Crank pulleys
Old Apr 27, 2010 | 09:04 AM
  #41
jonnylaw's Avatar
jonnylaw
Originally Posted by Z1 Performance
If you call ATI, they will verify exactly what I have posted and measured. Belt sizes are totally different from stock as a result
So you do have the 6.78" street damper pulley? The 6.32" is a race versionand deletes the ac pulley.
Old Apr 27, 2010 | 09:06 AM
  #42
jonnylaw's Avatar
jonnylaw
they will - it will end up costing around $1000 though by the time it's said and done though
I'm on the phone with them right now..
It seems this or just puttung back the oem crank pulley may be the best way to ensure my blower is not overspinning. Changing the SC pulley from the 85mm to the 95mm does not make enough difference on the calculator. What do you think?
The pulley has an inside and an outside shell. Maybe can keep the inside shell and replace the outside shell with a smaller diameter. They said they will get back to me with what they can do and the price...
Old Apr 27, 2010 | 09:22 AM
  #43
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
I presume I have the same one everyone else does - my A/C and P/S are still intact and fully functional, nor have I altered the factory idler pullies in any way
Old Apr 27, 2010 | 10:23 AM
  #44
jumbosrule's Avatar
jumbosrule
I have the Fluidampr crank pulley - no issues.
I have also researched quite a bit and also came to the conclusion that Fluidampr has a more efficient design.
ATI's design is completely mechanical/rubber and works better at higher RPMs than at lower RPMs. Of course - vibration at lower RPM is not as harsh as at higher RPMs, so this might not be a negative for most people.
Since the Fluidampr uses a fluid damping method - it works better across the RPM range as a whole. But if you compare ATI to Fluidampr, performance is close to the same.
I have never heard of any issues coming from the Fluidampr or the ATI, it's always user/installation error. IMO - you really can't go wrong with either one.
Old Apr 27, 2010 | 10:31 AM
  #45
jonnylaw's Avatar
jonnylaw
I'll probably have a ATI damper for sale soon, since I'll likely put back on a new oem crank pulley to get my blower back in its efficiency range/not overspin.
Old Apr 27, 2010 | 07:41 PM
  #46
jonnylaw's Avatar
jonnylaw
Ok, so I'm a little confused on how the OD is measured and stated with the ATI/Fuildampr and the stock piece.
Basically, for calculating impellar speed, I need to know the diameter of the pulley where the belt runs, That is, at the top of the belt lands. Not the bottom of the vees, not the outer edges of the pulley where the lips are high to keep the belt from walking off:
http://www.928motorsports.com/servic...our-pulley.jpg
http://www.928motorsports.com/servic...ingpulley.html
So, when people say the Stock diameter is 5.75" and the Fluidampr OD is 6.5" and the ATI is 6.78", is the diameter being measured like above, or is it being measured straight across the face with the higher lip (not the measure I am looking for)?
If someone has a OEM, Fluidampr, or ATI unit handy and can properly measure it, described in the method above, or straight across to see which stated diameter is being referenced I would appreciate it!
Also, I'm sitll confused on the Fluidampr. If it is 3/4" larger than stock, how can you retain the stock belts? This is why I am asking to see how the stated diameter is measured.
thx.
Old Apr 27, 2010 | 07:44 PM
  #47
jonnylaw's Avatar
jonnylaw
Originally Posted by Glex25
^I haven't added the accessories but i put the pulley face to face and they seemed the same diameter.
I will try to post pictures once I take out the other motor and show the difference between stock and the fluidampr
If possible, can you measure your Fluidampr in the method I described above, or simply straight across the face to see which way the stated diameter of 6.5" is being measured?
thx.
Old Apr 27, 2010 | 07:58 PM
  #48
jonnylaw's Avatar
jonnylaw
Also, does anyone know how well the oem crank pulley will hold up to ~400/400. I'm not sure which would be better, protecting the crank more, or ensuring that my SC is not overspinning..
Old Apr 27, 2010 | 08:23 PM
  #49
Glex25's Avatar
Glex25
I tried taking it as close as possible
I also did across the face and it came out to 6.25"
Old Apr 27, 2010 | 09:54 PM
  #50
IIQuickSilverII's Avatar
IIQuickSilverII
^^ this...
Old Apr 28, 2010 | 04:33 PM
  #51
Glex25's Avatar
Glex25
Took some more pictures with a skinnier measuring tape
Old Apr 28, 2010 | 07:07 PM
  #52
Elperuano's Avatar
Elperuano
At what horsepower should this be considered a necessity? Im assuming stock blocks won't really see much of a benefit from this but its comforting to know that this'll cause less strain on my crank if i were to get it... FI wise
Old Apr 29, 2010 | 06:16 AM
  #53
str8dum1's Avatar
str8dum1
the stock pulley is balanced for the stock redline. if you plan on exceeding that, then a aftermarket dampened pulley is a good idea.
Old Apr 29, 2010 | 08:30 AM
  #54
nyqueenz's Avatar
nyqueenz
Fluidampr thats what i have. limits vibration from the crank.
Old Apr 29, 2010 | 09:14 AM
  #55
Glex25's Avatar
Glex25
I posted up pictures of the Fluidampr pulley with measurements.
Can anyone else post pictures with measurements of the oem and Ati Damper?
Old Apr 29, 2010 | 10:11 AM
  #56
jonnylaw's Avatar
jonnylaw
I would agree, although another way to put in, would be if you have stock internals, the stock crank pulley will likely be ok.
However, I'm not sure if the added stress/load caused by FI on a stock engine, would truly benefit from a dampened pulley like the ATI/Fluidampr.
Also, it should be noted that the same crank pulley (part nunber) is used on Infiniti G35 coupes/350z from 2003-2007. So that includes both nonrevup engine (6600 redline) and revup engines (7000 rpms).
Old Apr 29, 2010 | 10:44 AM
  #57
jonnylaw's Avatar
jonnylaw
Thx for taking the time to post up measurements on your Fluidampr.
I spoke with ATI and Fluidamper on the actual OD, measured from where the belt sits and they are as follows:
ATI: 6.610"
Fluidampr: 6.125"
Everyone says the stock is 5.745", but I haven't actually measured myself.
If I had originally bought the Fluidampr, instead of the ATI, I might have left it on, and not rev'd past 6500. However, the ATI is just too big for my application...
Old Apr 29, 2010 | 01:16 PM
  #58
350z006's Avatar
350z006
Really? I spoke to someone at Fluidampr today as well, and he told me it was around 6.25"...
ATI: 6.610"
Fluidampr: 6.125"
Old Apr 29, 2010 | 01:26 PM
  #59
jonnylaw's Avatar
jonnylaw
^^possible, there was some confusion over measurement from where the belt would sit. It's either 6 1/8" or 6 1/4". Measurement by Glex were also ~6.25"
I'm pretty sure this difference in Fluidampr diameter from stock would still require different belt(s). Maybe Glex can verify when he puts on accesory belts.
Old Apr 30, 2010 | 09:41 PM
  #60
MR RIZK's Avatar
MR RIZK
Fluidampr VS OEM
It appears that the pullery that runs the AC is the same diamaeter but the pulley that runs the PS and AL will be overdriven due to the larger pulley diameter.
Also the overall height of the FD is about 2mm over stock ie: it will sit 2mm further away from the enigine.
One other point of concern is the timing markers which do not appear to be the same as OEM. Can anyone comment on this?
Summary:
OEM 165mm and 150mm
FD 165mm and 158mm
NOTE: this is not measured to the top of the teeth so give or take 2mm from edge to teeth. There is a bit of paralax error in the photos
