Thoughts on the V-band turbos
Old Jan 20, 2010 | 05:48 PM
Boosted Performance's Avatar
Boosted Performance
Vendor - Former Vendor
Default Thoughts on the V-band turbos
Anybody have any experience with the Precison turbos that have the V-band in and V-band out on the turbine.
It sounds very attractive, and would be easy to work around when it comes to fabricating, vs the standard T3 or T4 flanges.
Precision offeres the 6262 in that V-band configuration and only with a
.82a/r. It would also be very easy to install and remove the turbo if needed.
Any thoughts or experience with this setup?
Something like this:
Old Jan 20, 2010 | 06:35 PM
Dynosty's Avatar
Dynosty
We have used them on a few setups now and I love working with them. They make for very easy install, and allow everything to rotate for optimal fitment unlike bolt-on flanges.
Another benefit of the Tial SS V-band housings is a drastic reduction in weight. Beyond shedding pounds off the car, it takes weight off the manifolds and makes them less prone to cracking.
Old Jan 20, 2010 | 06:38 PM
str8dum1's Avatar
str8dum1
i guess for 1 turbo the huge difference in price (those TiAL housings are $$$$$$), might be worth it.
I'd prolly want to use the extra money on their new ceramic ball bearing turbos.
Old Jan 20, 2010 | 06:54 PM
QuadCam's Avatar
QuadCam
yes...those tial cast stainless housing are pretty trick! i can only assume they must be made from some special alloy of stainless that has a low thermal expansion rate. I haven't heard of an expansion issues with those housings......like i said, very trick!
Old Jan 20, 2010 | 07:04 PM
jeffie7's Avatar
jeffie7
Looks like a great setup! The turbo housing looks to be held on with nothing more then the tips of the washers?
Old Jan 20, 2010 | 07:08 PM
Boosted Performance
Just to be clear, I would not be using the Tial turbines. The picture is just there to show what I mean.
Old Jan 21, 2010 | 05:41 AM
str8dum1's Avatar
str8dum1
you mean TiAL compressors housing?
your original pic is of a TiAL turbine which costs about 350$ extra. You can get Vband downpipe from PTE directly, but not a V-band uppipe flange (which is what TiAL is offering).
SP uses V-band downpipe PTE's on their builds
Old Jan 21, 2010 | 06:18 AM
Boosted Performance
No, I mean turbine (exhaust) housing. I will make the call to Precision today, I am sure I have seen them offering the uppipe in a V-band configuration as well.
EDIT:
Found it, got to love google:
This will be a very nice feature to have. It would take one 5 minutes to remove the turbo if needed, or bolt another one up. There is no need for any gaskets or high temp. RTV.
The simpler I can make this the better.
Justin100
Nov 25, 2021 06:26 AM
