My HKS S/C Installation
Old Jul 19, 2010 | 03:42 PM
  #381
cdoxp800's Avatar
cdoxp800
Originally Posted by djamps
Your stock cats are probably not going to 'blow out' but they are most certainly going to clog completely... get test pipes ASAP.
Working on it. I just need something on it so I could drive it.
Old Jul 26, 2010 | 09:06 AM
  #382
Ruthless18x's Avatar
Ruthless18x
So tell me if I'm correct based on reading this thread.
- Running a stock unit and pulley avg. 6 psi, which could be increased by running a larger crank pulley, possibly near 8 psi?
- GTM modified units and pulleys don't really show higher unit efficiency or whp numbers.
- Also, are any of you guys running 272 cams or meth?
Old Jul 26, 2010 | 12:01 PM
  #383
IanP's Avatar
IanP
Mine is GTM blower with stock pulley & stock crank pulley running 7.5psi
Stock cams but probably getting meth injection installed soon
Old Jul 26, 2010 | 12:15 PM
  #384
Ruthless18x
So does the GTM unit run at a higher psi or is 7.5 the norm? I thought it was the GTM pulley that raised the psi over the stock unit.
Old Jul 26, 2010 | 12:19 PM
  #385
IanP's Avatar
IanP
I was expecting 6psi with the setup I have but my car makes 7.5PSI
Old Jul 26, 2010 | 12:26 PM
  #386
Ruthless18x
Hmm. You only have bolt ons correct?
Old Jul 26, 2010 | 12:31 PM
  #387
IanP's Avatar
IanP
Yeah
Old Jul 26, 2010 | 05:54 PM
  #388
Ruthless18x
335 WHP is the lowest number I can find on this kit. Sound about right?
https://my350z.com/forum/shop-builds...p-310rwtq.html
This car only has an HKS exhaust from what I can tell, the rest is perfectly stock.
I'm think that with the following mods, and a stage 0 kit I can easily push 350-375 which I think would be perfect for me on a stock block track car. I will also be taking out the majority of my interior.
- HKS Stage 0 Kit
- DW 600cc Injectors
- Walbro 255
- HKS Dual Exhaust
- Motordyne ART Test Pipes
- AEM Meth
- ATI Crank Pulley
- BC Stage 3 Cams & Springs
- AAM Plenum Spacer
- Powerlab Oil Spacer
Let me know what you guys running this kit think, because this would add another option to the PL with a 4.5 spring, or the small GT25 GTM kit.
Old Jul 26, 2010 | 11:12 PM
  #389
ITOzann's Avatar
ITOzann
I think that a meth kit won't bring any power gains with an stage 0 or even stage 4. Also, your boost levels might drop because of the tp's. I was going to get a meth kit, but me and my tuner decided to skip it since it costs money, tuning time, and ads the chances to have future issues. I terms of the crank pulley, that something i want to know. let us know the output of your set up. I myself wanted to order a crank pulley but after reading the issues jonnylaw had, i decided to wait for a bit lol
Old Jul 27, 2010 | 01:13 AM
  #390
IanP's Avatar
IanP
Sounds about right.
My meth install was gonna be more for safety than gaining more power & its not hugely expensive for it to be supplied and fitted
Old Jul 27, 2010 | 05:46 AM
  #391
Ruthless18x
Same here. The meth wouldn't be for power, and I would not tune around it.
I guess I could see a boost drop with tps but you guys don't seem to be having any luck with cats either.
Old Jul 27, 2010 | 09:39 AM
  #392
ITOzann's Avatar
ITOzann
You can still use the tp's and hopefully the crank pulley will bring the boost up. Just make sure you don't over spin the blower. On my kit, the tp made me loose 2psi
Old Jul 27, 2010 | 05:09 PM
  #393
weiboy718's Avatar
weiboy718
whatever! you idiot!
hahahahha! J/K!
Old Jul 27, 2010 | 09:43 PM
  #394
jonnylaw's Avatar
jonnylaw
Possibly.
Absolutely UNTRUE. Where are you getting this information? GTM spec blowers improve efficiency and the custom pulley increase psi. These 2 things work together to achieve extra boost/power.
Old Jul 27, 2010 | 09:49 PM
  #395
jonnylaw's Avatar
jonnylaw
- HKS Stage 0 Kit
- Walbro 255
- HKS Dual Exhaust
- AEM Meth
- ATI Crank Pulley
- AAM Plenum Spacer
You will NOT reach those numbers without a a GTM spec blower and possibly a GTM 85mm pulley. You are also missing a fuel return system or fuel pressure regulator.
What ems do you plan on running, if only using a reflash and running off of a maf sensor, you will need an upgraded maf. If you run a v-pro or similar, you can run off of map.
You will be better served getting at least a GTM Stage 1/2 kit or higher for your goals. Some of what you mention in mods will be included in the GTM kits, in addition to the GTM spec blower and/or pulley.
Old Jul 27, 2010 | 09:50 PM
  #396
jonnylaw's Avatar
jonnylaw
There is a lot of misinformation in this thread.
Old Jul 27, 2010 | 09:56 PM
  #397
jonnylaw's Avatar
jonnylaw
Meth is always a plus for S/C applications, although not necessary.
My Power Enterprise metallic HFC's have held up fine under boost (although I might check them next time they are on the rack).
I am tempted to try the Motordyne ART pipes and XYZ pipe with HFC to see if any gains can be had, but they are still out of stock and I am still unsure on whether to pull the trigger.
Old Jul 27, 2010 | 10:07 PM
  #398
jonnylaw's Avatar
jonnylaw
Itozann,
you said you lost 2psi with test pipes, but did you gain any power?
Old Jul 27, 2010 | 10:54 PM
  #399
ITOzann's Avatar
ITOzann
Originally Posted by jonnylaw
Itozann,
I lost 2 psi and lost about 10whp. I'm really considering the idea of a Crank pulley to make up for the boost lost, but I I wonder if I'll run into any problem
Old Jul 27, 2010 | 11:00 PM
  #400
ITOzann's Avatar
ITOzann
Itozann,
Also, to those planning to do meth, I'd recommend to save the money. Even I was told by my tuner that at 6-8.5psi it is simply not worth it.
Can you really do meth without a tune???? I didn't know that
