My HKS S/C Installation
Old Aug 11, 2010 | 08:14 PM
  #461
Ruthless18x's Avatar
Ruthless18x
I can't link it because the GTM site is Flash based, but it's toward the bottom of the supercharger kits page. It's called the Stage 5 Tuner kit and it's $5600.
Yeah it looks like basically a Stage 3 package with no fuel. I'm assuming the unit is modified to the same specs regardless of what "Stage" it is, right? So yes that would make the Stage 1 make more sense.
Also, I thought I read somewhere in this thread about your exhaust setups and that free flowing isn't always the best?
I'm thinking of either running my HKS dual with test pipes or my JIC full ti with test pipes. So would I lose more boost with the JIC than the HKS hypothetically?
Old Aug 11, 2010 | 08:46 PM
  #462
jonnylaw's Avatar
jonnylaw
It's hard to say as there does not seem to be much consistency in the numbers. My opinion would be that there would not be too much difference b/w those 2 exhausts, however the test pipes might cause you to lose psi and possibly a small amount of power vs. HFC.
Earlier in this thread, Itozann said he lost ~2psi and 10whp by switching to test pipes.
I'd be interested to see what Motordyne ART pipes do tho.
Old Aug 12, 2010 | 12:01 AM
  #463
ITOzann's Avatar
ITOzann
YEAH, after I installed resonated TP's, I lost about ~2psi and about 10whp.
Old Aug 12, 2010 | 07:08 AM
  #464
cdoxp800's Avatar
cdoxp800
I took my Berk HFC's off an put the stock Cats back on. I gained 2 PSI. After doing so reading, seems that Superchargers like some Back pressure. The deal is to find the right amount Back pressure for both Tq and HP.
Old Aug 12, 2010 | 10:24 AM
  #465
str8dum1's Avatar
str8dum1
psi does not = horsepower
psi is a measure of air flow resistance. so OF COURSE you gained psi by putting the stock cats back on....
Itozann, you did a retune after adding the test pipes?
Old Aug 12, 2010 | 11:13 AM
  #466
cdoxp800's Avatar
cdoxp800
Correct, but I also gained 20ftlbs of Tq.. So like i said earlier.
Originally Posted by cdoxp800
I took my Berk HFC's off an put the stock Cats back on. I gained 2 PSI. After doing some reading, seems that Superchargers like some Back pressure. The deal is to find the right amount Back pressure for both Tq and HP.
Old Aug 12, 2010 | 02:45 PM
  #467
350z006's Avatar
350z006
That was definitely the case with my Vortech...I got more power with a Moordyne xyz+hfc that with just straight TP's...
Old Aug 12, 2010 | 04:24 PM
  #468
ITOzann's Avatar
ITOzann
yes I did retune it right after the tp installation. I change the set up from oem cats with a single exhaust to resonated tp's with a true dual exhaust. Anyways, I agree with cdoxp800. It seems that the HKS s/c likes back pressure.
BTW, has anyone dyno'ed in a low calibrated mustang dyno. I'm not trying to compare gains or anything like that. I just want to check the output.
Old Aug 12, 2010 | 04:29 PM
  #469
cdoxp800's Avatar
cdoxp800
Originally Posted by 350z006
+1
Yep. I read your post and also talked to Tony. Very good info and nice improvement.
Old Aug 13, 2010 | 10:04 AM
  #470
vashuba311's Avatar
vashuba311
so does this kit(rotrex) sound like more of a turbo? does it have that wind like a traditional roots type? never heard one before. plus i love the sound of a turbo, but if i can get it with the reliablity of a supercharger, its a win win
Old Aug 13, 2010 | 10:27 AM
  #471
Ruthless18x
There are some videos in this thread and there are some on YouTube.
Either way I would not purchase any forced induction kit based on the sound it makes.
Old Aug 13, 2010 | 11:59 AM
  #472
cdoxp800's Avatar
cdoxp800
Here is a vid of mine a Z1 Motorsports
<object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/d6FLr2HjU_g?fs=1&amp;hl=en_US&amp;color1=0x3a3a3a&amp;color2 =0x999999"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/d6FLr2HjU_g?fs=1&amp;hl=en_US&amp;color1=0x3a3a3a&amp;color2 =0x999999" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
Old Aug 13, 2010 | 01:03 PM
  #473
vashuba311's Avatar
vashuba311
^^^^ nice!
Old Aug 13, 2010 | 06:25 PM
  #474
ITOzann's Avatar
ITOzann
Please don't choose an FI system base on the sound.
more hks clips ^.^
@10psi
http://www.youtube.com/watch?v=dRTr0tm8AYo
@10psi
http://www.youtube.com/watch?v=Xo_GEMYmP6U
@6psi - you can hear the blower at 21sec lol
http://www.youtube.com/watch?v=C3kTHQ1AF8Q
Old Aug 13, 2010 | 10:20 PM
  #475
jonnylaw's Avatar
jonnylaw
I can't find a 7pk1060 belt. I'm looking for one. Mitsuboshi makes one, but I can't find anywhere to buy it. HKS makes one, but they want an arm and a leg for it...
For the ATI crank pulley and the HKS SC, sizes should be
6pk1735 or 6pk1740 for alternator/ps
4pk860 or 4pk865 for a/c
Old Aug 14, 2010 | 08:52 PM
  #476
Ruthless18x
^ What is your current configuration Jonny? You sold your ATI right?
Hey ITOzann, do you have any of your dyno sheets you could post? I thought you posted them once, but I couldn't find them...
Old Aug 16, 2010 | 12:42 PM
  #477
ITOzann's Avatar
ITOzann
I only had a pic of the pulls at 6psi but and print outs at 8psi and 10psi.(all done in a low calibrated mustang dyno) Hopefully I still have them around since recently I moved and threw/lost lots of stuffs
Old Aug 16, 2010 | 07:56 PM
  #478
Ruthless18x
Bummer. Let me know if you find them for sure!
Old Aug 20, 2010 | 02:26 PM
  #479
cdoxp800's Avatar
cdoxp800
Hey guys been a while since I posted in here do to some projects I have been working.
So take I talked with Sam about a few of my ideas and he cannot see any issues with them.
1. I plan to relocate the MAF out of the HKS Suction Pipe (Currently using PMAS Here) and moving it up by the throttle body and using the OEM MAF (New 3" section added to existing Pipe). By doing this the ECU will see a truer air intake Temp and less turbulent air. This will let me run my OEM MAF. The current location of the MAF is seeing allot of Hot air from the engine Bay and passes this to the ECU, but the true temp of the Air after the intercooler is much cooler and not being take advantage of in the tuning.
See below Pic:
2. I plan on building a New Intake for the SC itself to get a way from the garbage HKS filter and moving it to a cooler air location. I plan on using a Apexi filter (Part #: 500-A024). I chose this filter because if this review.
http://www.mkiv.com/techarticles/filters_test/2/
Intake Sample Pic:
I feel all these changes will help better the performance of the HKS kit. It's going to take few weeks to get all this made because of work, and then a whole re-tune.
Old Aug 20, 2010 | 05:39 PM
  #480
ITOzann's Avatar
ITOzann
Intake Sample Pic:
AWESOME!!! if you would consider doing an extra intake pipe let me know, I'll put a deposit on it I tried 6 different filters and none worked with my large aftermarket radiator.
Please let me know
BTW, where did you get that pic from?
