BC2 Cams - Idle and stalling (Haltech)
Old Apr 13, 2010 | 07:48 AM
rcdash's Avatar
rcdash
It will go rich on decel, but as the idle falls, it will lean out quickly and die. On my Haltech, I've set fueling at 500 rpms similar to that at 2500 rpms! My idle is 800 rpms. Hope that helps.
Old Apr 13, 2010 | 10:52 AM
binder's Avatar
binder
thanks, i can't say it helps the issue until i have my car together to test it but i will for sure say it helps my knowledge and makes perfect sense.
now i'm excited to get home in 2 weeks to rebuild this engine (stupid head gasket) then see if i can fix my year old problem
Old May 4, 2010 | 09:00 AM
binder's Avatar
binder
is that on your base fuel table?
i noticed hal has my targets down at 14.2 in that area also.
Old May 4, 2010 | 12:31 PM
rcdash's Avatar
rcdash
Yes, on the base fuel table, which is tuned via injector pulse width, so I just enter the millisecond value directly.
Old May 4, 2010 | 02:37 PM
binder's Avatar
binder
wait, i'm lost, how do you enter the ms in the base fuel table? I can't find that
Old May 4, 2010 | 03:44 PM
Chris@FsP's Avatar
Chris@FsP
Vendor - Former Vendor
You have to change it in SETUP. You will need to completely remap if you change from VE to IPW tuning.
Old May 4, 2010 | 04:43 PM
binder's Avatar
binder
alrighty then....i'll be fine with my fuel % change then. lol
it's pretty much fixed right now. It drops like 100rpm at most now.
Old May 4, 2010 | 06:09 PM
rcdash's Avatar
rcdash
Oh yes, with VE, just make it richer. Sorry I was thinking in ipw and relating values from one cell to another - cannot do that with VE since it's all hidden from you. Glad it's working for you.
Old May 4, 2010 | 10:24 PM
binder's Avatar
binder
ya, this haltech is nasty.
i'm working on tip in at higher rpms. Hal set it around 3-3.5k for a great tip in but we were playing tonight and i was doinga 40mph roll with a friend and my tip in sucked. It jumped to 16.6 a/f. I can't just richen the cells up (tried) because it makes the car run super rich once it catches up. I guess that TT load thing is what i need to mess with and it's a little confusing for me.
Old May 5, 2010 | 05:08 AM
rcdash's Avatar
rcdash
Transient throttle enrichment tuning is tricky and takes patience. See my thread over on the Haltech forums if you want to know the algorithm employed. It becomes a little easier to figure out how to make adjustments then...
Old May 5, 2010 | 06:35 AM
binder's Avatar
binder
i'll search for it. same user name over there? which subforum is it under?
I love this thing so i want to know how to tune the crap out of it.
Old May 5, 2010 | 06:38 AM
MR RIZK's Avatar
MR RIZK
http://forums.haltech.com/viewtopic.php?f=24&t=3450
Old May 5, 2010 | 06:41 AM
binder's Avatar
binder
thanks!
Old Jun 9, 2010 | 06:32 AM
lanceccs's Avatar
lanceccs
Stock engine with Kinetics Plenum, Apexi filter and straight thru exhaust from header to cat back.
Got my Haltech tuned today and I am experiencing the same problem.
Symptons
Eccentric Idling
-RPM oscillates between 200-1300 after deceleration. Takes a few cycles to stablise.
-In some circumstances where I shut throttle and clutch in suddenly, it will stall the engine.
I don't know nuts abt tuning and I don't wanna mess around with the tune. I will bring the car back to the tuner and have it fixed. What should I tell the tuner to try???
Please help... thanks.
Old Jun 9, 2010 | 06:37 AM
rcdash's Avatar
rcdash
copy through ignition timing helps with idle stability (put a "C" in the cells rather than an absolute timing value in degrees). The rest is in the fueling.
Old Jun 9, 2010 | 07:03 AM
lanceccs's Avatar
lanceccs
Thats quick reply. Thanks!!!
Another secondary problem/question....
I have the "03 with narrowband, so I've gotten the Haltech Dual Wideband and wanted to put them on only to find out that the dealer sold me the Silverbox 350z Haltech with Old Harness (without the pnp connector for the dual wideband).
Long story short.... We completed the tune without fixing the haltech widebands... I wanted to get the wideband wired up somewhere and put them in use. However, the tuner advised that I should have the haltech wideband calibrated against the tuneshop's wideband which they used to tune my car.
I was told it would require 1-2 hrs of dyno time for that...and of coz that means $$$$.
Question is...
Is it really necessary to calibrate against the tuneshop's wideband? What if I don't??
Old Jun 9, 2010 | 08:35 AM
Chris@FsP's Avatar
Chris@FsP
Question is...
I'd trust the Haltech wideband over many dyno's built-in wideband.
Old Jun 9, 2010 | 08:52 AM
  #38
Elperuano's Avatar
Elperuano
the problem is there's no manufacturer for the display gauge of the haltech wideband so it leaves people who have the wideband with no display gauge forced to check a/f n stuff like that thru the actual haltech ecu... sucks until they come out with a company to make the display gauges
Old Jun 9, 2010 | 08:58 AM
  #39
str8dum1's Avatar
str8dum1
^ did you wire up the prosport gauge completely to the haltech harness. There's no reason it wont work properly.
Old Jun 9, 2010 | 09:01 AM
  #40
Elperuano's Avatar
Elperuano
yea meng its wired right just off... its gotta be the gauge. the haltech display gauge reads off the haltech directly n makes adjustments accordingly... even with my gauge off it will never adjust like the way the display gauge should i believe... besides id prefer to use the entire haltech system than have 1 unfamiliar source hooked up to it.
