Going to the dark side!!
Old Mar 17, 2010 | 04:09 AM
  #161
jeffie7's Avatar
jeffie7
The only reason someone can't do something is because they tell themselves they can't do it.
I'm that guy at work who's pulling apart random stuff and making it work, not small chit but full size refrigerators, ovens, drywall, plumbing, gas lines, deep fryers, you name it, if there's a slight chance I might be able to fix it, I'll try. 9 times out of 10 I have no idea what I'm doing, about 80% of the time I get the job done. People always ask, how is it you know how to do that? My answer is always the same, I didnt.
People message me all the time because of the powerlab kit, the piping is friggin huge and when you look at the pipes and where they go, it looks like there's no way in hell it can fit, in some spots there's maybe 1/8 of an inch of clearance. Almost everyone that has messaged me with a I hate this kit why did I try this on my own, all planned to do it in 1 weekend.
Be realistic about a time frame and take your time, if issues come up step away and rethink it. In the end you really can't mess up that much stuff, I think the worst thing you can do during a turbo install is drop something into the motor when you're changing the plugs, or strip out one of the sparkplugs. The rest of the stuff is just a PITA I gotta stick this tool up where? how the hell! yeah many of those moments.
I wouldn't recommend doing a turbo install to anyone unless they have a garage to use with more then enough room to move around, and a unlimited time span. Once you take your car in for tuning ask the tuner to do a one over on all the piping, and major components.
If you can't get 5-6-7-8+ days to work on it or don't have a garage, I wouldn't mess with it.
Barnies too busy with that fat chick website so I doubt he'll find time to get under his car. Hills is his best option.
Old Mar 17, 2010 | 06:23 AM
  #162
Boosted Performance's Avatar
Boosted Performance
Vendor - Former Vendor
Originally Posted by MDHRZ
As long as it's truely bolt on and you have the right tools, then it shouldn't be a problem. The GTM kits may not be worth installing yourself.
When I put my kit together that was the main objective. Simple bolt on. The instructions that come with the kit have huge (full page 1 picture at times in color) pictures. All the electrical stuff is plug'n play. I really cant see any reson for someone not to be able to install it.
I am sure it is the same with other kits, maybe not as much room but that is about all.
Old Mar 17, 2010 | 12:33 PM
  #163
Barnabas's Avatar
Barnabas
National Z Club President
new toys for the car
Old Mar 17, 2010 | 04:22 PM
  #164
MDHRZ's Avatar
MDHRZ
Somebody got hooked up with this new job lol. Nice wheels man. Did you get rid of the other wheels you had?
Old Mar 17, 2010 | 04:27 PM
  #165
Barnabas's Avatar
Barnabas
got rid of the 18's not the gram lights
Old Mar 17, 2010 | 06:51 PM
  #166
djamps's Avatar
djamps
Working on a fridge is a bit different than working on your DD. Worst case on a fridge you say F it and toss it in the trash. Worst case on your DD is you're 4k deep on a new shortblock after not connecting that line to your wastegate properly where someone like Frank wouldn't miss it if he was blindfolded and working with one hand.
Old Mar 17, 2010 | 06:53 PM
  #167
Barnabas's Avatar
Barnabas
Originally Posted by djamps
Working on a fridge is a bit different than working on your DD. Worst case on a fridge you say F it and toss it in the trash. Worst case on your DD is you're 4k deep on a new shortblock after grenading your block after forgetting to connect that vacuum line to your wastegate properly that someone like Frank wouldn't miss.
thats my mindset maybe if it was a SC I would do it
Old Mar 17, 2010 | 08:00 PM
  #168
nyqueenz's Avatar
nyqueenz
Originally Posted by Barnabas
been in the works for a little while. I am in the final steps of getting the last of the parts I need and I will be doing my build
JWT550bb TT kit
ATS Triple Carbon Plate Clutch 1350-kg. (Soft-Type) w/ Aluminum Clutch Cover & Lightweight Carbon Flywheel
NGK one step colder spark plugs
EMS will be uprev osiris
still need to get injectors (thinking 600cc DW)
Am going to do a return fuel system ( trying to find a used one for sale if not will have my installer build one)
A/f, EGT, boost, gauges ( looking for DEFI's)
I plan on buying Quaife LSD and 3.3 final drive gears in the near future
Already on the car:
Kinetix velocity plenum
HKS hi power true dual 2 1/2" exhaust
install will be done by Frank @ hills garage in baltimore MD and tune will be done by frank smith in annapolis MD.
Goal is to run a 9psi and a 7psi map and see what HP i can get
Is this the one an only... man i didn't even relise this is you bro.. so whats the latest hit me up in PM.
Old Mar 17, 2010 | 08:01 PM
  #169
nyqueenz's Avatar
nyqueenz
thanks chris!! maybe we can cruise together when im done but im putting a rock under your gas pedal soo you cant get past half throttle
If anyone has a hook up or can help me get a good deal on the parts im looking for let me know!!!
what parts do u need im in Kuwait holla at me.
