Vortech V3 leaking, but not through seals.
Old May 26, 2010 | 04:27 PM
kam80's Avatar
kam80
Default Vortech V3 leaking, but not through seals.
Hi All, came back from the track on the weekend and when changing my wheels over saw oil, lots of oil...
Anyway I pulled the guard off and checked the SC, belts, seals and cogs are dry and the area where the drain line is connected to the housing is also dry. There's lots of oil on the guard and surrounding areas from around what I presume to be the filler bolt. There were no leaks before I went to the track and I've been using the Vortech for about 2 months now, so I'm guessing wherever the leak is coming from, it's under sustained high RPM.
I read back and a few people were having issues with the V2, is anyone having similar issues with the V3?
The bolt is quite hard to access as it's right up against part of the chassis, but I can get a hex key into it and have tightened it up, though it didn't seem loose. The breather bolt is also dry and there's no residue on the inside of my hood, not sure where else to look?
I also drained the oil and seems like I lost about 1/3rd of it.
Old May 26, 2010 | 04:28 PM
Vas_Z33's Avatar
Vas_Z33
its probably coming from your BPV... have your checked your IC piping?
Old May 26, 2010 | 05:18 PM
str8dum1's Avatar
str8dum1
so you did replace the bolt that came on the unit with the one in the package, right?
i'd pull your blower and inspect closer. take pics of oily areas on the charger
Old May 26, 2010 | 05:20 PM
Vas_Z33's Avatar
Vas_Z33
Originally Posted by str8dum1
thats a mess. Looks like a lot more than the 4oz that the V3 can hold as well...
oh **** i forgot the V3 doesnt share with the engine.. opps.. +1 to that ^
Old May 26, 2010 | 06:02 PM
kam80's Avatar
kam80
Yup did that. Got some photos at home taken through the guard, will post them up tonight, thanks for the help all!
Old May 27, 2010 | 03:52 AM
kam80's Avatar
kam80
Pics...in this first one you can see oil on the top of the guard that's been peeled back. Belt, cog, seals all dry.
Second pic is a slightly closer look inside...no visible residue on the SC housing except small patch on the bottom and on the breather hose.
I think it's the fill bolt because it's more likely the oil has come out, leaked onto the guard and dripped down...
Old May 27, 2010 | 04:13 AM
Vas_Z33's Avatar
Vas_Z33
is it me or does that cog seem to be installed in correctly??...
Old May 27, 2010 | 04:55 AM
05Z33's Avatar
05Z33
Is your A/C working fine?
Old May 27, 2010 | 12:27 PM
whoojong's Avatar
whoojong
Do you have a catch can? You may be getting blow by from the PVC, I have had this problem before.
Old May 27, 2010 | 03:25 PM
kam80's Avatar
kam80
I dunno, the cog comes preinstalled by Vortech and there aren't that many Vortech 350Zs rolling around Austraia to compare it against.
It was the last time I used it, it's winter in Australia now. The AC compressor has always been a bit greasy.
Hmm could be blow-by, I don't have a catch can on that side, but I've extended the intake piping into the front-bar, so it would be hard for oil to get all the way up there.
Old Nov 29, 2011 | 11:15 AM
ilbiondo's Avatar
ilbiondo
Default olio vortech v3
Ciao a tutti..
o riscontrato lo stesso problema di perdita dell'olio dal compressore e la cosa a mio parere sembra che succede quando si gira in pista e si sta su di giri....
sapete dirmi come risolvere il problema??
Grazie
Old Nov 29, 2011 | 11:26 AM
OldManZ350's Avatar
OldManZ350
got a pic of from the top showing the cog assembly?
350z006
Apr 14, 2009 08:11 AM
turtle1678
Aug 20, 2008 02:03 PM
str8dum1
Jan 10, 2008 09:45 AM
mcduck
Apr 27, 2004 06:33 AM
