OIL issue???
Old Dec 23, 2009 | 09:04 PM
Zphanatic's Avatar
Zphanatic
Default OIL issue???
Got another issue... (This is a built motor) Think I am having an oil pressure problem on cold starts. So on cold starts, the motor rattles kinda loud for about 2-3 seconds. So i watched the oil pressure gauge when I cranked it one morning and while the motor rattled, the oil pressure gauge read 0, and after about those 2-3 seconds the motor sounded normal and thats when the oil pressure gauge jumped high. This normally happens on cold starts, but lets say if I drive around for awhile and turn it off and wait about an hour. It would do the same, even if the motor is warm. But if I crank within 30 min, its ok.
Any ideas? I tried switching the oil pressure sensor and nothing. I went from 15w-50 oil to 10w-30. I dont think it would be the clutch possibly? Have a Twin Carbonetic. Possibly oil pump, which is also brand new, motor only having about 5k miles.
Any ideas?
Old Dec 24, 2009 | 07:15 AM
06Track's Avatar
06Track
What is your oil pressure when fully warmed up? At idle and while
driving. Also, what oil filter do you have?
Old Dec 27, 2009 | 07:17 PM
Zphanatic's Avatar
Zphanatic
Fully warmed up around 20ish? Idle is same. When hitting full boost about half way, which is 60?
I use OEM Nissan oil filter...
Any more ideas?
Old Dec 27, 2009 | 07:21 PM
Chris@FsP's Avatar
Chris@FsP
Vendor - Former Vendor
Probably just the timing chain tensioner.
Old Dec 28, 2009 | 05:08 AM
rcdash's Avatar
rcdash
There was that sprocket noise TSB on the DE engines.
Old Dec 28, 2009 | 09:30 AM
Zphanatic's Avatar
Zphanatic
So your saying the timing chain tensioner is making the noise? Or needs to be tightened a bit?
And is that sprocket noise TSB normal as well?
Old Dec 28, 2009 | 05:18 PM
35Zer0's Avatar
35Zer0
i would go back to the person or shop that built the motor...sometimes problems don't show up until 1000's of miles later
Old Dec 28, 2009 | 05:26 PM
04fairlazdyz's Avatar
04fairlazdyz
LOW N SLO
+1 whoever put the motor together should be willing to look at it. Especially if you only have 5k miles on the engine
Old Dec 28, 2009 | 05:59 PM
Zphanatic's Avatar
Zphanatic
Well I bought the car from someone else, and he had it built. And that shop actually happen to have gone out of business... So I am trying to figure it out.
Any other ideas???
Old Dec 28, 2009 | 06:07 PM
Chris@FsP's Avatar
Chris@FsP
These threads should help you out.
https://my350z.com/forum/engine-and-...-start-up.html
https://my350z.com/forum/forced-indu...tensioner.html
35Zer0's Avatar
35Zer0
Any other ideas???
if thats the case go back to the person you bought the car from...unless you 2 had some kind of "as is" deal...anywho
you may need to go to a reputable tuner shop and have them take a look...its gonna be the expensive route but you'll get a better idea
Old Dec 29, 2009 | 05:34 AM
GreenGoblin's Avatar
GreenGoblin
Who built the motor?
Old Dec 29, 2009 | 04:21 PM
Zphanatic's Avatar
Zphanatic
Maximum Motorsports? I believe they were in Florida...
So this sounds like its pretty common and normal? And nothing to really worry about, as long as I keep up with my oil changes?
Old Feb 26, 2010 | 09:16 AM
Zphanatic's Avatar
Zphanatic
Hey guys, sorry to bring up my old thread back up. But today I took off the left black cover on the front timing cover where the main timing chain tensioner sits, and I tried to tighten it up, but it wouldn't move. I could tighten the chain, but the tensioner would remain in its position. So does this sound like the problem?
apex locator
Jul 23, 2021 02:27 AM
350z82
Oct 1, 2015 06:25 PM
