My 2010 Build, APS Twins
Old Jul 22, 2010 | 09:54 AM
  #61
binder's Avatar
binder
Originally Posted by Zivman
they are not coated. most people are just running them as you see them. before the turbo piping is more critical than after the turbo in terms of wrapping and coatings (keeping the heat in)
that won't matter much with turbos on the manifolds.
and post turbo piping it is very critical to heat wrap them on a manifold or front mount turbo system due to engine bay temps. It will make drastic improvements in cooling the engine bay which leads to less heat soak into the charge pipes therefore lower intake temps.
Old Jul 25, 2010 | 12:09 AM
  #62
wannabuy350z's Avatar
wannabuy350z
Originally Posted by Cass007
What tubing are you referring to? The turbos mount right to the manifolds
pre-turbo. like the APS kits have
Old Sep 10, 2010 | 11:04 AM
  #63
derekinthez's Avatar
derekinthez
I'm subscribed to see the outcome. I give the OP props for not listening to the naysayers!
Old Sep 10, 2010 | 11:40 AM
  #64
zen350z's Avatar
zen350z
In for finished result...
350Z_Al
Oct 29, 2020 07:44 PM
