And so it begins...Finaly!
Old Mar 22, 2010 | 08:03 PM
  #101
CAB350z's Avatar
CAB350z
Okay so drivers turbo is in... sorta... Got over one problem to hit another
The turbo doesnt sit far enough over... OR high enough to clear the clutch line...
IDEAS PLEASE
Old Mar 22, 2010 | 08:25 PM
  #102
Sylvan Lake V35's Avatar
Sylvan Lake V35
Originally Posted by CAB350z
IDEAS PLEASE
Sell the kit buy one that fits better I thought SFR was better than this they look like they have some nice products. Although when I tried buying the twin throttle intake a couple years ago the customer service was painful i never did get the answers I needed.
Sorry to hear about your dad I hope he is doing ok and i hope things start to go better on the TT install.
Old Mar 23, 2010 | 03:31 PM
  #103
CAB350z's Avatar
CAB350z
Any one please? Can i move the clutch line or relocate it? or even just lower it abit?
I could really use help on this one
Old Mar 23, 2010 | 03:46 PM
  #104
str8dum1's Avatar
str8dum1
really? thats simple
just undo the clip holding the line to the flat mount. that will let u pull the hardline thru the hole and give you all the room you need.
Old Mar 23, 2010 | 04:15 PM
  #105
Sylvan Lake V35
Get it made into a flexable steel braided line or if you have the flare tool you can build a hard line. I crushed my PS hard line when installing my engine all it took was some tubing and a flare tool to make a new one I cut the old one and reused the end nuts.. If you take the hard line to a hose shop I am sure they can make you a steel braided one with the same ends or a hard line that is a little longer and you can bend it yourself to fit properly.
Old Mar 23, 2010 | 07:30 PM
  #106
CAB350z's Avatar
CAB350z
TODAY was full of win. Took The clamp out , everything fell into place... for the most part. LOOK! Both turbos are in, and for the most part hooked up, all that needs to be done is intercooler piping, charge piping, fuel pump and electronics.... pictures
Btw Rich I solved that problem... i may only have 2-3 mm of clearance but its still clearance !
However there was not all win...
For some reason they put thread sealer on this piece and it would not turn properly unless it was removed... I tried to remove it and this
Happened. Retrospect i probably could have just moved a pulley but this seemed like less work...
Oh well.. Off to mopac I go that is all for now
Old Mar 24, 2010 | 04:35 AM
  #107
superchargedg's Avatar
superchargedg
Damn Noobs
Looks like your making some good progress and hope to hear her running soon.
Old Mar 24, 2010 | 12:26 PM
  #108
CAB350z's Avatar
CAB350z
So a bit of work before school today
Intercooler on /check
Oil supply feed to the turbos, check
Old Mar 24, 2010 | 03:42 PM
  #109
Sylvan Lake V35
Nice to see
Old Mar 24, 2010 | 05:20 PM
  #110
str8dum1's Avatar
str8dum1
Looking good, making very fast progress
pic from 2 months ago. almost the same but my bumper brace doesnt fit back on
Old Mar 24, 2010 | 05:31 PM
  #111
Chris@FsP's Avatar
Chris@FsP
Vendor - Former Vendor
Do you have a build thread somewhere, str8dum?
Old Mar 24, 2010 | 05:34 PM
  #112
Sylvan Lake V35
I think he is waiting till the build is 100% wrapped up to avoid the Sylvan/Cass fail thread situation
Old Mar 24, 2010 | 07:00 PM
  #113
str8dum1's Avatar
str8dum1
lol, ya gotta get my Haltech sorted 1st, so I'm just tryin to help Cab350z along thru a tedious install.
Old Mar 25, 2010 | 10:06 AM
  #114
CAB350z's Avatar
CAB350z
Why is your intercooler sitting much lower then mine?
Edit: it might just be the pictures but it still looks lower...
Rich, For the oil pump did yours fit right in... or did you have to drill holes?
Old Mar 25, 2010 | 10:14 AM
  #115
Boosted Performance's Avatar
Boosted Performance
That does sit low, this is what my looks like:
http://i137.photobucket.com/albums/q...D/S1031600.jpg
The lower port (inlet in my case) just clears the bumper and have just enough room for the splash guard.
Old Mar 25, 2010 | 11:50 AM
  #116
str8dum1's Avatar
str8dum1
ya its low. on my todo list of things to modify but not a priority. Those welded tabs on the back of the IC pretty much dictate where the IC sits and my end tanks are differnt than yours.
But ya, the way it is now, I cant use my undertray.
You'll need to use some self tappers to mount the pump.
Old Mar 25, 2010 | 05:11 PM
  #117
CAB350z's Avatar
CAB350z
This thing. Oh man, this thing. PITA. I almost hulked out and ripped it in two. Holy hell, this frustrated me more then any other piece of the install.
Do not need to worry about it now though.
The Scavenger pump was much easier then i thought it would be.. My only concern though is that it i wont be able to get the plastic covers back over.
It doesnt look like i will be able to get the starter ground back on.. is there another way i can reconnect it?
Old Mar 25, 2010 | 08:36 PM
  #118
CAB350z's Avatar
CAB350z
So the passenger turbo side is full mounted....
and I had to get creative with an old Nismo CAI that I had... SFR gave me the wrong length pipe OR flex tubing, i dont know which but it was actually not a hard fix.
Old Mar 25, 2010 | 08:48 PM
  #119
Boosted Performance
I really hope you have that car supported better than just that jack on the lower control arm.
Old Mar 25, 2010 | 11:29 PM
  #120
CAB350z's Avatar
CAB350z
No... there are 4 jack stands... each on a control arm.
I took them down for that picture but there are also cinder blocks placed strategically too
