My HKS S/C Installation
Old May 11, 2010 | 09:19 AM
  #241
jonnylaw's Avatar
jonnylaw
Originally Posted by IanP
Question for those of you with the GTM kit,
Did you change to the smaller pulley yourself or did your tuner do it?
I've just had a call from my tuner saying that I would have to send my S/C to HKS japan as they are the only ones that can do it
I don't understand, the pulley sits right in front of the blower. Anyone should be able to swap it out. A retune may be necessasy, but HKS Japan doesn't have to do that if you are using a pro tuner with the fcon or are using a different ems.
Old May 11, 2010 | 09:23 AM
  #242
IanP's Avatar
IanP
Thats what I thought but GTM wouldnt tell me how to swap it out & told me to leave it to the tuner. But my tuner is saying that HKS have told them that to replace the pulley it has to go back to Japan (which will cost me a fortune & means i'll be without a car for however long it takes) Surely though this is what GTM modify the blower for?
Stock pulley is making max boost at 6.8psi & boost is dropping off past 4.5K rpm. Hopefully Sam at GTM will chime in with some more info about it
Old May 11, 2010 | 01:21 PM
  #243
ITOzann's Avatar
ITOzann
Do it yourself, and use Osiris!
Old May 11, 2010 | 01:33 PM
  #244
IanP's Avatar
IanP
Car is currently at an uprev dealer being tuned so was hoping to kill 2 birds with 1 stone
They are my nearest dealer & are 170 miles away so I wanna get it all right on 1 visit
Old May 11, 2010 | 01:49 PM
  #245
pez1111's Avatar
pez1111
Try Rotrex http://www.rotrex.com/Home.aspx
Old May 11, 2010 | 03:17 PM
  #246
ITOzann's Avatar
ITOzann
It might be your MAF sensor, or vacuum leak
Old May 11, 2010 | 04:49 PM
  #247
_ink's Avatar
_ink
Originally Posted by _ink
Its just the normal kit. Thanks for your suggestion, i will definately be trimming that shroud.
Are you talking about the belt that is pictured here on top of the trimmed part?
Can someone please verify this for me?
Old May 11, 2010 | 05:45 PM
  #248
cdoxp800's Avatar
cdoxp800
Its just the normal kit. Thanks for your suggestion, i will definitely be trimming that shroud.
Just trim the Part where the red dash'es are. It will make getting the three bolts for idler pulley on much easier.
Old May 11, 2010 | 07:40 PM
  #249
ITOzann's Avatar
ITOzann
^+1 on that.. It was too late when I realize I could do that. I had to remove my radiator
Old May 11, 2010 | 08:01 PM
  #250
_ink's Avatar
_ink
Thanks for that, but i wanted to verify wether that is the belt that i need to disconnect? (the belt above the trimmed shroud)
Old May 12, 2010 | 04:02 PM
  #251
Chops@MVP's Avatar
Chops@MVP
Originally Posted by pez1111
Thanks guys for your responses, and it just arrived!!! Thanks Robert and Paul at MVP. So a few more bits and pieces and the install will begin.
I'l do a thorough listing soon. My zed is a rev-up.
Again thanks guys.
Thank you guys!!! Be sure to email photographs of the vehicles once completed so we can add them to our site!!
Regards,
Robert
Old May 13, 2010 | 12:51 AM
  #252
jonnylaw's Avatar
jonnylaw
+1 on pics, especially interested in pez's install as he's installing a non-revup kit on his revup engine. The brackets do indeed look the same between the two kits, but his install should show whether the kits are indeed the same (minus the ems/injectors). Please keep us up to date on your install progress pez and whether you encounter any issues.
Old May 13, 2010 | 04:08 AM
  #253
pez1111's Avatar
pez1111
Yep will do. If all my parts arrive on time I will try and get it done in the next few weeks as i will away for about 2 months from June 1. Either way i will post my progress. This thread has been wealth of info. I may have to delete the passenger side (OZ ) water tank for the xenon washer so as to fit the traction oil cooler, i'm currently running a HKS oil cooler where the intercooler will be fitted.
Old May 13, 2010 | 04:32 AM
  #254
pez1111's Avatar
pez1111
Not relevant, deleted.
Old May 13, 2010 | 04:41 AM
  #255
_ink's Avatar
_ink
Hi guys,
really need an answer on this asap.
The belt that i don't connect was the one referenced in the picture correct?
just to remind people, the belt i am referring to is so i can drive the car to the tuner once i install the kit.
Old May 13, 2010 | 10:14 AM
  #256
IanP's Avatar
IanP
Hi guys,
The front belt you disconnect yes You will see when you install it that one belt fits around the oem pulleys & the other belt only goes around the idler pulley & the s.c pulley - this is the one you need to remove
Got my car back today, i'll get some graphs up a bit later on but basically
380 RWHP/ 420 Flywheel
350 Ft/Lb
7.5 PSI
Very happy with it
Old May 13, 2010 | 02:39 PM
  #257
cdoxp800's Avatar
cdoxp800
Got my car back today, I'll get some graphs up a bit later on but basically
350 Ft/Lb
7.5 PSI
Very happy with it
Very nice Ian
Old May 13, 2010 | 04:03 PM
  #258
ITOzann's Avatar
ITOzann
^+1 impressive numbers!!!
Old May 13, 2010 | 04:09 PM
  #259
_ink's Avatar
_ink
Thanks Ian!!!
And VERY NICE numbers!!!!!!
Are you running the GTM stage 4 kit?
Old May 13, 2010 | 04:53 PM
  #260
pez1111's Avatar
pez1111
350 Ft/Lb
7.5 PSI
Very happy with it [/QUOTE]
Nice
