 PM
nanotech
Oct 2, 2015 05:02 AM
