The Journey of a DeatschWerks Injector
Old May 4, 2010 | 01:41 PM
DeatschWerks's Avatar
DeatschWerks
Vendor - Former Vendor
Default The Journey of a DeatschWerks Injector
This blog was written by the President of DeatschWerks, David. He has a monthly blog that can be found here: The DeatschWerks Tech Blog
Please give us your feedback in the comment section of the blog page!
Chris
By David Deatsch
When your shiny new box of DeatschWerks injectors arrives at your door, few realize their journey consisted of much more than a ride on a UPS truck. Post production testing at DeatschWerks is just as important as the magic and love we put into each injector during the production process. Before injectors are put into sets, a battery of tests are performed and only the best make the cut. Our staff works hard to to continually develop and improve what is already the industry leading injector testing and quality assurance program. It is a lot of extra work but it is all worth it to ensure flawless performance for our customers from the first crank of your engine.
Coil Testing – Ohm testing is where many shops stop but it is just the beginning for us. In addition to the basic ohm test, we test for direct shorts, voltage draw, and latency. Our newest coil test is an LCR based binning procedure which combines impedance, inductance, and resistance values of a coil to classify injectors into 3 different categories (bins). These bins are then separated and never mixed so only injectors with the closest coil characteristics will make it into the same set.
Spray Pattern and Atomization – Proper spray pattern and atomization is analyzed visually on the flow bench. The spray pattern is observed at a wide range of pulsewidths and rpms so that the injector is assured to perform well under all engine conditions.
Static Test - We perform the static test a minimum of 3 times on each injector to ensure consistency. In addition we only flow test using the best equipment which is calibrated daily and operated by experienced, full-time, DeatschWerks trained employees.
Dynamic Test – We have been using dynamic testing in accordance with SAE guidelines since day one over 5 years ago. Every set of our injectors is balanced for static flow rates, dynamic flow rates, and coil response.
Injector Matching - What good is all this testing if we don’t put it to good use? We use all the data we collect to make the best sets possible. We match injectors for static rate, dynamic rate and coil response. We put them in sets with less than 2% variance in each of those 3 categories.
QA testing – The last step is putting the injectors into matched sets so we’re done, right? Oh no, we pull 10% of all boxed injectors off the shelf and flow test one more time. Why? quality control, thats why. We go the extra mile to provide our customers the best quality available.
The report – A personalized flow report with every set… it’s a DeatschWerks exclusive. No other company gives you as detailed information about your specific set of injectors as we do. In addition, we provide the data on a colorful, easy to read report.
Old May 4, 2010 | 03:51 PM
350Z400rwhp's Avatar
350Z400rwhp
I love mine!
Old May 4, 2010 | 04:05 PM
streetzlegend's Avatar
streetzlegend
Good to know I have a quality part on my car, I havent had a single issue with my 600cc's.
Old May 4, 2010 | 04:09 PM
jeffie7's Avatar
jeffie7
So far my 600s still flow fuel =) Now they just need to ship them in a nice pretty shiny box, not the basic white box.
ohwell we can't have our cake and eat it too.
Old May 4, 2010 | 04:25 PM
Vas_Z33's Avatar
Vas_Z33
loved my 600s... going to get 800s for my build!
Old May 4, 2010 | 04:42 PM
westpak's Avatar
westpak
SFZCC
One of the 800's I ordered ohmed at 500, I wanted to switch to hi impedence but that was a bit too much
Old May 4, 2010 | 05:57 PM
whoojong's Avatar
whoojong
love my 600's. great product. I love drop in parts.
Old May 4, 2010 | 06:07 PM
_ink's Avatar
_ink
the drop in factor is awesome!!!
but why did you make them green??
Old May 4, 2010 | 06:19 PM
whitez33350ztt's Avatar
whitez33350ztt
love my injectors.. plug and play is great
Old May 4, 2010 | 06:37 PM
IslandZavage's Avatar
IslandZavage
any plans on a 1200cc?
Old May 4, 2010 | 06:44 PM
Vas_Z33's Avatar
Vas_Z33
+111
Old May 4, 2010 | 07:34 PM
midz350's Avatar
midz350
+10000 considering the HKS 1000cc cost over $1000 for the set of 6
Old May 5, 2010 | 08:34 AM
DeatschWerks
We do have some larger sizes coming soon. For those interested, send me a PM with your email (and phone #, if you like) and I'll put you on the contact list.
westpak, you have a PM.
Old May 5, 2010 | 08:46 AM
str8dum1's Avatar
str8dum1
not the ones I am selling.
but for people that have to use high impedance injectors, DW FTW
Old May 5, 2010 | 10:38 AM
IslandZavage
Originally Posted by deatschwerks
we do have some larger sizes coming soon. For those interested, send me a pm with your email (and phone #, if you like) and i'll put you on the contact list.
Westpak, you have a pm.
pm sent
Old May 5, 2010 | 07:30 PM
Hexxum001's Avatar
Hexxum001
My DW's have worked great for 3+ years now.
Old May 5, 2010 | 08:58 PM
Elperuano's Avatar
Elperuano
Good gawd, 1000cc! Hows the gas mileage? :P
Old May 6, 2010 | 06:11 AM
captj3's Avatar
captj3
Your injectors are OK. So why are the ones I have under rated. I sent them out and to have them cleaned and tested. Needless to say they still didn't come back at your rating.
Old May 6, 2010 | 06:48 AM
DeatschWerks
Injectors flowing differently on other benches is not uncommon. Flow Benches are like dynos, they are all going to read differently from one to another. It is more important for the injectors in a set to have like flow characteristics than it is for their overall flow rating. Our tests are conducted to, and above, SAE standards using one of the SAE's approved test fluids.
Apart from the flow bench, there are environmental variables that can affect flow rates. The temperature of the room, fluid, injector during testing; humidity, the test fluid used, the pressure at which the fluid is introduced to the injector (just a 1lb difference can net a 10cc difference!).
I hope that helps. I am curious to see the difference, though. Do you have your flow report for after the cleaning?
Old May 6, 2010 | 08:03 AM
captj3's Avatar
captj3
Yes I do before and after. Let me know I would be more than happy to show you the report. Just tell me where to send it to.
