My HKS S/C Installation
Old Jul 16, 2010 | 08:38 AM
  #361
cdoxp800's Avatar
cdoxp800
Well I got you all beat. My boost just went from 8.5psi to well over 11psi. My Exhaust also got quieter. I am thinking my HFC's have melted or my boost gauge sensor is going bad. Now at the same time I am not feeling much power at WOT. I haven't a clue right now, but I will get the HFC off over the weekend to check it all out.
Old Jul 16, 2010 | 09:23 AM
  #362
jonnylaw's Avatar
jonnylaw
Can any of u guys please tell me if u can hear any type of sound coming from the blower at idle? Thx.
Old Jul 16, 2010 | 10:49 AM
  #363
cdoxp800's Avatar
cdoxp800
Mine sounds quite. All I here is the Air being sucked in.
Old Jul 16, 2010 | 01:51 PM
  #364
jonnylaw's Avatar
jonnylaw
Guys, I spoke with Sam today. Any idle surge/inefficiency issues are NOT due to the GTM pulley. There are many other issues that could be at play (including tune related). I apologize for believing the word of another without properly thinking out the scenario. There are many proven setups running the GTM 85mm pulley w/out issue. Must check belt tension/bolts/tune etc...
Old Jul 16, 2010 | 02:40 PM
  #365
thatv35guy's Avatar
thatv35guy
lol, sounds like he roughed you up…
Old Jul 16, 2010 | 03:20 PM
  #366
jonnylaw's Avatar
jonnylaw
^^no, he didn't. He is kindly helping me try to resolve my issues. I am trying to source new belts for replacement and check proper belt and bolt tension. That will be first step.
Old Jul 16, 2010 | 03:29 PM
  #367
cdoxp800's Avatar
cdoxp800
Well found my boost issue. My Berk Metallic Substrate HFC's are coming apart. I have a total of 4000 miles on this set.
I guess there not so good for forced induction set as advertised. "Perfect for forced induction use"
This is the set with the revised double gusset. They still broke at the welds. Oh well I guess it time for resonated test pipes.
I have found a set of Megan Racing Resonated Test-Pipes.
Any thoughts or recommendations?
Attached Thumbnails My HKS S/C Installation-berk-hfc-001.jpg   My HKS S/C Installation-berk-hfc-002.jpg   My HKS S/C Installation-berk-hfc-003.jpg
Old Jul 16, 2010 | 03:32 PM
  #368
cdoxp800's Avatar
cdoxp800
I spoke with Jared the other day about this. Here is his reply
The problem is that hot start is a matter of VERY fine tuning.
Typically I've found that idle surge usually comes down to fueling. Once the fueling is stabilized at idle, the surge usually goes away. The trims need to be ~100 and the MAF curve should be pretty smooth/flat in the idle area. Same goes for the fuel compensation and the ignition advance. They should all be pretty smooth around the idle area.
Old Jul 17, 2010 | 01:45 AM
  #369
_ink's Avatar
_ink
WOW @ the cats!!!!!
That's definitely concerning.
Old Jul 17, 2010 | 12:11 PM
  #370
ITOzann's Avatar
ITOzann
[QUOTE=jonnylaw;8527668]yes, your belts need to be of a proper tension and not slipping to make the power you should. There are instructions on belt tension in the manual. When my kit was first installed I made decent power. Then the belts were tightened down more and I gained 2 psi and more power, so belt tension makes a difference.[/QUOTE=jonnylaw;8527668]
Thanks for the info! What belt set up did you use with the 85mm pulley? I bought the belt from Sam@GTM like 2 months ago and it is not working fine. Gotta check for a replacement now since it started making a louder squeaking noise at start up.
I don't believe so. It is not the dreaded vortech metal grinding sound nor is it a whine. I've been told it's normal for Rotrex style blowers but am unsure. With your car on and the hood up, put your ear close to the blower and see if u can hear what I am referring to. thx.
My blower doesn't make any sort of sounds.
Originally Posted by _ink
WOW @ the cats!!!!!
+1
Old Jul 17, 2010 | 01:17 PM
  #371
cdoxp800's Avatar
cdoxp800
You could try the Dayco 5070410. The Bando PK1060 is 41.73in, and the Dayco 5070410 is 41in. The Dayco 5070410 should work just find if you have a 85mm GTM Sc Pulley.
As for the others:
A/c side is OEM
Pw steering, alternator. I am using a Dayco 5060670 (6PK1700).
Old Jul 17, 2010 | 02:51 PM
  #372
jonnylaw's Avatar
jonnylaw
The belt that comes with the 85mm pulley (as shown on GTM build threads any what came with my kit) is the Bando 7pk1040. BandoUSA does not stock 7pk belts, you could try the Dayco (but I'm unsure on their quality--they seem fairly generic to me), or maybe Gates has an offering. I'm assuming the 1040 indicates a 1040mm length. Did you get a Bando 7pk1040 from GTM? If so, have you tried tightening it down some more?
Old Jul 17, 2010 | 02:53 PM
  #373
jonnylaw's Avatar
jonnylaw
Guys, this is what my blower sounds like at idle (there is a "ringing' coming from blower). I have less than 5k miles on it
http://s38.photobucket.com/albums/e1...=HKSSCRING.mp4
So ur guys' blowers do not make this "ringing" sound as captured above?
Old Jul 17, 2010 | 05:57 PM
  #374
_ink's Avatar
_ink
hmmm, mine doesn't make that noise.
To me, that sounds like a loose bearing.
Old Jul 17, 2010 | 09:51 PM
  #375
ITOzann's Avatar
ITOzann
I'm using the Bando belts for the s/c and the crank pulleys. The 6 ribs belt is a Bando PK1700 and the 7 ribs is a Bando PK1060. When I bought my used kit, it only came with the s/c belt. Then, I called GTM and ordered the one i was missing(crank belt). I've had squeaking issues since I have the kit; I never thought it was the brand new belt
Old Jul 18, 2010 | 04:23 AM
  #376
IanP's Avatar
IanP
<object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/fybFjQ9z1yI&amp;hl=en_GB&amp;fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/fybFjQ9z1yI&amp;hl=en_GB&amp;fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
Thats mine at idle
Old Jul 18, 2010 | 07:31 AM
  #377
cdoxp800's Avatar
cdoxp800
Mine sounds the same as IanP
On a side note I got my stock Cat's back on for now. No more HFC's for me. Done with the whole cat cracking and cat blowing apart thing. I am looking at Motordyne ART Pipes.
Old Jul 19, 2010 | 06:42 AM
  #378
djamps's Avatar
djamps
You should be running at a minimum 3" cats for FI. Since installing AAM 3" cats and downpipes I've had zero issues with 10k miles so far on them and 9-10psi with twins. It's the same cats they use as an upgrade for the GTR cats so they definitely hold boost no problem.
I've seen nothing but issues with ANY 2.5" cat and boost.
Old Jul 19, 2010 | 06:44 AM
  #379
djamps's Avatar
djamps
Your stock cats are probably not going to 'blow out' but they are most certainly going to clog completely... get test pipes ASAP.
Old Jul 19, 2010 | 10:59 AM
  #380
GGGGGGGG's Avatar
GGGGGGGG
Jonnylaw,
my car makes the same exact ringing sound as your since day one I got the car back. I thought it should be normal and I've had it for more than 10000 miles now.
