And so it begins...Finaly!
Old Jan 9, 2010 | 02:13 AM
CAB350z's Avatar
CAB350z
Default And so it begins...Finaly!
Alright so those of you who know me, know i purchased a turbo kit way back in September. After a long wait on deliver it came, and right as i started to get it my truck gave out and I was with out a daily driver/ vehicle i could use to drive to work/ school.
So realizing that it would cost to much to fix me and my buddy decided to sell it/junk it. On dec16th I bought a brand new truck (2010 tacoma 4x4) and just as we were about to start work on the car some one turned into me as I was entering an intersection (On boxing day, less than 600k on the truck). Police deemed it his fault but this is the after math... first two are my truck the third is his car.
Well i just got the rental and i started the work on car, its gonna take a while as i work 4 days a week and have school 4 days a week as well.
But my build so far for engine:
SFR Kit
60 - 1 t3/t4 turbos
Cosworth intake plenum
HKS exhaust
and here is my baby, she is very dirty as I live in calgary and i had to drive her in the slush the past few days. I will update as much as I can as soon as I start installing stuff.
Old Jan 9, 2010 | 04:34 AM
duro78's Avatar
duro78
Damn brand new truck totalled that sucks. Why did you buy a new truck instead of a cheap beater. The way cars are depreciating really doesnt make sense buying a brand new car
Old Jan 9, 2010 | 04:47 AM
0jiggy0's Avatar
0jiggy0
Fukin sucks about the truck. But GL on the Z.
Old Jan 9, 2010 | 05:39 AM
Cass007's Avatar
Cass007
GL on the build and better luck with the new DD.
step 1 - Buy a better camera
step 2 - Clean the leaves out of the cowl
Old Jan 10, 2010 | 10:56 PM
CAB350z's Avatar
CAB350z
Got a really sweet deal on the truck, and i will buy a new camera.
However Ive hit my first snag with the vehicle. As i was taking of the intake and preparing to take off the plenum i discovered my strut bar wont budge. Now I am not a small person and I cant get the screws to move...I had a 220ft lb impact gun on it they didnt move. Any suggestions? The only one i can think of is move to a much stronger impact gun... good or bad?
Ps Nissan was the last one to have the vehicle (needed a new engine) and i figure they over torqued everything
Old Jan 10, 2010 | 11:02 PM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
WD40 and ***** is all u need. Get rid of the HKS exhaust and everything else looks good. Sorry to hear about ur loss with vehicles
Old Jan 10, 2010 | 11:05 PM
shezzzhot's Avatar
shezzzhot
Abzolutely Zexy
I luv F/I!!
GL w/ build.
Old Jan 11, 2010 | 12:41 AM
bullant47's Avatar
bullant47
Default Strut Bar
Have you shortened the length of the strut bar with the centre adjusters. I may take the pressure off the bolts holding the bar on. I've seen it before.
Ken
Old Jan 11, 2010 | 02:22 AM
rcdash's Avatar
rcdash
There's nothing that a 2-3 ft long breaker bar can't open, easily. Unless you have air tools, it's the only way to go. Which EMS?
Old Jan 11, 2010 | 05:32 AM
Chris@FsP's Avatar
Chris@FsP
Vendor - Former Vendor
Get a bigger gun
Old Jan 11, 2010 | 05:38 AM
str8dum1's Avatar
str8dum1
ya I use the 500 ft-lb snap on one at 140psi and it takes everything off.
have fun with that install. you'll want to remove the coolant pipes on both sides and the rear of the motor to have enough clearance to get at the headers and wastegates. Make sure you have the wastegates on beforehand. have fun running the charge pipes between the frame rail and the steering column.
Old Jan 11, 2010 | 05:46 AM
XKR's Avatar
XKR
Good luck.... Keep is updated
Old Jan 11, 2010 | 10:31 AM
CAB350z's Avatar
CAB350z
Just an FTC for now
Old Jan 11, 2010 | 10:45 AM
ADMAN's Avatar
ADMAN
Congrats
Old Jan 11, 2010 | 11:29 AM
350z spd's Avatar
350z spd
Just be careful on all of that so you dont strip anything. When I went to put my turbo kit on Nissan had just replaced my motor 3,000 miles prior and everything was way over torqued. Good luck
Old Jan 11, 2010 | 03:14 PM
UMW350Z's Avatar
UMW350Z
Boxing day? Kilometers??? I CAN'T CONVERT THOSE TO STANDARD MEASUREMENTS!
I had a Canada-spec Ford Aerostar as my true beater 2 years ago. Gotta love it when people freak out when you are 'doing 120' according to the spedo
Old Jan 11, 2010 | 03:18 PM
DB350's Avatar
DB350
I don't think your z wants to be turboed
Old Jan 11, 2010 | 03:42 PM
BoostedProbe's Avatar
BoostedProbe
For some reason I found that very funny.
Old Jan 11, 2010 | 05:39 PM
Sylvan Lake V35's Avatar
Sylvan Lake V35
Made me laugh as well.
I hope the rest of the install goes better than the strut bar removal, If you drive your car in the winter you might have lots of stubborn nuts/bolts.
Old Jan 11, 2010 | 06:14 PM
CAB350z's Avatar
CAB350z
Yea unfortunately i had to drive it in the two really bad storms that hit Calgary... so there are a few stubborn ones on the underside. But today I picked up a larger breaker bar and bolts came off easily. I also made my way to the plenum and got that out of the way... Hopefully after I go out for dinner tonight i can make my way back to switch out injectors. Btw there is significantly less coolant in the vq then there was in my 1990 4runner. I thought that to be a bit odd.
Regardless- Pictures:
Please note... better camera
Right side injectors:
Left side injectors:
