APS TT Built Block - Fuel system choice
Thanks guys. Think I will go CJM twin pumps, Stage 2 return and 800cc injectors. Better to be safe than sorry I suppose. I dont think I will have a hope in hell of hitting 600rwhp on my tuners Dynopack as it reads a fair bit lower than the Dynojet. Tuner says his dyno reads about 5% higher than a DynoDynamics in shootout mode.
248c... They told me it was absolutely out of fuel and pressure was dropping on that pass.
cass made 640ish on a DD with single pump and meth. YOu can get a simple meth kit for 1/2 the price of a the dual pumps. The dual pumps can be added later easily if needed, so I wouldnt drop the ~1000$ (your need extra lines, fittings, electrical, etc) up front for that.
Get you tune with the RFS and injectors and see where you stand. Meth is an much cheaper option is other benefits as well.
In my experience, DD shootout mode reads _alot_ higher than DJ. Bone stock 2006 g35 coupe with nothing but an exhaust at the last meet did 267whp on a DD in shootout mode... a DJ would have read no more than 24x whp...DJ may have it's weaknesses, but it is at least consistent and the only dyno I would trust when comparing results between dynos.
I have had no trouble running to near empty with the CJM stage 1 fuel system (I monitor fuel pressure inside the car). I typically fill up with a full tank somewhere in the 14-16 gallon range (needle is on "E"), same as stock.
I presume that was not on 93 octane nor without meth/water injection? That's really high, wow. I was talking about pump gas number though, and was just ballparking.
on a dyno, i bet you could get that kinda power. on the street under 'load', youd comeup short pretty quick.
also they might have tuned to AFR 12.5 which will make more power and extend fuel systems.
the biggest problem with the APS "extreme" fuel system is that the injectors run out of steam early on because they over rate them. guys going for big power end up putting in some 1000cc injectors and switching to our rails because the APS rails will not fit taller injectors under the intake manifold. By then you have to redo some plumbing and get rid of their dual regulators... and by then the only thing you are still using is their twin pump, which is not as nice as ours anyway
