BOV!
Old May 11, 2010 | 08:48 PM
  #41
mx594's Avatar
mx594
I am using a (knockoff) HKS SSQ with the insert removed. At 7 psi of boost it is very quiet. I don't really care for the sound either. I was thinking about switching to a synapse but I haven't heard much about them. The nice thing about the synapse is that it has multiple flange options so I could swap it in without changing the flange that is already welded onto my piping.
Old May 11, 2010 | 09:04 PM
  #42
Elperuano's Avatar
Elperuano
I actually like the sound of the BOV... Im at 8lbs and i love to hear but can only really hear it at part-throttle... Im guessing with my open dumps at WOT i cant hear it all when..
Old May 12, 2010 | 01:13 AM
  #43
tw8715's Avatar
tw8715
anyone know what size flange to get with the HKS ssqv bov?
its being matched to greddy TT pipes.
thanks!
Old May 12, 2010 | 04:19 AM
  #44
Alberto's Avatar
Alberto
Cranky FI Owner
Originally Posted by Elperuano
Yessir... Lima, Peru de Chorillos! Para la Universidad!
U? I was gonna say te parece peruano tambien but I didn't wanna make no assumptions..
Miraflores Lima is where I was born, dont know much about it other than what Ive seen in my visits back to the motherland.
Alberto the SWOOSH sound ur car makes at WOT sounds nice.. r u runnin open dumps also? Im sure the built block n the massive pounds of boost ur runnin must help also
I run open dumps as well, the sound WOT is mainly that but the K&N intakes made things slightly louder than the stock foam Greddy crap.
Old May 12, 2010 | 09:15 AM
  #45
Elperuano's Avatar
Elperuano
Thas cool Alberto, you were born in the nice part of Peru Like me
I try to go back as often as I can... Might take another trip in October.. we'll see
As for the sound of my open dumps... its just loud.. in-car vid sucks ill get one of my buddies to film it as I drive by...
Old May 13, 2010 | 12:23 AM
  #46
tw8715's Avatar
tw8715
Bump! Anyone know which flange size to get to mate up with the greddy tt pipes?
Old May 13, 2010 | 09:01 AM
  #47
mx594's Avatar
mx594
Isn't there only one size flange? Why would it matter if you are going to weld it on?
Old May 13, 2010 | 12:40 PM
  #48
tw8715's Avatar
tw8715
Well I'm sure there are sizes for a reason. Would want the flange to be larger then the pipe.
I'm think 50 mm would be good? Can anyone else confirm?
Old May 13, 2010 | 01:30 PM
  #49
IslandZavage's Avatar
IslandZavage
what did your tuner/installer say about it?
Old Jun 9, 2010 | 09:52 AM
  #50
VQ35deMax's Avatar
VQ35deMax
I am using a Turbosmart Vee port unit however I am having some issues with it. Maybe you guys can help me out with some advice.
First things first does it matter how long the vacuum line is? Is the theory the shorter the better apply here? Also when using a hose, is a silicone hose a bad idea?
I have adjusted the blow off valve by spinning it to the softest setting. However under partial throttle I hear compressor surge. I took the valve apart and i could see where it moved up and down. So i know it opens when the car builds boost but it stays closed at idle and when the vehicle is revved. Also my idle is fine and the car does not die.
Any suggestions?
Old Oct 27, 2010 | 08:30 AM
  #51
TheDangerZone's Avatar
TheDangerZone
Originally Posted by hydroflip
sard bov ftmfw!
SARD is legit, I have a friend that has one on his EVO and it's nice. no sputtering at all. I'm pretty sure this is the one he bought
http://www.more-japan.com/sard-r2d2-...ngle-type.html
bcoffee20
Nov 19, 2015 06:39 PM
Calinismo350z
Sep 14, 2015 04:04 PM
