New Build
Old Apr 24, 2010 | 02:21 PM
SH Luciano's Avatar
SH Luciano
Default New Build
Quick background, in 2007 in got an APS single turbo installed on my stock block...made about 400whp at 10psi. Over the past few years I've purchased some extras, Stoptech BBK up front, Haltech, Cosworth manifold, 830cc Deatchwerk injectors...and most recently (couple months ago) the stage 1 long block from IPP. My friend finally got some free time to pull my old motor and install the new one. He put a turbo blanket on from PTP, header wrapped the crap out of all the exhaust piping pre-turbo, made a brace for my oil solenoid, replaced the fuel line in the engine bay to get rid of some of the unnecessary bends/fittings, custom catch can that vents both valve covers, and a custom external wastegate with a tial 38mm slime line gate. I drove the car home today with my old injectors/unichip for the break in, and have a tune scheduled at AMS in about 9 days. I'm sure there are some things I'm forgetting...but that's pretty much the meat of it.
Once car is tuned, Ill post numbers/graphs with results. Cross your fingers...I'm hoping to be pleaseantly surprised, but likely it'll be around 500whp.
Attached Thumbnails New Build-1.jpg   New Build-2.jpg   New Build-3.jpg   New Build-4.jpg   New Build-5.jpg
SH Luciano's Avatar
SH Luciano
moar pics
Attached Thumbnails New Build-6.jpg   New Build-7.jpg   New Build-8.jpg   New Build-9.jpg   New Build-10.jpg
Old Apr 24, 2010 | 02:22 PM
SH Luciano's Avatar
SH Luciano
more pics...
Attached Thumbnails New Build-11.jpg   New Build-12.jpg   New Build-13.jpg   New Build-14.jpg   New Build-15.jpg
Old Apr 24, 2010 | 02:23 PM
SH Luciano's Avatar
SH Luciano
last couple pics...
Old Apr 24, 2010 | 04:52 PM
glenns280's Avatar
glenns280
nice
Old Apr 24, 2010 | 04:59 PM
Goo$e's Avatar
Goo$e
Looking at pictures is my favorite. More pics.
Old May 18, 2010 | 11:32 AM
SH Luciano's Avatar
SH Luciano
somewhat dissappointing results...here's the dyno. any ideas from the experts out there as to what could be causing the boost issue up top?
File Type: pdf
Old May 18, 2010 | 12:33 PM
thom000001's Avatar
thom000001
What are the specs on the turbo....and everything else.
Was it always external WG or did you modify it to be external?
Most folks see 18-20rwhp per lb of boost (at least when twin'd)
tom
Old May 18, 2010 | 12:50 PM
zmedic16's Avatar
zmedic16
damn. upgrade turbo?
Old May 18, 2010 | 12:54 PM
Boosted Performance's Avatar
Boosted Performance
Vendor - Former Vendor
I think you turbo is runing out of breath.
Old May 18, 2010 | 01:00 PM
SH Luciano's Avatar
SH Luciano
turbo is the standard off the shelf turbo that came with the aps st kit - gt35r, BUT the housing(s) are smaller than normal. according to aps website they say 16psi is good for 650hp worth of air flow...but they're obviously blowing hot air up MY *** like my turbo is to my motor past 15psi. turbo is internally gated from the kit, changed that up to be an external gate with a tial 38mm slim line gate, i think it has 8.8lb spring which should be good for 17.6 psi if i'm not mistaken.
the tuner said possible causes being exhaust valve float or cam problems...but i'd think the car would run like crap through out the whole rev range if that were the case?
i think it's time to convert this pos kit to a twin kit.
Old May 18, 2010 | 01:04 PM
thom000001's Avatar
thom000001
Is variable cam timing still turned on, and what is controlling it......
Maybe your cams aren't phasing
Tom
Old May 18, 2010 | 01:11 PM
str8dum1's Avatar
str8dum1
when my cams dont phase, its very noticeable in the boost curve. His boost curve looks pretty normal..
So basically you gained 50 hp while going with a lower compression motor. I'd say not bad.
Old May 18, 2010 | 01:56 PM
SH Luciano's Avatar
SH Luciano
Tom
fwiw cam phasing only works pre 5500rpm's (i've been told), so in theory that shouldn't impact my high rpm power.
Old May 18, 2010 | 01:57 PM
SH Luciano's Avatar
SH Luciano
not bad? when you figure in cost...that's a pretty terrible hp/$ ratio.
Old May 18, 2010 | 02:26 PM
Boosted Performance
You have to keep in mind that you have a kit that was meant to work best with a stock motor. The T3 is just too small for big power.
Old May 18, 2010 | 02:57 PM
Barnabas's Avatar
Barnabas
National Z Club President
already stated...
Old May 18, 2010 | 02:58 PM
SH Luciano's Avatar
SH Luciano
that's why i just need to add another one
Old May 18, 2010 | 04:23 PM
str8dum1's Avatar
str8dum1
Unfortunately, someone should told you that before you bought a built motor. No big secret that kit wouldnt make big numbers.
Old May 18, 2010 | 07:40 PM
SH Luciano's Avatar
SH Luciano
i wasn't looking for "big" numbers, just hoping for 500 to the tire...which i've seen a few other builds get.
oh well, back to the drawing board...
