the 8 questions game!
Old Apr 26, 2010 | 02:54 PM
dimitris20's Avatar
dimitris20
Default the 8 questions game!
The goal is to get a no name single turbo kit that I found on the internet (very cheap) and get some power out of it at 8,5 psi. Im willing to go ahead and test this option because:
1. Its cheap
2. Looks an easy project
3. I thing the worst case scenario (having 8,5 psi as max pressure) is to get ridiculous results out if this kit
4. After done that it will be fairly easy to install a proper kit
5. Ive already spoken with 8 people that have installed this no name turbo and have no problem so far (not on a 350z yet though)
6. If I succeed it will be great news for every 350z owner!!!
7. Its cheap!!!
Questions:
1. Is additional fuel management controller needed . (I will use an exhaust gas oxygen sensors for monitoring oxygen content of exhaust gases ,what’s its name?)
2. Where can I find an additional ECU for this application?
3. If don’t use one what’s the safest psi that can I go up to?
4. What’s the worst case scenario.
5. What is the size of the turbine that I need (max torque @ 3,5 to 4 rpm)
6. What other necessary sensors do I have to install to avoid as much trouble as possible?
7. Any other obvious point that I haven’t considered
8. Im I crazy???
If somebody is willing to answer only the 8th question please don’t cause I know his answer already.
And please don’t get into conversations like “you get what you played for” cause China proved this saying wrong many times the past 5 years, at least to me.
Thanks
Old Apr 26, 2010 | 02:58 PM
thom000001's Avatar
thom000001
Oh wow...this will be a good one!!!!!!!
Old Apr 26, 2010 | 03:08 PM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
Sub'd
Old Apr 26, 2010 | 03:13 PM
sublimemoment's Avatar
sublimemoment
Please let us know how this goes........lol
Old Apr 26, 2010 | 03:17 PM
IslandZavage's Avatar
IslandZavage
i think its a great idea. i give u props for trying something most will not due. Turn that **** up to 9psi. make sure u do a DIY install thread and get a dyno sheet to show everyone how this kit will be a beast on the street. How much power those 8 people u spoke too get out of it.. Good luck...
BTW
Old Apr 26, 2010 | 03:18 PM
Vas_Z33's Avatar
Vas_Z33
lol lmfao... Iam amazed at your threads OP...
Old Apr 26, 2010 | 03:34 PM
tonyzS/C03's Avatar
tonyzS/C03
^+1 but here we go....
1. i think that your looking for a wideband O2 sensor. several kits use the stock injectors for FI (Vortech) but they also use an additional computer to monitor and add fuel as needed.
2. do more homework there are lots...
3. ??????
4. catostrophic engine failure and the self distruction of the known universe
5. more homework agian but a quick search of the interwebs gives a ton of results http://www.squirrelpf.com/turbocalc/index.php
6. boost gauge would be a good start... in addition to the exhaust gas oxygen sensors that you will be installing.
7. just doing it right the first time and save your pennies for a name brand kit
8. .......
Old Apr 26, 2010 | 03:53 PM
Boosted Performance's Avatar
Boosted Performance
Vendor - Former Vendor
I think you need to tell us ALL the turbo specs that the seller provided you with.
Old Apr 26, 2010 | 04:10 PM
Barnabas's Avatar
Barnabas
National Z Club President
hmmmm in fir results....
who are these 8 people?? dyno numbers?? how long have they had them??
Old Apr 26, 2010 | 04:21 PM
RoTors350Z's Avatar
RoTors350Z
The 8 that you've interacted with, how did you find them? They wouldn't happen to be people who have provided glowing reviews of this kit, on ebay, and probably have no other transactions other than buying and giving the feedback?
Have you seen these cars, that have this kit, in person?
Old Apr 26, 2010 | 04:23 PM
zman1982's Avatar
zman1982
Every two days OP has a brilliant idea!
Guilty1s's Avatar
Guilty1s
Wow... usually Dave needs to post up
Nope, your the first.... Go ahead and install it and let us know the result...
Old Apr 26, 2010 | 05:12 PM
str8dum1's Avatar
str8dum1
there was a thread a couple years back about a a guy that made customsingle kits using chinese turbos/wastegates/BOV and made over 450whp on the stock block.
I little prep work on the turbo such as cleaning casting flaws/etc and there's no reason why the OP cant make it work.
Old Apr 26, 2010 | 06:03 PM
CeBrwn5454's Avatar
CeBrwn5454
In for results...I'd love to see indepth documentation of what you buy, from who you buy it, and the price.
Best of luck.
Old Apr 26, 2010 | 06:08 PM
35th SS's Avatar
35th SS
sub'd
Old Apr 26, 2010 | 06:18 PM
jeffie7's Avatar
jeffie7
I hope this works well! I'll remove my powerlab kit and sell it on ebay then pick up one of these kits and in the end pocket around 5G
*crosses fingers* please oh please!
Old Apr 26, 2010 | 08:00 PM
adamciya350's Avatar
adamciya350
Inb4davidv
Old Apr 26, 2010 | 08:35 PM
go-fast's Avatar
go-fast
F34RL355's Avatar
F34RL355
the 8 people are really his 8th question they are all in his head, i think hes crazy
Old Apr 26, 2010 | 11:02 PM
dimitris20's Avatar
dimitris20
[QUOTE=IslandZavage;8335244]i think its a great idea. i give u props for trying something most will not due. Turn that **** up to 9psi. make sure u do a DIY install thread and get a dyno sheet to show everyone how this kit will be a beast on the street. How much power those 8 people u spoke too get out of it.. Good luck...
BTW
Nobody tried on a 350z, all they were replacement turbos for stock cars but nobody mentioned any broblems with performance or reliability , yet is too late because nobody have used the kit for more than 6 months
