Is a stiffer engine mount available for the GTM VQ35HR TT Kit?
Old Apr 6, 2010 | 04:21 AM
Germanguy's Avatar
Germanguy
Default Is a stiffer engine mount available for the GTM VQ35HR TT Kit?
Hi,
Im riding a built stage 2 GTM VQ35HR TT Kit. The engine now sits approxx. 0,5 cm higher than stock. Today we wanted to change the stock engine mount into a stiffer one, but it didnt fit. There is 1 cm room between the bolt and the mount. My question is: Are there any stiffer engine mounts out there for the HR GTM TT guys?
Thanks,
Alex.
Old Apr 6, 2010 | 05:21 AM
GreenGoblin's Avatar
GreenGoblin
Doesn't the GTM kit come with spacers for the oem mount? If so you could use those to fill your gap.
Old Apr 6, 2010 | 06:32 AM
str8dum1's Avatar
str8dum1
that or just stack fender washers, assuming the bolts are long enough on the motor mounts.
Thats what I used on my solid mounts.
Old Apr 6, 2010 | 10:48 AM
QuadCam's Avatar
QuadCam
I still can't believe they designed their kit and messed up on the headers and had to use spacers on the motor mounts so the downpipe would clear the steering shaft.....
Old Apr 6, 2010 | 12:03 PM
GreenGoblin
A much cheaper bandaid then getting a new casting made...
Old Apr 10, 2010 | 07:06 AM
BrazenZ's Avatar
BrazenZ
Check out sound performance solid engine mounts. I believe I read that they are longer that stock.
Old Apr 10, 2010 | 08:34 AM
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
In order to be able to fit six different turbo options with 9 different A/R's housing, spacing the engine was a must, And in my opinion it is a small compromise for what the kit can offer.
I hope this makes sense
Sam
Old Apr 10, 2010 | 03:18 PM
midz350's Avatar
midz350
^^ +1000
