Removing Greddy turbos without extracting engine ??
Old May 16, 2010 | 02:41 PM
cersoft's Avatar
cersoft
Default Removing Greddy turbos without extracting engine ??
I did a search but couldn't find anything, is this possible, my seals on the driver side turbo might be done and I'm trying to figure out how much I'm looking at ...
Old May 16, 2010 | 02:52 PM
Vas_Z33's Avatar
Vas_Z33
is it possible? yes. people have made the kit fit with the engine still in place.. im sure they can be removed as well. its a PITA
Old May 16, 2010 | 02:55 PM
midz350's Avatar
midz350
If you have small hands.
Old May 16, 2010 | 02:58 PM
GreenGoblin's Avatar
GreenGoblin
I had to do it once. I made a custom wrench.
Old May 16, 2010 | 03:15 PM
RandomHer0's Avatar
RandomHer0
patience and custom tools lol
Old May 16, 2010 | 04:55 PM
sdbarker's Avatar
sdbarker
Uhoh!
Old May 16, 2010 | 05:05 PM
Chris@FsP's Avatar
Chris@FsP
Vendor - Former Vendor
It is definitely doable. Removing the front cross bar and removing the bolts/lowering the steering rack a bit will make the job much easier.
Old May 16, 2010 | 05:33 PM
zman1982's Avatar
zman1982
Take a look at your hands, normal right. After you take them off with the motor in you will have many scars and cuts on your knuckles. Major PITA!
Old May 16, 2010 | 07:24 PM
NNOCENT's Avatar
NNOCENT
scars and cuts FTW
Old May 17, 2010 | 03:49 PM
superchargedg's Avatar
superchargedg
Damn Noobs
Well i installed my kit with the motor in the car and it was a major pita but it can be done.Just go and get some cheap wrenches and bend cut and whatever to make them work.............oh and dont forget the bandaid's. and the cussing and throwing of said tools.
Old May 17, 2010 | 07:30 PM
cersoft's Avatar
cersoft
Thanks for all of the advice
Old May 17, 2010 | 08:24 PM
GT-ER's Avatar
GT-ER
The reason I went Vortech instead of Turbo....although the boosted performance system was VERY tempting.
Old May 18, 2010 | 07:02 PM
QuadCam's Avatar
QuadCam
it should be alot easier to take it out with the motor in the car.
some of the hardest parts in installing the Greddy TT with the motor in the car is getting some of the nuts into place and then tightening them. taking them off will be alot easier.
as I recall, I had to glue a nut to the end of my finger so that I could get the nut inplace (turbine housing to exhaust manifold). otherwise, the nut would fall every time I tried to get in there. So, you won't have to do any other that BS to remove the nuts.....just let 'em fall!!
Old May 18, 2010 | 07:19 PM
ashtrojan2008's Avatar
ashtrojan2008
that's awesomely ingenuitive wish i would have thought of that lol
+1 on the cuts and cussing. You can look at the pics on my thread to see how the space looks
https://my350z.com/forum/forced-indu...pic-heavy.html
the hard part was putting the exhaust manifolds on with the engine in the car. Oh and if the wastegates aren't relocated... sorry. thats a pita.
as far as getting the turbo off, it really isnt that bad.
ross
Old May 30, 2010 | 06:42 PM
cersoft's Avatar
cersoft
So we got around to doing the leakdown test today and results are :-
14%, 16%, 20%, 22%, 16%, 25% for cylinders 1 -> 6
a little looser that I would have hoped but not disasterous right ?!???
Spark plugs look like this ..
Next step is to drill out the pcv valve as it is restricting flow and that is what is causing my smokey joe issues ...
Anyone want to comment on the numbers or plugs?
Old May 31, 2010 | 08:41 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Not great, but not bad. If the power is there, and it's not consuming much oil I would not be concerned.
How are you looking in terms of power output and oil consumption?
Old May 31, 2010 | 10:17 AM
cersoft's Avatar
cersoft
Thanks, yeah, power is still epic and I will certainly keep an eye on the oil consumption, I think that my biggest source of oil usage right now is the crank case pressure pushing oil back past the rings.
My current thoughts are that as an engine gets looser the pcv valve will not open soon enough / sufficiently under higher vaccuum situations, I'm gonna drill that sucker out as I have check valves in place only allowing flow into plenum and towards intake. The rest of my pcv / catchcan system will be a mirror of rcdash's system, breather on driver's side, pull from plenum and driver's side intake for vacuum / boost pull.
What do you think is your ideal pcv setup for a setup similar to mine (Greddy twins) ??
Old Jun 1, 2010 | 03:24 PM
cersoft's Avatar
cersoft
Update: So whilst driving I have been 100% without smoke or oil smell but each time I crank it (either hot or cold) I get quite an impressive cloud of smoke, this is quite annoying ...
Tonight I will unhook plenum suction and see if it still happens, I need to figure out where the oil is coming from ...
Any ideas?
Old Jun 1, 2010 | 07:38 PM
Blwn_By_Twins's Avatar
Blwn_By_Twins
I removed my pass side manifold/turbo once because the manifold cracked and needed replaced. I then took the entire kit out by myself in the garage to sell it last May. The only tool I had to make custom was either a 12 or 10mm box end wrench bent 90 deg. Did the rest with normal tools. Took me about 9 hours total. The manifold studs and 1 bolt holding the turbos to the manifold will be your biggest problem.
Old Jun 1, 2010 | 08:03 PM
mcook41's Avatar
mcook41
Are we talking about the 18 G or 20 G turbos
