my SC Setup
Old May 12, 2010 | 01:50 AM
maXmood's Avatar
maXmood
Under Boost!
Default my Vortech SC Setup
Finally, after a long wait (about 4 months), the car went in for vortech sc installation..
i've created this thread to post in all the details/issues/problems i may face along the way rather than creating a new thread every time something comes up, and for anyone interested on how it goes.
What's on the car already:
-Stillen short ram intake
-MD Plenum Spacer w/ ISO Thermal
-Berk HFC
-Borla TD Exhaust
what's going on the car:
-Vortech SC v2 Tuner kit with Charge cooler (No FMU or SS Box)
-2.87 drive pulley
-600cc DW injectors
-Walbro 255lph fuel pump
-Koyo 36mm Vcore radiator
-B&M Trans oil cooler
-GTM HD engine oil cooler
-NGK one step colder spark plugs
-AAM oil pan spacer
-Nismo thermostats
along with AEM Boost, AFR and Oil pressure gauges..
Tuning with Osiris, by PM-Dyno.
will keep this thread updated.
Old May 12, 2010 | 04:24 AM
ITOzann's Avatar
ITOzann
I like your list!
Old May 12, 2010 | 07:27 AM
djamps's Avatar
djamps
Which engine management?
Old May 12, 2010 | 08:05 AM
Vas_Z33's Avatar
Vas_Z33
it says that he is tuning it with osiris
Old May 12, 2010 | 08:10 AM
verdict.'s Avatar
verdict.
Originally Posted by ITOzann
I like your list!
Agreed.
Old May 12, 2010 | 08:55 AM
Erdem's Avatar
Erdem
how long would it take them to get the car up & running again?
Old May 12, 2010 | 09:27 AM
maXmood's Avatar
maXmood
Under Boost!
I like your list!
Originally Posted by verdict.
Agreed.
Thanks
this goes back to the search button and the FI guys.
i'm not rushing the mechanic.. i just came back from the garage, he installed GTM oil cooler (no pics) and nothing else.
hope it goes all well..
Old May 13, 2010 | 01:40 PM
nightcrawler_8's Avatar
nightcrawler_8
all the best in your setup
+1 for hijacking.. but look at it from a postive point of view... maybe u will learn something out of it and avoid the reason while building your setup \
good luck bro
Old May 15, 2010 | 11:46 AM
maXmood's Avatar
maXmood
Under Boost!
good luck bro
Thanks bro..
Update:...
Car is almost done, i'm missing couple of parts and need some advice.
first, i've order the AAM oil pan spacer to skip tapping the oil pan. but it came without the connector (dunno what it's called), and i need to find one. i need a name, any recommendation?
second, since i'm tuning with Osiris, the tuner asked me for a wideband.. even tho i'll be having the AEM EUGO (AFR gauge) installed, which isn't that accurate for tuning, can't he just read the AFR directly from Cipher and tune it through ROM Editor?
if not, then what do you recommend?
thanks
Old May 15, 2010 | 01:20 PM
maXmood's Avatar
maXmood
Under Boost!
ok, i think i found a solution to my first request...
http://www.fastwayracer.com/p70/UNIV...duct_info.html
Old May 15, 2010 | 04:46 PM
whitez33350ztt's Avatar
whitez33350ztt
whos tuning ur car in bahrain? just curious and sounds like a great list.. almost identical to mine
Old May 16, 2010 | 12:39 AM
maXmood's Avatar
maXmood
Under Boost!
what numbers did you push when it was stock and what is it now?
the tuner is from PM-Dyno, KSA (Saudi), his name is Julan. he'll be coming over to bahrain to do the tuning.
Old May 16, 2010 | 01:27 PM
maXmood's Avatar
maXmood
Under Boost!
Update...
the car is done (installation).
finally!!
had to tow it to my house because of the bigger injectors and since there isn't an SS box with the kit.
hand was itchy and i couldn't resist, so i cranked it up!! woooo..! love the sound, and was watching the AFR guage going down hill (went from 14.9 to 12.xx), so i switched it off .. the fume is ughh..
can't wait till it's tuned..
Old May 16, 2010 | 04:32 PM
Synjn's Avatar
Synjn
You have a nice setup. Very similar to mine. I like all the oil coolers and large radiator. Prolly hot as hell over there. I recommend the wideband though. At first I didn't really like it but have come to realize that it is an essential piece of monitoring equipment. Get another gauge to cross reference like an "oil temp" or "exhaust gas temp." I'm a pilot so I love gauges
Old May 16, 2010 | 07:56 PM
whitez33350ztt
my car is full bolt on and stage 2 cams.. stock bottom end with the stock pulley and stock maf using osiris as my engine managemnt.. i ran outta voltage at 5800 rpm and made 377whp and 310wtq on a dynojet. im going back withthe pmas maf and should be pretty close or hit 400whp.. on 3.33 pulley.. the car pulls so hard with the cams.. its hot as hell in new jersey and i was thinking about an oil cooler.. its probably a major help right?
Old May 17, 2010 | 06:47 AM
teh215's Avatar
teh215
Any issues with the aftermarket radiator and the Vortech belts?
Old May 17, 2010 | 06:53 AM
maXmood's Avatar
maXmood
Under Boost!
thanks...
it's defo hot as hell.. spring is about 30c, summer reaches 50c.. oh, and winter is just as low as 12c.
i'm not sure why i went with oil pressure gauge (since we already have the stock one).
Old May 17, 2010 | 07:05 AM
maXmood's Avatar
maXmood
Under Boost!
i'm sure it's gonna help alot in hot weather.
really good numbers you got there.
Old May 17, 2010 | 07:06 AM
maXmood's Avatar
maXmood
Under Boost!
with 36mm koyo rad, it's all good here.
Old May 17, 2010 | 01:33 PM
maXmood's Avatar
maXmood
Under Boost!
tuning is gonna be done tomorrow..
need your thoughts on this.. the belt doesn't look too tight, i can twist it 90 degrees and probs more.
i'm not sure if the tensioner is tightened enough (need to search for DIY), but i think i'll need a shorter belt (probs 80") if it's tightened at its max.
