"F1 racing" flywheel with built greddy tt
Old Jan 20, 2010 | 06:53 PM
Tsukuba-Z33's Avatar
Tsukuba-Z33
Default "F1 racing" flywheel with built greddy tt
quick question. Im building my motor for my 500whp build and my machinist needs my flywheel to balance my motor. HOWEVER, my flywheel is in my car and it would cost me alot of downtime and money to remove my flywheel from my car since my Z is my daily driver. SO i looked in the marketplace and online and see that the ebay brand "F1 Racing" has a flywheel for fairly cheap. I personally wouldnt and ebay brand clutch for such high hp build but im thinking maybe ill be alright with the FLYWHEEL ONLY. My question is would i be jeopardizing my built motor if i used just a F1 racing flywheel with my competition stage 4 clutch thats already in my car?
P.S. ive sereached other forums and found positive review for other vehicles.
here the link to the clutch
http://cgi.ebay.com/ebaymotors/F1-RA...item5d277eeb47
Old Jan 20, 2010 | 07:24 PM
Quamen's Avatar
Quamen
First off your flywheel should be balanaced independently already. I don't see a reason why you would need the flywheel to balance the rotating assembly since they are balanced already.
Second, I have not heard anything about the F1 Racing flywheel, not to say they are bad though. However, you are talking about what I presume is a fairly expensive motor. IMO, buy a reputable flywheel and be done with it. We save $200 and risk a couple thousand? Not to mention that you can find flywheels in the market place for between $200-300 used if need be from companies that have proven to hold well over 500whp.
Old Jan 20, 2010 | 08:37 PM
Tsukuba-Z33
Thats what i thought. i thought i could internally balance my motor (in absence of the flywheel and crank pulley) but i made a thread about that and i got diffent answers.
here the thread i made.
https://my350z.com/forum/forced-indu...ort-block.html
2ndly, lets say i did buy that F1 racing flywheel and got it rebalanced would it be okay for my 500whp build or not??? or is quality the main concern???
Old Jan 20, 2010 | 09:08 PM
deanfootlong's Avatar
deanfootlong
have your motor "zero balanced" so you can use any flywheel you want. you dont need the flywheel to get the rotating assembly balanced.
Old Jan 20, 2010 | 10:35 PM
drivessidewayz's Avatar
drivessidewayz
You can get a proven flywheel for under $200 more. If you're building it up to 500 whp, then spending an extra $200 on a good part won't matter. It's also lighter
http://cgi.ebay.com/ebaymotors/Fidan...item5635e631c6
Old Jan 21, 2010 | 06:55 AM
Tsukuba-Z33
okay, do you think id be okay with a zero balance motor like deanfootlong said??
Old Jan 21, 2010 | 06:56 AM
Quamen's Avatar
Quamen
I don't think anyone will have an answer for you. Again, spend the extra money on a new flywheel from RPS, JWT, Spec or Fidanza. Those have all been used on high horsepower builds successfully. You can find them used for around $200 in the classifieds and almost all of them come with replacable wear surfaces so no biggy. I am selling my JWT for $200 but a local person is buying it.
Old Jan 21, 2010 | 03:12 PM
Aced16's Avatar
Aced16
I have a full spec twin disk unit w/ flywheel I will be posting for sale this week if interested, let me know...
Old Jan 21, 2010 | 03:26 PM
str8dum1's Avatar
str8dum1
aced, what are you going with now? did it not hold the NO2?
Old Jan 24, 2010 | 12:59 PM
Aced16's Avatar
Aced16
I actually never got around to installing it have had it sitting in my apt for about a year now. Dont you run a SPEC twin on your build? I'm sure its over kill for my current set up, so I'm going to sell it
-Chris
Old Jan 24, 2010 | 01:43 PM
str8dum1's Avatar
str8dum1
I do, so I am always curious to what other people's impressions/problems/success are with it
Old Jan 24, 2010 | 05:58 PM
Tsukuba-Z33
how are spec twin disc??? i asked hal at injected performance and he said GARBAGE. but granted thats only 1 opinon. lol
Old Jan 25, 2010 | 06:17 AM
str8dum1's Avatar
str8dum1
its slips nicely for the street and strip and held my previous power just fine.
notchy going into 1st and reverse, but my slave cylinder might have been leaking. They've got good customer support, but I am thinking I shoulda just put in the tilton triple cerma-metallic since my tranny was out recently.
Old Jan 25, 2010 | 06:38 AM
captj3's Avatar
captj3
Every machine shop is different. The shop I will be using wants the flywheel, clutch and crank pulley to balance the motor. Giving the shop these parts will allow them to do a better job at balancing the motor. But you don't have to do it, they can just do the short block as well. My best advice is talk with the shop that is doing the work about the pros and cons of balancing with and without the parts, since you are investing thousands of dollars in a motor.
Old Jan 25, 2010 | 09:16 AM
Tsukuba-Z33
^^thanks bro
sales@czp
Sep 23, 2019 03:30 PM