Old Mar 17, 2010 | 08:11 PM
  #170
jeffie7's Avatar
jeffie7
The main thing I pointed out was having enough time to not worry about it, this means any DD is OUT of the picture. Plus anyone who turbos their DD outside of Keith is crazy, I'd never do it. Even if I could have a turbo kit installed in 1 day. I'd hate knowing that if the slightest thing goes wrong my car could be down for a week waiting on a part, even if its something basic. If its part of the turbo kit, chances are it's not a local part.
If you turbo your car and are willing to hit anything more then ZERO PSI without first having it tuned you shouldn't have a turbo car. Once its taken to the shop you'd get it looked over and tuned. at that point the tuner should spot any issues or notice things like the waste got not working correctly.
I had a turbo car that had one of the vac lines come off the waste gate I did hit about 2 bar since I was doing a full throttle run, but as soon as I noticed I backed off and still managed to drive 20+ minutes home keeping the car out of boost.
Strapping a turbo onto a car will not cause it to blow up even if its put on wrong, it wont run correctly or wont run at all, having it not setup right then running under load, THAT is when you'll find your problems. It really isn't rocket science turbo kits are pretty basic when you step back and look at them for what they are. the worst thing I can think
of outside of dropping something into a spark plug hole or stripping it would be drilling out the block for an oil return since that's a one shot deal, but now we have many options for spacers with oil returns build into them. it really is straight forward.
For the record our smallest fridge cost us $2100.00 we dont really like to toss them out.
Old Mar 18, 2010 | 06:00 AM
  #171
str8dum1's Avatar
str8dum1
Frank left a rag in someone charge pipe
Old Mar 18, 2010 | 06:35 AM
  #172
jeffie7's Avatar
jeffie7
**** happens people screw up all the time, it's about how you fix your mistake that matters.
Most shops if tuning it themselves would have pulled the rag out and never said anything to the owner. We'll never know if frank would have fessed up or not if he did the tuning but in the end Case was taken care of. Just had to get past the whos at fault issue.
Old Mar 18, 2010 | 06:37 AM
  #173
MDHRZ's Avatar
MDHRZ
I don't think he'll make that mistake again. **** happens. I'd still go to Hills.
Old Mar 18, 2010 | 06:44 AM
  #174
jeffie7's Avatar
jeffie7
With that being said, someone who does 1 or 2 turbo installs will triple check damn near everything where someone who does them daily just goes through the motions. I've noticed that with a lot of things. Look at homes, if I do something I make sure its done right, if a pro builder does something they make sure its done well enough to be fixed by trim and paint. shoe moding is a wonderful thing for hiding uneven walls/floors.....
Old Mar 18, 2010 | 06:50 AM
  #175
jeffie7's Avatar
jeffie7
**** happens, it could happen again or something else, this can happen anywhere, from a rag in the charge pipe or not installing something correctly, **** happens everyday from performance shops to dealerships. Just search dealership horror stories on google. People run cars into walls, forget to put drain plug back in, install wrong oil filters, or my fav, using a impact gun to put a drainplug on. list goes on.
I wait tables and everyday I screw up things. I always tell people the truth and fix the issue. that's life, I eat out a lot and the thing that pisses me off is when a server screws up something and pretends it diddn't happen or blames it on something else.
Old Mar 18, 2010 | 07:52 AM
  #176
MDHRZ's Avatar
MDHRZ
Whether it’s 1 install or 1000 installs everything should be triple checked. I doubt Frank will let that exact same issue happen again given the severity of it. Yes, other issues will happen. I’ve never met Frank, but from what I’ve heard about him I think he will learn from that mistake and make sure it never happens again. In my line of work I check everything more than once. I have no choice. If I “accidently” shut down the network or blow up a server then I’ll most likely be escorted out of the building. I guess it all comes down to what the repercussions would be.
I do agree with your statement though. There are a lot of people who just go through the motions.
Telling the truth goes a long way no matter what it is. Unfortunately, some people don’t get that (AAM for example). Frank is a stand up guy from what I see and that’s why my build will be going to him if I don't do it myself. His customer service seems to surpass any other Mid-A shop as well.
Old Mar 18, 2010 | 09:11 AM
  #177
jeffie7's Avatar
jeffie7
I'm taking my Z out today for smog testing, I just ran into another problem related to my turbo kit, what really pisses me off is it has nothing to do with my install....
you want it done right do it yourself...... I can't preach that enough.
Old Mar 18, 2010 | 09:30 AM
  #178
MDHRZ's Avatar
MDHRZ
You take your Z out?
Old Mar 18, 2010 | 09:32 AM
  #179
jeffie7's Avatar
jeffie7
It's sitting in the driveway, watching to see if it will hold pressure before taking it out, then I need to put 30 miles on it and get it tested if no codes pop up.
If anyone wants to see it, nows your chance! lol
Old Mar 18, 2010 | 11:32 AM
  #180
NNOCENT's Avatar
NNOCENT
wish i would have known you brought it out, went to lunch near arundel mills i would have stopped by.
